  1. Apr 28, 2021 at 5:27 PM
    Professional Hand Model
    Hand Protectors
    Yeah. The Power Steering change is easily done since its all open. I had to draw the line as mine is still working and as its up higher than the Alternator ‘should’ be easier to replace. I’ll ride that one until either the rack fully blows or the pump goes. Hope to get a few more years!
    KNABORES and Voss[QUOTED] like this.
  2. Apr 28, 2021 at 5:29 PM
    Hand Protectors
    Not sure about an easy Alternator Upgrade thats plug and play @Voss. I’ve seen some decent ‘conversion’ mods, but those aren’t easy and I don’t need them so they get a pass.
  3. Apr 28, 2021 at 5:35 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Ill look into it but from what I remember reading, pretty sure the sequoia alternator bolts right on. If not then I’ll stick with original. Hasn’t let me down yet.
  4. Apr 28, 2021 at 5:37 PM
    Hand Protectors
    Your 2003 may be easier iirc for the Upgrade. Its been a while since studying it.
  5. Apr 28, 2021 at 5:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Unfortunately, all the cardboard in the building is either immediately crushed when no longer needed or in use.
    This made do. Only my calfs got wet. :)
  6. Apr 28, 2021 at 5:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wait that’s a thing? Shit. More junk for me to buy
  7. Apr 28, 2021 at 5:43 PM
    speedtre
    speedtre New Member
    Inland Northwest
    I'm pretty sure this is the one you want Denso part # 210-1066. 150 amp is the highest that will bolt in. You might consider doing the big 3 upgrade while your at it.
  8. Apr 28, 2021 at 5:46 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Expected life on these alternators is 200k or so? I think I will consider a preemptive replacement and upgrade to the big sequoia alternator when the next belt is do.
  9. Apr 28, 2021 at 5:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    NUDRAT[OP], bmf4069 and Voss[QUOTED] like this.
  10. Apr 28, 2021 at 5:48 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    @FirstGenVol
    What problem do these solve?
  11. Apr 28, 2021 at 5:49 PM
    Hand Protectors
    Some report longer mileage. My Mojo Radar was tingling on mine (171k) so I planned it in on the TB Job. Cracked open the Alt and the bushings were down to the warning nubs. I also measured them and they were under spec per the FSM. Pics got erased so they are somewhere back on page 600 here.
  12. Apr 28, 2021 at 5:51 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Yeah I think I remember reading it at the time.
    Next question, If a truck regularly uses 90 amps. Would a 150 amp alternator last longer than a 100 amp alternator? They both would do the job but the big one would be stressed less?
  13. Apr 28, 2021 at 6:03 PM
    Voss
    2003 AC TRD 4x4
    Thanks! What’s the “Big 3”?... asking for a friend
    FrenchToasty likes this.
  14. Apr 28, 2021 at 6:04 PM
    Hand Protectors
    I’m not a scientist, but the way I see it is the Voltage Regulator determines whats needed and when. My truck will not demand more than how it was designed. I’ve not added extra demand so no extra stress. Actually, I’ve lowered demand with all the LED Bulbs and new fine tuned engine components.
    To try to answer your question, the Upgrade is good for those that add demanding components. How much longer the Upgraded Alt lasts is hard to determine. Might not last as long or could last longer in a regular system. The Upgrade will handle extra demand systems better and last longer than an undersized one in the same extra demand system.
    Voss and onesojourner[QUOTED] like this.
  15. Apr 28, 2021 at 6:09 PM
    speedtre
    speedtre New Member
    Inland Northwest
    You can buy kits or make one yourself...but pass on Aluminum and go all copper...
    https://youtu.be/syOD6SUk9RI
  16. Apr 28, 2021 at 6:14 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    So the shop that’s doing my head gasket job for the sequoia brought up doing the timing belt since everything is gonna be apart. It was done at the most 5k ago. Somebody talk me out of re-using the belt? The only catch I can see is them not wanting to warranty the timing belt and stuff if it was to cause issues
  17. Apr 28, 2021 at 6:18 PM
    Hand Protectors
    Whats the total TB kit cost? Like $160 for Aisin? Sounds like a cheap deal if thats going to give you warranty. Sucks, but listen to them. Just the belt is like $65? Stop being a cheap bastid!:D
    NUDRAT[OP], Voss and NWPirate like this.
  18. Apr 28, 2021 at 6:42 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why would you replace a belt with only 5k miles on it? Seems like a waste of money.
    jerryallday likes this.
  19. Apr 28, 2021 at 6:43 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I posted a pic on the previous page. Apparently the metal is known to crack in that area. I've never heard of it but apparently it's happened to a lot of people.
    See below
    bmf4069 and onesojourner[QUOTED] like this.
  20. Apr 28, 2021 at 6:49 PM
    Voss
    2003 AC TRD 4x4
    Just make sure they use an OEM Toyota belt.
    Edit: probably best you take them the parts cause... life happens sometimes
  21. Apr 28, 2021 at 7:12 PM
    Voss
    2003 AC TRD 4x4
    Not long ago I asked the stealer how much new battery wires were and the price was ridiculous. If someone were to do the “big 3”, what would you use for this upgrade?
  22. Apr 28, 2021 at 8:11 PM
    Voss
    2003 AC TRD 4x4
    Think has something to do with warranty on the work that’s being done
  23. Apr 28, 2021 at 8:59 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    for the HD versions? Really? crap. That's not something I wanna hear. He did say the standard versions 3/1 were stock height but that the HD versions give about 1.5" of lift due to more payload capability
  24. Apr 28, 2021 at 9:03 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I paid the below at Longo Toyota in January. I always buy online and pick up in store.
    2006 double cab
    Part Number Part Name Price Quantity Total
    43330-39825 Lower Ball Joint $121.57
    43340-39595 Lower Ball Joint $121.57
    Subtotal: $243.14
    Local Pickup: Free
    Tax: $24.32
    Total: $267.46
  25. Apr 28, 2021 at 9:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Unsure if the double cab LBJs are different or not, but here was my order from cool springs last July.
    43330-39466 Lower Ball Joint $87.26
    43340-39356 Lower Ball Joint $87.26
    Installed in December.
    Part numbers are slightly different.
    Voss and Professional Hand Model like this.
  26. Apr 28, 2021 at 9:44 PM
    empty_lord
    05 rollover special
    If it’s apart. Do the belt. REQUEST OEM.
    Best time to do the water pump to
    Why risk serious engine damage from the old belt snapping?
  27. Apr 28, 2021 at 9:44 PM
    empty_lord
    05 rollover special
    05-06 have beefier ball joints. Some 04s. Other than that all the others are the same
    FrenchToasty and Tundra2[QUOTED] like this.
  28. Apr 28, 2021 at 9:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh. Spindle changed too? Just the ball joint?
  29. Apr 28, 2021 at 10:43 PM
    empty_lord
    05 rollover special
    spindle. lower control arm and joint
    Darkness likes this.
  30. Apr 28, 2021 at 11:02 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    There's a lot going in here. Condolences on your dog. I hope all goes well with the new pup.
