  1. Mar 29, 2021 at 3:45 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Got a link? I must be using a cheap magnetic one someone gave me. No silicon inside.
  2. Mar 29, 2021 at 3:53 PM
    Professional Hand Model
    Hand Protectors
    Duralast Autozoned about $15 a few years ago.
    Even has hatching grip on the shaft for Hand Threading.
  3. Mar 29, 2021 at 5:30 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    i ended up at autozone and got this one, except mine is rubber / silicone free.
    Ran out of time to attempt to use it, will go for it tomorrow.
    Picked up 4qts valvoline 80w-90 gear oil, plan on doing that as well
  4. Mar 29, 2021 at 6:20 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    MAY finally have a lead on a 2020 86 radio. If soC CARPLAY, HERE I COME!
    Darkness, chrisb, KarmaKannon and 2 others like this.
  5. Mar 30, 2021 at 12:31 AM
    empty_lord
    05 rollover special
  6. Mar 30, 2021 at 1:20 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
  7. Mar 30, 2021 at 4:25 AM
    Hand Protectors
    empty_lord[QUOTED] and Darkness like this.
  8. Mar 30, 2021 at 5:03 AM
    Jack McCarthy
    Bill
    North of Boston
    This gives me ideas for a new clearcoat...
    The LIDAR solution would have to be some sort of LED bar in the front.
  9. Mar 30, 2021 at 6:15 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What color Loctite do you guys keep around for suspension work? LBJ bolts for example.
    NUDRAT[OP] and jerryallday like this.
  10. Mar 30, 2021 at 6:31 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I go blue
    NUDRAT[OP] and Darkness like this.
  11. Mar 30, 2021 at 6:45 AM
    shifty` Inside his chest they found ten thousand pencils
    Make this a 2nd vote for blue. I keep both the liquid and the stick around. I don't like using more aggressive stuff like red on anything. Blue is similar to painting things shut and actually helps prevent bolt freezing due to corrosion bonding.
  12. Mar 30, 2021 at 7:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Mar 30, 2021 at 7:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Blue x3, red only if you want to torch things.
    Darkness likes this.
  14. Mar 30, 2021 at 7:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It is impossible for me to listen to that man's voice for more than a few minutes. I feel for the owner of that truck but it's clear he didn't check the frame when he bought it and he didn't do anything to protect it further. He's SOL.
    KarmaKannon, NWPirate, CodyP and 3 others like this.
  15. Mar 30, 2021 at 7:39 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    That guys voice is big cringe. If he wants to be such a smart aleck to go bashing Toyota for salty roads maybe you should have looked at the frame before you bought it.
  16. Mar 30, 2021 at 7:41 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    By the way I am looking at getting the ICON progressive add a leaf. Anyone have trouble with these or do you like them? @empty_lord
  17. Mar 30, 2021 at 7:42 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I'm not bothered by Scotty's voice, and his content is typically spot-on correct.
    As for the Tundra in question, it sounds like a dealer told the owner the frame had been coated and there was nothing to worry about. Maybe the dealer coated over rust, thus making it worse.
  18. Mar 30, 2021 at 7:47 AM
    Casper421
    In the woods
    06 DC
    @FirstGenVol
  19. Mar 30, 2021 at 7:58 AM
    18" TRD Off Road Wheels
    You mean I'm not the only one who can't stand Scotty videos? :eek::eek2: I don't care how good (or bad) the info is, if it's presentation is insufferable I'm out. I automatically close and thumbs down robo-reader videos too. Maybe I'm just a jerk. :notsure:
    Pucks18 and chrisb like this.
  20. Mar 30, 2021 at 8:01 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wouldn't recommend these. If you are hell-bent on going the AAL route, go with Wheelers. They seem to have better reviews. I followed ICON's instructions, removed the overload spring, and got ZERO lift. It did help it ride slightly better though. If I had known this, I would have just spent more to replace my leaf packs.
    Darkness and speedtre like this.
  21. Mar 30, 2021 at 8:12 AM
    FrenchToasty
    Mo
    Bone stock
    I had to laugh when I watched his dielectric grease video, adding half a tube inside of a connection and telling people it helps conduct electricity.......
  22. Mar 30, 2021 at 8:37 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    NUDRAT[OP] likes this.
  23. Mar 30, 2021 at 10:23 AM
    Richid
    Richid New Member
    Check out orange instead.
    I used red on mine, but orange is different than blue or red (I know, duh). It maintains it's hold as the bolt loosens, whereas blue/red only prevent break-free. It also does not require heat to remove, like blue.
  24. Mar 30, 2021 at 11:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  25. Mar 30, 2021 at 1:21 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    PHM Hand Threading?!?!? Does your agent know you’re being frivolous with your money makers?
  26. Mar 30, 2021 at 1:24 PM
    Hand Protectors
    Gloves are always in the contract.
    NUDRAT[OP] and CodyP[QUOTED] like this.
  27. Mar 30, 2021 at 3:26 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
  28. Mar 30, 2021 at 3:31 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @shifty` since we were talking about little euro cars, check out this little thing. @chrisb you might like it too. These run the VW/Audi 1.8T motor but it's the size and weight of a Polo.
    shifty` and chrisb like this.
  29. Mar 30, 2021 at 3:35 PM
    Jack McCarthy
    Bill
    North of Boston
    Not necessarily. The way that tundra is rusting at the bottom of the frame rail is similar to mine where it’s most likely rusting from the inside out.
    They spray a wax like coating inside but all it seems to do is trap moisture and accelerate the process.
  30. Mar 30, 2021 at 3:37 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
