  1. Mar 6, 2020 at 2:09 PM
    #1291
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Was I supposed to order new mounting brackets when switching to a double din head unit? I'm having to force and bend the brackets to make it fit in the dash.
  2. Mar 6, 2020 at 3:59 PM
    #1292
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Yes
  3. Mar 6, 2020 at 4:09 PM
    #1293
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Damn. No mention of this on Crutchfield at all. Typically they will guide you through this at checkout.
  4. Mar 6, 2020 at 5:15 PM
    #1294
    imDementeD
    I ordered the Metra kit on Amazon for like $22.xx.
    The cheap one that's like $6 didn't work correctly.
    I also tried the stock brackets. I feel I could have made it work but wasn't worth the hassle.
    because_wumbo-truck likes this.
  5. Mar 6, 2020 at 5:27 PM
    #1295
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Well, after working on this for hours I beleive Crutchfield may have shipped me a dead head unit. I'm not getting any power. This was a Scratch and Dent unit but there is no physical damage. I thought their website said they test them before reselling but I just checked and I apparently imagined that. I've tried it both with and without the brake bypass to see if that was causing it.
    The lesson here is to always test it first before spending hours on the backup camera and bypass.
    theblurry1 likes this.
  6. Mar 6, 2020 at 5:47 PM
    #1296
    Professional Hand Model
    Hand Protectors
    Anyone familiar with a new OEM 1st Gen Tundra muffler and if there are identifying markings on said muffler that indicate it is indeed an OEM? @empty_lord @speedtre or anyone else that geeks out on parts.
  7. Mar 6, 2020 at 5:50 PM
    #1297
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I believe it should have Toyota stamped on it somewhere
    I’ll check mine when I get homr
  8. Mar 6, 2020 at 5:55 PM
    #1298
    Hand Protectors
    Thanks. Send me a pic if you have one of yours off the truck and/or a pic of the stamp location.
  9. Mar 6, 2020 at 6:18 PM
    #1299
    speedtre
    speedtre New Member
    Inland Northwest
    That blows...sorry to hear it. :(
  10. Mar 6, 2020 at 6:23 PM
    #1300
    empty_lord
    05 rollover special
    [​IMG] Should be visible from under the truck
  11. Mar 6, 2020 at 7:06 PM
    #1301
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    That blows. Will they take it back?
  12. Mar 6, 2020 at 7:56 PM
    #1302
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I'm sure they will. Crutchfield has great customer service. That sucks though.
  13. Mar 6, 2020 at 8:06 PM
    #1303
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Maybe not THE go to. I spent about 7-8 years in the 12v audio/video/alarm/tint world. 4 years of that as an MECP master tech. I left the industry in 2012 around the introduction of the CAN, MOST bus systems. So give me any vehicle pre 2014 and I can almost tell you any disassembly and wiring locations/colors from memory.
    In other words, if it can be done with a relay, I’m your guy. If it needs a data bus interface, Ive been out of the game a bit but give me some time and I could likely make something work.
  14. Mar 6, 2020 at 8:28 PM
    #1304
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    The Alpine has all those different holes in the side so that it will align with the many different factory DIN mounting brackets used by imports through the early 2010s. Those little nipples that stick out will usually line up with 2 tiny holes and then you will see at least 2 screw holes on each side that align with the factory brackets. Use the Metra 95-8202 to fill in the holes left along the side of the radio.
  15. Mar 6, 2020 at 8:46 PM
    #1305
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    The double USB port for the Tundra showed up today
    and noted the tailgate handle on a co-workers midlife crisis (2019ish Tundra). Wonder if that could be made to fit a 1st gen.
  16. Mar 6, 2020 at 9:36 PM
    #1306
    empty_lord
    05 rollover special
    It could technically. You’ll need to graft the new tailgate into the old. I’ve considered it. But I couldn’t bring myself to cut up a brand new Toyota tailgate.
    Someone did a 3rd gen Tacoma tailgate grated into a 1st gen tailgate.
  17. Mar 6, 2020 at 9:39 PM
    #1307
    because_wumbo-truck
    Jon
    Houston, Texas
    Good to know. Get ready for future questions.
  18. Mar 6, 2020 at 9:41 PM
    #1308
    empty_lord
    05 rollover special
    Totally forgot to take pictures. But fixed up the body harness I got from the junkyard, reattached all the light wires. So it should be ready to put in the truck when it’s back
    NUDRAT[OP] and speedtre like this.
  19. Mar 6, 2020 at 9:41 PM
    #1309
    because_wumbo-truck
    Jon
    Houston, Texas
    I've been wanting a tail gate reinforcement plate and been considering if I could make a 3rd gen taco one work
  20. Mar 6, 2020 at 9:47 PM
    #1310
    empty_lord
    05 rollover special
    Their tailgates are taller I believe.
  21. Mar 6, 2020 at 10:38 PM
    #1311
    because_wumbo-truck
    Jon
    Houston, Texas
    Damn. Maybe I could trim it
  22. Mar 7, 2020 at 4:10 AM
    #1312
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While this doesn't help much Erik, I wouldn't beat myself up too much. When I selected your year/model Tundra and that radio, it had a link "See the installation gear you'll need" and it pointed out you'll need to use your existing brackets.
  23. Mar 7, 2020 at 4:34 AM
    #1313
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thanks. I think I can make the brackets work once I get a working stereo.
    speedtre and BubbaW[QUOTED] like this.
  24. Mar 7, 2020 at 4:36 AM
    #1314
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It says that Metra is only good for 03-06 Tundras. They must have changed something. Since you're the radio guy, I may need help after I call Crutchfield. I'm going to test my old radio this morning and make sure it still works just as process of elimination.
    speedtre likes this.
  25. Mar 7, 2020 at 4:38 AM
    #1315
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Is the bracket needing to be bent wider because new radio is not as wide ? If so, can you add washers on bolts between bracket and radio to make up width difference ?
    If new radio is wider and bracket needs to be bent in, that would suck.
  26. Mar 7, 2020 at 5:08 AM
    #1316
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The new radio is wider so I'm having to squeeze the brackets to fit the radio in the pocket. I'll ask Crutchfield about it on the phone once they open.
  27. Mar 7, 2020 at 5:39 AM
    #1317
    artsr2002
    'Yonder
    That's sucks bro. I was able to use the metal mounting brackets off my factory Toyota radio with my Kenwood double din unit just fine. The only other pieces I had to use are the Metra 95-8202 kit to close up the side gaps.
  28. Mar 7, 2020 at 6:02 AM
    #1318
    because_wumbo-truck
    Jon
    Houston, Texas
    @empty_lord mentioned this the other day. The 00-02 had a different size bezel and radio. That's likely why you brackets don't work
  29. Mar 7, 2020 at 6:09 AM
    #1319
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  30. Mar 7, 2020 at 6:14 AM
    #1320
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I'm a big fan of Dean and Fernando @Five Car Stereo, so while you're in there this morning, if you have a VOM and you feel froggy, take a look at the voltages of new harness while unhooked from radio. At the 1:45 mark of video below, Dean tells what each colored wire is for the Alpine iLx W650. The power harness ones that are important you could check are the Red(ACC wire), Yellow w/fuse(Power wire) with IGN ON....etc.
