  1. Jun 25, 2021 at 3:32 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Should let @Tundra2 know about said she shed. Looks like an upgrade from his current target home. Maybe if he tows it home he can save on moving costs? :D J/K
  2. Jun 25, 2021 at 3:42 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    CB69AC2A-73BC-4F56-AE46-63A6571D93C4.jpg 3C5BFAD2-302E-4EAD-867D-01C9049A7229.jpg Tundra on call, nothing to exciting but a float switch tripped on a roll around portacool, emptied it and got the dude another one. But there was a cute cat hunting something in this bush…
  3. Jun 25, 2021 at 5:15 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    That oil pressure gauge is not supposed to be there while cruising right?
  4. Jun 25, 2021 at 5:35 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Looks about right for idle after warmup.
    FrenchToasty likes this.
  5. Jun 25, 2021 at 6:21 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    It's possible and very common on many vehicles. I would recommend getting a mechanical gauge or borrowing one and verifying your actual oil pressure before throwing parts and $$$ at the issue. If a mechanical gauge verifies your oil pressure is within spec then your issue is somewhere downstream (i.e. oil pressure sending unit or faulty gauge). Probably oil pressure sending unit. Verify first. And if it turns out to be the sending unit I would strongly encourage you to go oem part. Aftermarket ones are notoriously cheap and don't last long and you're right back where you started.
    chrisb and NUDRAT[OP] like this.
  6. Jun 25, 2021 at 7:20 PM
    Jack McCarthy
    Bill
    North of Boston
    Not unusual. Mine does that as well.
    onesojourner and Desert Dog like this.
  7. Jun 25, 2021 at 8:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not bad. Not black, but not bad.
    And they got straight to the point didn't they?
  8. Jun 25, 2021 at 8:05 PM
    FrenchToasty
    Mo
    Bone stock
    Nice rack, looks good n tite to the roof
  9. Jun 25, 2021 at 8:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I didn't even see the rack...
  10. Jun 25, 2021 at 8:22 PM
    FrenchToasty
    Mo
    Bone stock
    Exactly, that’s what I dig about it. I’m building a rack of some sort for the camper so I’m eye balling all kinds of stuff
  11. Jun 25, 2021 at 8:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Can't wait to see what you come up with.
  12. Jun 25, 2021 at 8:30 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    The racks normally the first thing I notice...
    chrisb, RUSTYNUTS, bmf4069 and 5 others like this.
  13. Jun 25, 2021 at 8:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm looking further south.
  14. Jun 25, 2021 at 8:55 PM
    Desert Dog
    Same here. I've had at least half a dozen vehicles over the years that do it. The gauges in these aren't precision instruments. I've even had a couple oil pressure sending units that simply had corrosion on the electrical contacts that I cleaned up with emory cloth and reamed out the hole filled with semi-hardened oil with a pipe cleaner and brought them back to life.
    wandering_boy likes this.
  15. Jun 25, 2021 at 8:55 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Nekked racks are the best cause I don’t like to see em with a bunch of stuff on them
  16. Jun 25, 2021 at 9:36 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    This Gobi evokes a bit of an RV roof access / sundeck sort of feel. Mounts below the fiberglass & the 'legs' serve as roof access ladder. Subtle is good, but sometimes purposeful is discreet too. ...and who doesn't want a sundeck?
  17. Jun 26, 2021 at 3:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need a favor from someone willing to suck, and blow.
    Remove your vacuum tube from the engine to the brake booster. Tell me which way the check valve works. I made a boo-boo when I replaced that line, and forgot to check.
    I tracked down a check valve to install, but I'm not 100% sure which way it's supposed to be.
    Based on thought experiments, I think air should flow from the engine side to the booster side. NOT flow from the booster to the engine side. (Maybe I've got that backwards...)
    Just asking someone to double check..the only reason I thought to check this was when I was replacing dad's trucks vacuum lines.
    I'll be eternally grateful.
  18. Jun 26, 2021 at 3:44 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The way you're thinking is the correct way.
    Tundra2[QUOTED] and NUDRAT[OP] like this.
  19. Jun 26, 2021 at 7:35 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    A legendary first gen tundra. Someone who wished they bought a legendary first gen. Then me. Camping in Ponca.
  20. Jun 26, 2021 at 7:37 AM
    Ponca rules
    onesojourner likes this.
  21. Jun 26, 2021 at 7:42 AM
    FrenchToasty
    Mo
    Bone stock
    There was a group of newer tacos hanging out in a parking lot, younger males, all of them almost broke their neck trying to look at the truck they wished theirs was as I drove by. Haha it was great
    bmf4069 and onesojourner[QUOTED] like this.
  22. Jun 26, 2021 at 10:17 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    207018641_10159205348225275_314060329840_835769a24e767b115d04857391a9fac537a83057.jpg
    worked so good i had to make sure it wasnt beer goggles.
    these are 20lbs ea.
    My sundolphin aruba 10 is 40lbs.
    My old town angler 10 is 60 lbs.
    I know what id prefer to carry up and down the steps.
    my angler, because it sits a little lower in the water and you have more control.
    These arent bad, if theres too much air in the bottom bag they’re a little wobbly, and i dont completely trust the skeg. Seems like it’ll get knocked off easy. But a soild 7/10.
    13235467_10154110986580275_5616811723835_1ca0352748e456437c9411f3fc25dd5d22fd6cad.jpg
    208259254_10159207610955275_213248202273_151d1dbf8249daf00a280246aa26e4132b1d38a4.jpg
    its possible to get it back in the bag, but id rather have a longer bag it wouldnt have to fold as much. And could break the oar in half, instead of quarters. It didnt plane like the plastic ones, and heading up current was quicker to try to turn you around. Also, too much air in the bottom makes it unstable. Needs a plastic nose tip and bottom.
  23. Jun 26, 2021 at 1:16 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    The SHOs require fuel.
    My 91 and gf's 15. We met up to grab lunch and both needed gas.
    On the way home mine started overheating and my oil light went on and off a few times. Sigh.
    TRDGen, Sirfive and Jack McCarthy like this.
  24. Jun 26, 2021 at 1:16 PM
    That sexy Yamaha V6 is giving you issues?
    bmf4069 likes this.
  25. Jun 26, 2021 at 1:17 PM
    FrenchToasty
    Mo
    Bone stock
    Is the black one a SHO(whatever that means?) last Ford I owned was a 85 150 with a straight 6.
  26. Jun 26, 2021 at 1:19 PM
    Jack McCarthy
    Bill
    North of Boston
    I'll never understand the love for an SHO. Had a work friend who was a fanatic himself. My guess is he probably still owns his 1995 model.
    Must be one of those things you don't understand until you drive one.
  27. Jun 26, 2021 at 1:24 PM
    It's a 90's American M5. Sort of.
    bmf4069 and Darkness like this.
  28. Jun 26, 2021 at 1:24 PM
    Or like a scat pack Charger. You could buy one as a "family car" even though it was really a hot rod. Of sorts.
  29. Jun 26, 2021 at 1:26 PM
    Jack McCarthy
    Bill
    North of Boston
    I need to find a way to take pics at a seconds notice during a drive-by on the highway. Saw a smart car with flames painted on the side today that really made me laugh. :D
    chrisb and alee891 like this.
  30. Jun 26, 2021 at 1:27 PM
    Jack McCarthy
    Bill
    North of Boston
    It's kind of hard to give it a serious look myself because I always think of a taurus wagon which nobody wanted to ride in back at that time.
