  1. May 9, 2021 at 12:47 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Spare tire crank.
    My 2003 has a multi part tool you thumbscrew together. Annoying! When I had a flat I absolutely could not lower the spare with that tool.
    Is there a year that has a 1 part crank?
    For curiosity - I just took the 1-part crank tool from the 2002 Tacoma & tried it on the 2003 Tundra. It worked. And the crank worked - tire actually came down. Woot.
  2. May 9, 2021 at 12:50 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the regular cabs like mine are one piece
  3. May 9, 2021 at 12:50 PM
    empty_lord
    05 rollover special
    i just want to stick it on the bottom edge so the tool stops eating the paint.. in an effort to stop rust
  4. May 9, 2021 at 12:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Door edge protector may work.
  5. May 9, 2021 at 1:39 PM
    empty_lord
    05 rollover special
    Not easy enough to install down there. I did think of it. The rubber sheet metal edging shit should work fine.
  6. May 9, 2021 at 1:45 PM
    empty_lord
    05 rollover special
    Hmm before I forget, who’s got a recommendation for a storage box to put at the front of my bed, that’s still easy removable
  7. May 9, 2021 at 2:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    no want for a swing case?
  8. May 9, 2021 at 2:39 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I’m running two of these Plano boxes with a cargo bar holding them back. Two boxes fit wide with just enough room to open them up.
    Its nothing fancy but they look good vs regular plastic totes. The rubber pad is so I don’t kill my knees crawling back there.
    Storage is use for recovery gear and fluids mostly
    https://www.homedepot.com/p/Plano-68-qt-Sportsman-Trunk-Olive-Green-PLA068HD/312081519
    moving to this floor set up very soon, saw it at a truck meet. Save the knees
  9. May 9, 2021 at 3:25 PM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
  10. May 9, 2021 at 3:29 PM
    empty_lord
    05 rollover special
    that is perfect
    guess i'll be picking some of those up.
  11. May 9, 2021 at 3:30 PM
    empty_lord
    05 rollover special
  12. May 9, 2021 at 3:46 PM
    alee891
    Now/here
    Shitbox
    I run a single Plano ghetto-strapped with the full sized spare in the back.
  13. May 9, 2021 at 4:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I meant the automotive stuff. Meant to help prevent doors chipping when opening the door lol. Parts stores carried it, haven't looked for it for a while.
    ^ this type of stuff.
    https://www.ebay.com/itm/180-Long-B...ding-Trim-Protectors-Strip-15ft-/254162672825
  14. May 9, 2021 at 4:43 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Yeah I didn't want it to wash away in the rain and the paper that comes with the temp states you can put it in the back window or anywhere else on the rear of the vehicle. It was clearly visible and the guy was just being an ass.
    NUDRAT[QUOTED][OP] likes this.
  15. May 9, 2021 at 4:45 PM
    KarmaKannon
    Utah
    Some junk
    mcmaster has what you need. I use them to find a part and then try to find it cheaper somewhere else. Sometimes you can and sometimes you can't
    My knees need that stuff. Thanks for the idea!
  16. May 9, 2021 at 5:40 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Getting closer to getting the sequoia back, dropping the dirty deeds injectors off in the morning, and they start putting the ole girl back together 56439C82-7545-4D6A-BEA2-0B0232B26F10.jpg
  17. May 9, 2021 at 6:09 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Holy sheet! Went to pick up some 14/2 wire from the depot and its $40 now for 50ft! I bought 2 rolls off Amazon early last year for $19 a roll Screen Shot 2021-05-09 at 7.04.43 PM.jpg
  18. May 9, 2021 at 6:18 PM
    Professional Hand Model
    Hand Protectors
    Bought some UNtreated 2x4-8’ for.... $8 a stick the other day. Last year before Scary Hit it was avg. $2-2.50 a stick. Nuts!
    Saved those temporary 2x’s from that last job last month and glad I did because I was able to reuse them on the back porch Column Replace at the Govnas Plantation.
    2 Fiberglass Columns cost $700! plus another $150 in adhesives/fasteners. Getting out of Hand.
    bmf4069, GODZILLA and MS22[QUOTED] like this.
  19. May 9, 2021 at 6:20 PM
    Hand Protectors
  20. May 9, 2021 at 6:22 PM
    NUDRAT
    SW CT
    Govna's plantation too good for bondo? -35 whirled peas points for wasting wood.
    FirstGenVol, bmf4069, CodyP and 3 others like this.
  21. May 9, 2021 at 6:28 PM
    Hand Protectors
    Yeah. Well, we did feed the termites for a few years. Bondo releases toxins into the air and besides its not a permanent repair. Normally, I’d use a Structural Epoxy (super high dolla/permanent) for smaller repairs before it gets to bad. In this case, the $$$ said it was better to buy new.
  22. May 9, 2021 at 6:55 PM
    NUDRAT
    SW CT
    Bondo isn't intended to be structural so.... Only -25 points.
  23. May 9, 2021 at 6:56 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Another member posted that buys PVC buy the bulk and he said the prices have doubled if not tripled and in some cases suppliers dont even have it
    bmf4069, GODZILLA and NUDRAT[OP] like this.
  24. May 9, 2021 at 6:58 PM
    Hand Protectors
    Yeah. People are backing off from doing Projects from what I read here. Waiting until prices drop. :rofl:
  25. May 9, 2021 at 7:02 PM
    NUDRAT
    SW CT
    Honestly - I'm thinking the smart money is to sell my fixer as a fixer. Hop in the RV & hit the gubmint land w/ some internet. Work from home is a reality, work from RV on government land - same thing. Just trying to decide if hopping off the treadmill results in being left too far behind inflation.
  26. May 9, 2021 at 7:12 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Keep the house if it's affordable. Don't stay out of the market to long.
    Renting with a good property management company watching out may be a good way to go.
  27. May 9, 2021 at 7:18 PM
    18" TRD Off Road Wheels
    Real Estate is almost always going to outpace inflation. Keep the property, even if you just rent it out to pay for itself.
  28. May 9, 2021 at 7:29 PM
    KarmaKannon
    Utah
    Some junk
    Just be happy you could find it. The way things are going we might be seeing what less than first world nations experience. I'm hearing of places having a hard time competing with unemployment and stims for entry level to mid level skilled labor. If that's happening enough we'll have a lot of managers and your internet stays on, but getting produce and building supplies could be difficult. The prices... May change as well.
  29. May 9, 2021 at 7:36 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It's all super weird. Who would have thought that if you flood the market with cash that prices would go up. It's like the more free cash they give us the less it's worth. Weird.
    NUDRAT[OP], chrisb, bmf4069 and 4 others like this.
  30. May 9, 2021 at 7:41 PM
    KarmaKannon
    Utah
    Some junk
    They pretend to pay us and we pretend to work.
