  1. May 15, 2021 at 10:37 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s nice to have those skills since a Toyota Service Manager once told me to fix a squeak in my dash, his guys could tear a dash apart to fix it but it would never go back together correctly.
  2. May 15, 2021 at 10:47 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Just start taking out every screw and 10mm you can find. It comes out with relative ease.
  3. May 15, 2021 at 10:52 AM
    Sunnier
    Sunny
    San Diego, CA
    Alright then. I’ll fake me way forward (as usual)! It’s worked so far. :cool:
  4. May 15, 2021 at 11:15 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Realistically there are fasteners behind the glove box, radio, knee bolster and console (if you have one). I would also suggest removing the steering column shroud and A-pillars.
    After that, it’s just clips and a balancing act. Also helps to have 4 hands.
    NUDRAT[OP] and Sunnier[QUOTED] like this.
  5. May 15, 2021 at 11:54 AM
    Sunnier
    Sunny
    San Diego, CA
    Thanks. As usual, I ran into a different obstacle and will continue rocking the hand held for the foreseeable future.
  6. May 15, 2021 at 12:57 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Are you advocating for violence?
  7. May 15, 2021 at 1:35 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Drove by something that has been near and dear to my heart since Gran Turismo 1
  8. May 15, 2021 at 1:55 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I wanna run on that sooooo bad.
  9. May 15, 2021 at 2:09 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Same here but I'm driving the Element, no way I could handle the cork screw in this. Would be sweet on a bike!
    bmf4069[QUOTED] likes this.
  10. May 15, 2021 at 2:11 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Drove a 2018 F350 at work today...
    bmf4069, NUDRAT[OP] and BubbaW like this.
  11. May 15, 2021 at 2:11 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I used an adapter harness to grab power/ground/etc at the dash for my radio (toyota 86 also).
    I bought an adapter harness that fit the OEM amp and ran 14ga wires back to the OEM amp plugs, along the center console hump to under my rear pass seat, to bypass the amp and use the onboard 86 amp.
    You could also buy crutchfields harness for the 05/06 access cab. They seem to be the only one that carries the correct one. https://www.crutchfield.com/S-Pl6VHSXKU6q/p_120708121/Metra-70-8121-Amp-Bypass-Harness.html
    Here's the part #'s I saved.
    70-8113 radio
    70-8121 amp bypass
    These may fit but have to be extended. I bought the ty3 and extended it.
    AXABH-TY3
    AXABH-TY4
    AX-AB-LX3
    AXABH-LX3
    Totally worth the effort. The OEM amp is anemic at best, stock speakers and the 86 radio onboard amp is a huge difference.
    NUDRAT[OP] and chrisb[QUOTED] like this.
  12. May 15, 2021 at 2:14 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    bmf4069 likes this.
  13. May 15, 2021 at 2:52 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Stereo in and 100% functional.
    Carpet cleaner, but not 100% clean. Same with the carpet mats. Need to replace those bishes with some WeatherTech boiz.
    Front seats, plastic trims, and center console yet to clean and reinstall.91D932F5-B75F-494D-81A5-50B6B105301E.jpgD52F85A7-1AD7-4E00-A319-464D2A82956C.jpg
    bmf4069, NUDRAT[OP], Glock 40 and 4 others like this.
  14. May 15, 2021 at 2:57 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    They were modified with pumps and vents. It would be a good way to get a lot of safe storage fro cheap. I won't be testing this but people have claimed t
    The average life span of travel trailers and rvs is 10 to 15 years. Other than storing your fuel they also grow black mold like nothing else.
  15. May 15, 2021 at 3:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] Aluminum covers came in. Now to order the gaskets and have these powder coated satin black.
  16. May 15, 2021 at 3:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    what's the gauge right of fuel :confused:
  17. May 15, 2021 at 3:39 PM
    empty_lord
    05 rollover special
    Trans temp
  18. May 15, 2021 at 3:48 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Check engine light is on of course
  19. May 15, 2021 at 3:56 PM
    Professional Hand Model
    Hand Protectors
    bmf4069, FrenchToasty and Darkness like this.
  20. May 15, 2021 at 6:03 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  21. May 15, 2021 at 6:35 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    And SRS light at 33k
    Darkness[QUOTED] and KarmaKannon like this.
  22. May 15, 2021 at 7:08 PM
    Wsidr1
    Wsidr1 New Member
    Bret
    Tacoma x 2
    @FirstGenVol
    I worked in this area of the plant during 1st gen production. I hope this boosts your confidence. The 1st gen Tundra instrument panel was not a modular unit. Meaning, it was assembled inside the truck. The assembly sequence went something like this, start to finish: A/B ECU; main wire harness to cowl(firewall); parking brake, AC, htr blower; brake pedal; IP reinforcement (large round bar supporting weight).
    There were very few parts attached to the IP skin(dash) before the skin was installed into the truck. This makes partial dis-assembly easier than the subsequent generations that were modular units. The passenger airbag, speakers, and a few misc parts were assembled to the skin before it was installed, but not much else. Removing lower console, lower IP, etc, then the skin and the rest is pretty straight forward.
    So, you should be able to dis-assemble it as far as you need and then stop.
    onesojourner and MS22 like this.
  23. May 15, 2021 at 8:59 PM
    Toyotalover713
    Toyotalover713 New Member
    2004 double cab tundra
    Light bar All led interior and exterior
    Has anybody found aftermarket headlight housings for 1st gen double cab models? I am having trouble finding any that fit. I preferably want black housing if anyone could I would appreciate it!!
  24. May 15, 2021 at 9:02 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Amazon and ebay have plenty. There are black options too
  25. May 15, 2021 at 9:26 PM
    Toyotalover713
    I tried a pair on Amazon and they didn’t fit correctly they said they did not fit the double cab but fit the crew cab model
  26. May 15, 2021 at 9:30 PM
    KarmaKannon
    Utah
    Some junk
    Get the ones for the double cab and they will fit the double cab.
    https://www.ebay.com/itm/203057735033
    You'd have to check the difference between 04 and 05/06 headlights, but I thought it was just the extra little marker light. Also the 04 sequoia might be the same headlight. I have an 06 so it's not something I've had to worry about.
    onesojourner and FrenchToasty like this.
  27. May 15, 2021 at 9:40 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    So I know this is going to be incredibly vague and like a total shot in the dark but I’ve had a few drinks and I’m gonna ask anyways.
    What kind of bolt on, resonator back, exhausts were available for our trucks?
    Reason being is that the parts truck had this exhaust on it that I just couldn’t bring myself to not keep. There are no markings, the muffler seems stainless, the tips are black and it honestly sounds really good.
    I’ll snap some pics tomorrow and maybe this will be easier to diagnose.
    KarmaKannon likes this.
  28. May 15, 2021 at 10:09 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    guest house / man cave / cigar bar. If you keep the roof water tight. :burp:
  29. May 15, 2021 at 10:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We talked about steering wheels?
    1,592... all scrap. (Minor defects like scratched leather, or something.)
  30. May 15, 2021 at 10:11 PM
    NUDRAT
    SW CT
    The wall was just sitting there. A car that drifts over the center line & hits you like that - it's coming at you, so...
    Darkness[QUOTED] likes this.
