  1. Mar 26, 2021 at 1:03 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Ugh. Those Edge kids are the worst.
    Same. Kelly was showing me our realtor's new house and my first takeaway was, "WHY IS IT SO CLOSE TO THE NEIGHBORS??!" (~3100 sqft on probably on 2 acre lots)
    Ideal minimum distance between neighbors is close enough to tell if it's a bonfire or a structure fire, but far enough to not smell it.
    RUSTYNUTS, NUDRAT[OP] and lsaami like this.
  2. Mar 26, 2021 at 1:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    lol we have half acre here.. defiantly too close. id prefer 10-15 acres at least
    FrenchToasty and chrisb[QUOTED] like this.
  3. Mar 26, 2021 at 1:05 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Exact same.
  4. Mar 26, 2021 at 1:11 PM
    18" TRD Off Road Wheels
    If I can't go outside and pee off my porch, the neighbors are too close.
    NUDRAT[OP], NWPirate, lsaami and 2 others like this.
  5. Mar 26, 2021 at 1:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Theyre about to retire, early but still retirement age. If it was younger people I wouldn't be so surprised.
  6. Mar 26, 2021 at 3:34 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    The bumper color is, drumroll please....
    Medium Quartz grey. here goes nothing. And by nothing, I mean 315 bucks.
  7. Mar 26, 2021 at 4:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @KarmaKannon and others with a fiberglass camper shell, what made you want a glass shell vs a soft topper or something of the likes?
    I’ve found a snug top local for cheap that needs a little work but not sure if I should wait and just get a soft topper?
    des2mtn likes this.
  8. Mar 26, 2021 at 4:40 PM
    empty_lord
    05 rollover special
    Soft shell around here is asking for a knife to be taken to it. Plus they don’t make one for my 8ft bed. Hard shell is nice. And eventually I’ll add a roof rack to it, the other bonus
  9. Mar 26, 2021 at 5:14 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    LMFAO your funny man :rofl:
  10. Mar 26, 2021 at 5:35 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You're having someone spray it?
  11. Mar 26, 2021 at 6:41 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Same as what @empty_lord stated about the knife and possibility of mounting things to the shell plus I want to armor up my windows and doors to make it even harder to break in. I like the way the soft toppers look though and opening the sides would be great for the desert. Fading of the canvas would also piss me off.
  12. Mar 26, 2021 at 6:46 PM
    FrenchToasty
    Mo
    Bone stock
    Is your shell set up for mounting things, or it’s not a big deal to drill and mount rails and what not?
    I’m basically looking for one, for the same reason you mentioned; if we want to go camping with the fam and bring the dogs, it’s not happening safely. When we do bring them in the 4runner it’s very cramped and LOADED. So this would free up a lot of space, haha might HAVE to upgrade the rear springs after if it sags.
    The one I found is a snug top but needs new window and locks so I could upgrade maybe to a windoor? But it’s cheap enough, it’s hard to pass up......
  13. Mar 26, 2021 at 7:31 PM
    KarmaKannon
    Utah
    Some junk
    Shouldn't be an issue to drill and bolt some mounts. I've seen some different options and I don't know exactly what I'd do. My most likely thing to mount would be an awning. The tepui ones were cheap last time I had our sales guy at work check and they can be mounted with a simple L bracket. When I worked for a shell place it seemed like most windows could be traded out for windoors. Another option is putting some aluminum sheet in place of the glass.
    Luckily for me I found a shell with the nice frameless back window. The issue is that it complicates things if I want to change the glass out for some aluminum. Still possible though. Not like I can see anything out of the shell anyway. Something like 5% tint on the back truck window with whatever is on the back shell window makes it look solid.
    My she'll is also nice and skirted in the sides. It looks nicer, but mounting a rack to the bed and throwing the shell on top of the mounts means I have to cut the skirt.
  14. Mar 26, 2021 at 7:44 PM
    empty_lord
    05 rollover special
    i plan on building a "cage" to better handle weight whenever i decide to do the rack
  15. Mar 26, 2021 at 8:17 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I get to sleep in my cap tonight and I'm so excited
  16. Mar 26, 2021 at 8:19 PM
    FrenchToasty
    Mo
    Bone stock
    PB&Jellous! I will probably build some sort of sleeper for me and the boys, maybe retrofit a decked system one day.
