  1. Jul 8, 2021 at 7:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Like @Darkness said they just click on. So you'd cut and deburr the copper then just push that fitting on.
    The expansion tank can literally be anywhere in the cold water side. Doesn't have to be right at the water heater.
    Also those compression fittings are awesome. I don't think we use anything else very often at work anymore.
  2. Jul 8, 2021 at 7:49 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Something like this, and a good supply of fittings, seems like a worthwhile investment for a do-it-yourselfer.
    https://www.amazon.com/IWISS-Plumbi...crimping+tool+5/8&qid=1625755579&sr=8-4-spons
  3. Jul 8, 2021 at 7:54 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Only comment on shark bites: sometimes they don't like to come off and can be a pain in the ass if the case. The little tool they provide works like 99% of the time, though. I had to use them often when working for an irrigation install company. Saved a ton of time, aside from the 1% where they didn't. Shark bites are also pretty pricey.
    onesojourner likes this.
  4. Jul 8, 2021 at 7:55 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Watch a youtube video first. It really is not that bad. Go grab some copper and practice once.
    NUDRAT[OP] likes this.
  5. Jul 8, 2021 at 7:58 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I would move this into the trees so you don't have as much maintenance on the trail.
    chrisb and Sirfive[QUOTED] like this.
  6. Jul 8, 2021 at 7:59 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ya'll seem to be forgetting that I am a self admitted mangler. I destroyed a perfectly good transmission pan. It seems you all want me to die.
    Tundies, NUDRAT[OP], Darkness and 2 others like this.
  7. Jul 8, 2021 at 7:59 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    It gets steep under the trees, but ill see what i can do. And thats more the high water line.
  8. Jul 8, 2021 at 8:00 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    This is way way easier than any of the work you have done to your truck.
    NUDRAT[OP], Festerw and bmf4069 like this.
  9. Jul 8, 2021 at 8:19 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I agree. It's not as bad as you think, and if you mangle, you just trim the copper back and start again. Get more connectors and couplings than you think you'll need.
  10. Jul 8, 2021 at 8:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Fair enough. I've been looking at Bradford White heaters online. I may have to go by in person to see how they are priced.
    I just got my 3rd quote back for replacement and they want $1,600 for a new 50 gallon heater so still in line with previous quotes.
    NUDRAT[OP], Darkness and onesojourner like this.
  11. Jul 8, 2021 at 8:33 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those are really cool for tight spaces but I'd never buy one. A mapp torch costs about $60 and I've yet to burn a house down.
    NUDRAT[OP], bmf4069, chrisb and 2 others like this.
  12. Jul 8, 2021 at 8:38 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    And you need a mapp torch to light your charcoal grill anyways.
  13. Jul 8, 2021 at 8:46 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Also great for mosquitoes. I stopped doing that once I got the electric tennis racket.
    bmf4069 and onesojourner[QUOTED] like this.
  14. Jul 8, 2021 at 8:46 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I thought they quit making mapp? Oxy acetylene all day long. Cant be seized if its liquid.
    bmf4069 and chrisb like this.
  15. Jul 8, 2021 at 8:52 AM
    I put my water heater in myself. Cut the copper pipes and bought ready to go sharkbite connectors with a valve for the cold water side. Easy swap. Found out later your supposed to have a permit to change your water heater. Weird.
  16. Jul 8, 2021 at 8:54 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Don't use the mamba :rofl:
    You would need to invest in a few tools to do this. You will at minimum need a copper tubing cutter. You can get away with using a hacksaw if you're careful but that can make it more work. A good tubing cutter will make clean cuts without deforming the pipe.
    If you use shark bite couplers with male adapters you can then use braided supply lines or even the corrugated copper supply lines. ALWAYS use an adjustable wrench to tighten those supply lines, never channel locks. With channel locks you can squeeze the nut and it will never seal.
    1600 is not bad if you don't want the headache. I suppose the prices have gone up in 10 years. A 50 gallon Bradford should cost between 800-900 at a supply house. Other parts (gas hose, flue vent, water connections) will be around $100. So DIY or spend $600 on a plumber.
    bmf4069 and onesojourner like this.
  17. Jul 8, 2021 at 8:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nobody pulls permits for them. Its surprising how quickly permits are required for plumbing. I never pulled permits unless I was doing a full trench sewer replacement. I did a lot of full replacements using the pull method and the liner method without permit.
  18. Jul 8, 2021 at 9:05 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I use mine the most for black widows and cockroaches
    bmf4069 and Darkness[QUOTED] like this.
  19. Jul 8, 2021 at 10:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    A few years ago one of our plumbers did just that. He was doing something under the sink and it caught fire later. I think he lit the insulation inadvertently or something.
    Darkness[QUOTED] likes this.
  20. Jul 8, 2021 at 10:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @FirstGenVol wait, don't replace it yet.
    I have an idea for a poll tomorrow...
    NUDRAT[OP], alee891, Darkness and 2 others like this.
  21. Jul 8, 2021 at 11:09 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Insulation goes up fast. I was working with a guy who lit the insulation in a garage. Hes lucky I had buckets of water and poured one on it. I pulled the wet insulation out after.
  22. Jul 8, 2021 at 6:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pictures never do it justice... just after a rain. That sweet, wet, earthy smell in the air. Lingering, calling to me... "Noah, go forth. Leave the shackles of the modern world behind. Return to nature, from whence ye came..."
    20210708_201626.jpg 20210708_201447.jpg 20210708_201441.jpg 20210708_201435.jpg
    Darkness, chrisb, bmf4069 and 3 others like this.
  23. Jul 8, 2021 at 6:59 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    There are plenty of studies that prove it's worth. Life goals.
    chrisb and Tundra2[QUOTED] like this.
  24. Jul 8, 2021 at 7:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Got a 3rd gen 4runner frame now…. So begins another project
  25. Jul 8, 2021 at 8:31 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What kind of project?
    Darkness likes this.
  26. Jul 8, 2021 at 8:34 PM
    empty_lord
    05 rollover special
    Find a 4runner for dirt cheap. Throw it together and my uncles buying it off me. He wants a smaller suv for camping. 3rd gen runner fits the bill
  27. Jul 8, 2021 at 8:39 PM
    FrenchToasty
    Mo
    Bone stock
    The 3rd gens are the perfect trail size rig
  28. Jul 8, 2021 at 8:43 PM
    empty_lord
    05 rollover special
    Yup. And it’ll be a “beater” that he won’t be as afraid to get messed up.
  29. Jul 8, 2021 at 10:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Do y'all know what camel pants are? :devil:
    Pretty sure @AzureNightmare might know this one, but I'm 100% positive he'll enjoy it.
  30. Jul 8, 2021 at 11:30 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Like high waters?
