  1. Jan 15, 2021 at 3:57 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    because tacoma
    some footage at the 8 min mark.
    https://www.youtube.com/watch?v=mglaX1aiKqY
    Darkness[QUOTED] likes this.
  2. Jan 15, 2021 at 7:33 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Hey yall. Anyone know what would make my abs suddenly stop working? I have zero leaks so I'm assuming it's something electrical or a plug. Can anyone tell me some common failure points on our abs systems? Thanks
  3. Jan 15, 2021 at 10:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  4. Jan 16, 2021 at 8:40 AM
    Professional Hand Model
    Hand Protectors
    Whoa! They doubled the price on these.
  5. Jan 16, 2021 at 10:16 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    I know it's barely been a day, but have you had a chance to drive on these and see if there's any difference? Haha I'll take anything. Was really eyeing up those aftermarket coils for my engine replacement but no one had said they used them.
  6. Jan 16, 2021 at 10:44 AM
    Hand Protectors
    Yeah. These are the ones you want guys. Made in Japan.
    abcinv, Hooptytrix and FrenchToasty like this.
  7. Jan 16, 2021 at 10:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not sure if they still are but most of MSD ignition parts used to be made in El Paso.
  8. Jan 16, 2021 at 12:07 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Hopefully they go back down when the osrams store has them back in stock.
  9. Jan 16, 2021 at 12:14 PM
    Hand Protectors
  10. Jan 16, 2021 at 12:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  11. Jan 16, 2021 at 1:30 PM
    Hand Protectors
  12. Jan 16, 2021 at 2:42 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I had a small hicup at idle for the longest time and no matter what I have done it wouldn't go away. Well it's gone now, that tells me that 1 or 2 of the old 1's wasn't functioning properly. My engine is a happy hummingbird on the good stuff at the moment.
  13. Jan 16, 2021 at 7:48 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    All of my 24mm sockets are 12 point except for my impact sockets. I would like to use a six point socket on the new drain/ fill plugs for my rear diff so I do not mangle them. I went to four different places today and the biggest six point socket I could find was 21mm. Grr :censored:
  14. Jan 16, 2021 at 8:30 PM
    FrenchToasty
    Mo
    Bone stock
    @Professional Hand Model
    I’m still digging pookie out of my cuticles!!!
    And I’m going back tomorrow for a second coat, I know you can appreciate a thorough job!
    The pookie really needs a second coat....... and I forgot to tar the car flex for the T stat that i drilled. I’ll take a pic of the perfect execution on a stud with a hole saw!
  15. Jan 17, 2021 at 5:39 AM
    Hand Protectors
    Just don’t nibble on those nails!
  16. Jan 17, 2021 at 5:43 AM
    Hand Protectors
    I prefer the Impact 6 Points Sockets. Seems they have a nice edge that bites. Why not use the Impact Socket? Unless you don’t have one that size?
    FrenchToasty likes this.
  17. Jan 17, 2021 at 6:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  18. Jan 17, 2021 at 6:48 AM
    FrenchToasty
    Mo
    Bone stock
    Stuck in the '00s likes this.
  19. Jan 17, 2021 at 7:06 AM
    Hand Protectors
    I don’t buy it, either. :rofl:
  20. Jan 17, 2021 at 7:11 AM
    des2mtn
    SW
    Tonto cover
    I have an impact six point, but this was what I was originally taught and why I was seeking out a chrome socket. Something with the metal mojo.
    NUDRAT[OP] likes this.
  21. Jan 17, 2021 at 7:11 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Hey man, it's on the internet. It must be true! :)
  22. Jan 17, 2021 at 7:15 AM
    FrenchToasty
    Mo
    Bone stock
    I sorta understand where your coming from, but the drain plugs aren’t torqued down to 90ftlbs like a wheel lug is.
    If I haven’t ever removed said plug, I tap it with a brass hammer. That helps jar the threads loose, it slightly crushes the crush washer further so there is less resistance on the threads as you back it out.
    CodyP and FirstGenVol like this.
  23. Jan 17, 2021 at 7:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I tried to work my Google-fu but didn't find anything more definitive than that. If you guys find something that disproves that, post it. My takeaway is that for light work there is no harm in using an impact socket but that it shouldn't be used if it's being paired with a 4 foot breaker bar.
    On the surface, what they said makes sense. That's assuming they are correct about the metal being softer.
    Agreed. I used an impact socket on my rear diff last week. It's only torqued to around 40lbs. I never could find the torque spec for the drain plug, only the fill plug at 39 ft lbs.
  24. Jan 17, 2021 at 7:30 AM
    des2mtn
    SW
    Tonto cover
    That's a very good point. I guess I'm just an overly cautious person at times, and I was trying to stick to the way I would normally go about it. I don't want to cause a headache for the next time I service the diff. I'll stick with my impact socket unless a chrome one falls in my hands.
    Darkness likes this.
  25. Jan 17, 2021 at 7:46 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'll shock you all. I use almost nothing but impact sockets. I don't have a lot of chrome sockets, besides my impact sockets are black so they work faster. I have not had a problem with the impact sockets mutating.
    Now are you ready for this part? Most of them are Pittsburgh... that's right, from Harbor Freight! :eek: the ones that aren't are Husky.
  26. Jan 17, 2021 at 7:52 AM
    FrenchToasty
    Mo
    Bone stock
    Lifetime warranty is hard to beat. Snap one, go get another
    Hooptytrix and Darkness[QUOTED] like this.
  27. Jan 17, 2021 at 8:08 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I use almost exclusively impact sockets as well. I’ve never had an issue.
  28. Jan 17, 2021 at 8:22 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Anyone need any random smaller 1st Gen Tundra/Sequoia bits? About to do a scrap yard run for a few harnesses. You cover shipping, part, and a small fee (for gas, entrance cost, and time). Will take this post down if against rules.
  29. Jan 17, 2021 at 8:25 AM
    des2mtn
    SW
    Tonto cover
    I need the sun visor mounting screws if you find any. Just the screws, not the visors.
    theblurry1[QUOTED] likes this.
  30. Jan 17, 2021 at 8:46 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Yeah I bet I can find those! I'll let you know. :)
