  1. Mar 15, 2021 at 8:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This.
    Batteries may also give wrong power which could reduce the life of high dolla items.
  2. Mar 15, 2021 at 9:04 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    To be the dissenting opinion I use (mostly) two 4ah batteries for all my tools. Unless your working construction the two you have should be sufficient.
    Only change I'd suggest would be the brushless compact saw if you can spend a little more.
  3. Mar 15, 2021 at 9:08 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Tenants called me. Faucet downstairs won't shut off, so he turned the angle stop and that won't shut off either. Now I have to replace all the angle stops in the condo.
    Shitty part is, we have to turn water off to the whole complex.
    chrisb and onesojourner like this.
  4. Mar 15, 2021 at 9:15 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Speaking of plumbing, my only wisdom is to buy plastic toilet seats as a replacement to the original when it breaks. The wood ones stain too easily unless you’re anal about cleaning the underside from splatter when taking a dump.
    chrisb likes this.
  5. Mar 15, 2021 at 9:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    chrisb and Jack McCarthy[QUOTED] like this.
  6. Mar 15, 2021 at 9:32 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Centoco makes a wood seat with a plastic shell. Best of both.
  7. Mar 15, 2021 at 9:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  8. Mar 15, 2021 at 9:41 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  9. Mar 15, 2021 at 9:48 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    On car gurus there are 14 2004 or newer 4runners with over 300k miles. There are no Kias with over 300k.
    chrisb and FrenchToasty like this.
  10. Mar 15, 2021 at 9:52 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    speedtre likes this.
  11. Mar 15, 2021 at 10:01 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I hate the brushless grinder cordless from Milwaukee, the brake on the drive is absolutely annoying; constantly seems like something is binding. I’ve ran it with no load and it just changes pitch for no reason like it’s hanging up on itself
  12. Mar 15, 2021 at 10:17 AM
    Professional Hand Model
    Hand Protectors
    Find the Main Vein (coming into your place) and slip a Shark Bite Shut Off on it. Now you’ll be able to sit back and drink beer and collect checks while doing the other valves in question. :rolleyes:
    FrenchToasty likes this.
  13. Mar 15, 2021 at 11:05 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I’ve gotta say, I feel like y’all reaaaaally undersold how sweet a new steering shaft seal is.
    Figured I’d go ahead and replace that since it was easy to get to, with half the truck being torn apart and all.
  14. Mar 15, 2021 at 11:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Oh no you didn't! :)I talked about it several times!!
  15. Mar 15, 2021 at 11:33 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    It’s unbelievable how much more quiet it is in the cab. I was shocked.
    Jack McCarthy likes this.
  16. Mar 15, 2021 at 11:55 AM
    Jack McCarthy
    Bill
    North of Boston
    You probably wouldn’t do it if your coupler looked like mine....and this was 9 years ago.
  17. Mar 15, 2021 at 12:27 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    NUDRAT[OP], CodyP, Lil Steve and 3 others like this.
  18. Mar 15, 2021 at 12:48 PM
    Hand Protectors
    That draft up the skirt feel better now? :rofl:
    Squeeze some Sylglide on the Topside of your new shaft seal (peel back carpet/fill in seal folds) and really hear how much more quiet it gets. I did this a few months back and I guess it slipped the radar with everyone. SUPER QUIET! :thumbsup:
  19. Mar 15, 2021 at 12:57 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I read bits about this but I had not seen it mentioned with double cab people. Tell me more?
  20. Mar 15, 2021 at 12:59 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    That is good to know I will avoid that one.
  21. Mar 15, 2021 at 1:12 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I think it’s so good, they’ve actually stickied it at the top of the forum. I just figured that it couldn’t make that big of a difference.
    Boy was I wrong.
  22. Mar 15, 2021 at 5:14 PM
    FrenchToasty
    Mo
    Bone stock
    They used to call me Bubble Trouble!(again just a self proclaimed Alias)
    pressure tested my welds on the resonators, one side had nothing, the metal stretching side needed a few go backs to the welding table.
    O2 extensions came in today as well.
    Started kroil spraying and starting to organize tools for weds; still need to find a long 3/8 ratchet extension. Pretty stoked, kinda nervous
    chrisb, Lil Steve, NUDRAT[OP] and 4 others like this.
  23. Mar 15, 2021 at 5:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You need a wobble end, or a straight extension?
    Lowe's has those locking extensions. A set of em is like 25 bucks. Not sure how long you need?
    Harbor freight has some 2 foot dudes.
    Lil Steve and FrenchToasty like this.
  24. Mar 15, 2021 at 5:22 PM
    FrenchToasty
    Mo
    Bone stock
    I have a shorter wobble, but I do need a long dude for sure, that will be my mission tomorrow
  25. Mar 15, 2021 at 5:31 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Can someone with a BFF front bumper tell me what the actual size of the pod light cutouts are? By bumper has shipped, and I’m trying to order new lights ahead of time, but I don’t want to order ones that are too big.
  26. Mar 15, 2021 at 5:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  27. Mar 15, 2021 at 6:02 PM
    FrenchToasty
    Mo
    Bone stock
    @Tundra2
    Gitty up! I inherited my dads stand up tool box, always finding random shit(a really nice open face reel a few months ago)
    But I went and checked the socket drawer...........
    A two footer and one foot extension:)
    Mission accomplished!
    Filthyphil, Dwarven1 and Tundra2 like this.
  28. Mar 15, 2021 at 6:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A big Dub!
  29. Mar 15, 2021 at 6:28 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Remind me in the morning. What lights are you considering?
    Tundra2 and lsaami[QUOTED] like this.
  30. Mar 15, 2021 at 6:44 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I’m between Baja designs and Auxbeam
    Tundra2 likes this.
