  1. Jan 27, 2021 at 9:14 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Hard to tell but those look like synthetic lines. Still not a great idea but they're far safer than wire.
    Glock 40, alee891, Casper421 and 2 others like this.
  2. Jan 27, 2021 at 10:50 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    The only place that rents stand alone car hauler trailers is Uhaul and they say a Tundra won’t fit.
    Does something like United Rentals do trailers/car haulers?
  3. Jan 27, 2021 at 11:00 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    interesting. my local rental place will rent standard equipment/tilt bed trailers with no care as to what I put on it. I would be United would rent trailers as well. It's pretty common for those places to rent the trailer along with a piece of equipment.
  4. Jan 27, 2021 at 2:01 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wish I earned a dollar for every time I get a nail or screw in a tire. Wife's car got a nail over the weekend. I'm gonna yank it and see if it went through. I also noticed there are no tools under the spare to change a tire with, so I picked up a 19mm socket and a smaller wrench as well as a scissor jack.
    Always check for those things when you buy a used car, lesson learned but at least I was at home and not out on the freeway or something.
  5. Jan 27, 2021 at 2:11 PM
    18" TRD Off Road Wheels
    oof! Fingers crossed it didn't make it through. That's a lot of healthy tread to lose to a stupid sidewall puncture.
    MS22 and Darkness[QUOTED] like this.
  6. Jan 27, 2021 at 2:11 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Man I have tried every trick I can think of to get my brake pedal to stop squeaking each time I press it. Nothing has worked. I know it sounds minor but it sure is annoying. My only solution has been to turn my music up louder. :notsure:
  7. Jan 27, 2021 at 2:13 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Brake pedal delete
    NWPirate, Glock 40, chrisb and 8 others like this.
  8. Jan 27, 2021 at 2:41 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah exactly, these tires only have a years worth of use on them. I don't really want one new tire and being unbalanced but don't like the idea of buying two new tires either.
    GODZILLA[QUOTED] likes this.
  9. Jan 27, 2021 at 2:49 PM
    Professional Hand Model
    Hand Protectors
    That Nail in Sidewall causes Cancer in California. Must change all 4 tires.
    Glock 40, chrisb, des2mtn and 5 others like this.
  10. Jan 27, 2021 at 2:50 PM
    Do you have road hazard protection on them? If you do, you could get away with just buying one tire to keep that axel even, and use the other tire as a full size spare.
  11. Jan 27, 2021 at 3:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I doubt it, I'll have to call to ask. Since this is 4wd I might be better off replacing two tires.
  12. Jan 27, 2021 at 3:25 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    my u-haul rents two carriers. one is the standard car carrier, one more equipment oriented with a full ramp but is narrow at the bottom.
    Wonder if your region only has the narrower style?
    If it physically fits onto the trailer - Some will tell them they are towing a 1967 VW Beetle. :anonymous:
    Makes their computer all liability happy.
  13. Jan 27, 2021 at 3:46 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    So when I bought the truck had a vibration from about 30mph on. 3 new u-joints, a new carrier bearing, and new set of control arm bushings later. Vibes are gone except for 35-45 mphs range. Any faster and the truck smoothed out. I thought maybe it was the crappy bfg all-terrains, since gotten new wheels and had the set-up rebalanced.
    I swear it feels like it’s directly under the front seats but there’s no guarantees on that bet.
    So that leaves me with a drive shaft weight, drive shaft angle issue, torque converter issue, idk.
    id suspect something with the trans but the truck shifts fine if you romp on it Ann speed through the speed range mentioned above
  14. Jan 27, 2021 at 4:06 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I would check to see if your drive shaft is out of phase.
  15. Jan 27, 2021 at 4:43 PM
    Cummins3500
    Logan
    thanks man, I’ll be up under the truck this weekend and will be sure to check. If it ever quits raining lol:bananadead:
  16. Jan 28, 2021 at 4:06 AM
    Hand Protectors
    The Island received a light dusting of about an inch snow overnight. We’ll be paralyzed for weeks but now everyone can work from home so it doesn’t matter.:rolleyes:
    Now I get to do some Truck Snow Model Shots. Maybe bust out my little Tonka Snow Shovel and Plastique Tire Boards. Gotta wait for the perfect light. :yes:
    NWPirate, des2mtn, chrisb and 2 others like this.
  17. Jan 28, 2021 at 7:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Jan 28, 2021 at 8:36 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Does anyone know if this is true of our trucks?
    On the first gen t4r the flow of coolant to the heater core is regulated by a valve on the feed line in.
  19. Jan 28, 2021 at 9:07 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Hahaha I was giving a guy a thumbs up yesterday cause he was driving an old beat up 90s Toyota pickup, he looked at me confused
    NUDRAT[OP] and GODZILLA like this.
  20. Jan 28, 2021 at 9:19 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yup look on the firewall and you'll see the valve.
  21. Jan 28, 2021 at 10:07 AM
    Pucks18
    Truck is covered in road salt, but that doesn't matter! Mu truck is also covered In grease and wool wax!
    Darkness, NUDRAT[OP] and N84434 like this.
  22. Jan 28, 2021 at 2:07 PM
    Hand Protectors
    Its a Little Box on the firewall on drivers side. Has a cable connected to it from Climate Dash. Lube it and work it real good.
  23. Jan 28, 2021 at 2:15 PM
    NWPirate
    Zach
    WA
    :eek:
  24. Jan 28, 2021 at 5:35 PM
    empty_lord
    05 rollover special
    IF anyone happens across the old TRD big brake kit for these trucks.. Let me know.
  25. Jan 28, 2021 at 11:52 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    unusual weather for her
    Darkness likes this.
  26. Jan 29, 2021 at 1:39 AM
    empty_lord
    05 rollover special
    man seeing the old f-350s and shit being able to have the new interiors out of the brand new trucks swapped in is really making me want to be able to swap in a 3rd gen taco interior... (since 2nd gen tundras WAY bigger)
    someone go steal me a 3rd gen taco so i can experiment
    lsaami and speedtre like this.
  27. Jan 29, 2021 at 4:43 AM
    Hand Protectors
    I saw these now unavailable? and discontinued calipers on a deep search a few months back when everyone was breaking wood on the Scary Lexus Calipers. What do you think about that StopTech 3 Piston Big Brake Kit? Other than the High Dolla $1300 Price. :rofl:
    empty_lord[QUOTED] likes this.
  28. Jan 29, 2021 at 8:10 AM
    empty_lord
    05 rollover special
    I just like seeing TRD. Lol. Honestly I’d make the 2nd gen taco wilwood kit work if I went that route
  29. Jan 29, 2021 at 8:43 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Having owned a '17 Tacoma, the interior was the ONLY improvement over the 2nd Gen. I could never bring myself to own a 2nd Gen Tacoma/4thGen 4Runner/3rd Gen pre-2014 Tundra just because I hate those interiors soooooooo much....
  30. Jan 29, 2021 at 9:14 AM
    empty_lord
    05 rollover special
    Only thing I like about the new Toyota’s (last 4-6 years) has been the interiors.
    speedtre[QUOTED] likes this.