  17. Mar 26, 2021 at 8:32 PM
    des2mtn
    SW
    Tonto cover
    I'll have to take more pictures of my box for you and share some ideas. I can't tell you how much use I get out of it.
    I wouldn't ever consider a soft topper personally because of the desert wind. I'm very biased though because I've been camping in this cap for over 10 years now.
    KarmaKannon and FrenchToasty like this.
  18. Mar 26, 2021 at 8:52 PM
    FrenchToasty
    Mo
    Bone stock
    We’re having a windy mindy kinda night down in southern az tonight, and wind while camping out outdoors always sucks and makes things miserable usually. Thanks for the wind input aspect of caps.
  19. Mar 26, 2021 at 9:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The boss says its time to fix this. Enough of the val and the hair algae farm.
    Starting over.
    Here we are.
    MNtundra, Lil Steve, speedtre and 5 others like this.
  20. Mar 27, 2021 at 4:35 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Growing up Edge, (still here, still here, after all these forking years...where did you go?) everyone Edge is an Edge Kid.
    Same goes for punk kids and hardcore kids.
    Makes no difference to me if you're 18 or 58. If you're Edge, you're an Edge Kid.
    Jeebus, if there are Edge Kids old enough to retire....that means I'm getting old.
    I call BS.
  21. Mar 27, 2021 at 5:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    There are only a few downsides to a fiberglass camper shell IMO.
    1) decreased visibility, which can be helped with a back up camera.
    2) it becomes harder to use the bed as it was intended. I had to switch to bagged mulch instead of having them fill my bed with a bobcat. If we didn't have 2 dogs I would get a diamondback tonneau and mount a RTT on that. I still think the camper shell was one of the most useful things I've added to my truck. I put some dog beds back there and open the front window, they love it. One dog goes to sleep and our crazy husky stands there for 8 hours feeling the breeze.
  22. Mar 27, 2021 at 6:21 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I came here to say this. In fact I would go as far as to say that a good amount of our society problems would be non issues with a bit more space.
    Darkness and KarmaKannon like this.
  23. Mar 27, 2021 at 6:23 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    A soft topper is disposable. A fiberglass topper is a lifetime purchase. Do you want a 4runner or a kia?
  24. Mar 27, 2021 at 8:34 AM
    Professional Hand Model
    Hand Protectors
    Gonna crawl under and try to tap out some Exhaust Pipe Bolts at the Y-Pipe. Last week tried the Spyder Andersen Slot Punch Technique like performed with KO Powa on the o2 Sensors, but got rejected by Bruce Lee Invisible Force Field Technique.
    speedtre, Darkness, chrisb and 3 others like this.
  25. Mar 27, 2021 at 11:33 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    nope. Monstaliner is designed to roll on. I’m going to do the bumper, my sliders, and the bed all at once myself, once the weather gets warmer.
  26. Mar 27, 2021 at 2:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My wife got me this cheap creeper for Christmas and I love it. So much better than crawling around on my back.
    chrisb, speedtre, MS22 and 7 others like this.
  27. Mar 27, 2021 at 3:10 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I looked at that one before. I read the wheels break off from some reviews though, so be aware.
    I, myself, just decided to upgrade the wheels on my craftsman creeper than buying a new one.
  28. Mar 27, 2021 at 3:15 PM
    FrenchToasty
    Mo
    Bone stock
    Ventilation is very important!!!! That shit is super strong!!!! I’ve done the plastic bumper on our 4runner bashed it and dragged down rocks, it just cracked it where the plastic folded!
    Last spring I did my bed, fender flares and bumper, it’s good stuff but like any painting, prep is KING!!
  29. Mar 27, 2021 at 3:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Oh I know this one isn't high quality. If it breaks I'll invest in a better one.
  30. Mar 27, 2021 at 5:31 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    For those of you who have swapped in the Baja designs in your fogs, did you run them to their on switch or splice them into you oem fog light controls?
