  1. Jan 8, 2021 at 9:42 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Use fog beam pattern lights and maybe consider mounting by the rear mud flaps but facing inwards about 30-45 degrees? Crossed beam in the middle basically.
    I wonder if the overlap in the center would make for decent lighting straight back.
  2. Jan 8, 2021 at 9:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    DAMN!
    That was me. We were shooting the breeze about it on this thread? Maybe the daily.
    Anyways, I was just going to tap into the reverse light after the frame harness for the brake light. There is a quick connect. Cheaper, and easier that way for me.
    I've already got cubes, but had more important things to do lately.
    Speaking of lighting, I think this is one of my absolute worst lighting mods. Nothing on this turned out how I wanted.
    I have a plan for a better way.
  3. Jan 8, 2021 at 10:28 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Pulled the passenger roof drip trim. Need to get it cleaned up and adhesive removed. Any tips?
    Tundra2 likes this.
  4. Jan 8, 2021 at 10:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I carefully used a propane torch to heat up the old adhesive from my high mount stop light.
    Once it was gooey I wiped it away with a rag. Didn't mess with the paint in any way that mattered. Slight yellowing, but you can't see it unless you're right up on it.
    Your truck is a darker color than mine, and should be better. This is a last resort kinda method though.
    jpink[QUOTED] likes this.
  5. Jan 8, 2021 at 10:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If the channel is wide enough, maybe a 3m pinstriping eraser will work? Its basically a 1/2-5/8" wide circular rubber pad on a drill chuck.
    Otherwise chemicals or heat.
  6. Jan 9, 2021 at 12:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Jan 9, 2021 at 6:10 AM
    Professional Hand Model
    Hand Protectors
    What bulbs are in your Reverse Assys? Nicely done on the Pods action. Might copy this if the HIR Bulb in my Reverse Assy doesn’t pan out.
  8. Jan 9, 2021 at 6:15 AM
    Hand Protectors
    My God man! What were you thinking? :rofl:
    Tundra2[QUOTED] likes this.
  9. Jan 9, 2021 at 6:38 AM
    Hand Protectors
    I’m asking for your prayers to Dali Llama today as the sheep skin covers are installed. Most of my Positive Vibe Earth Credítz will be expended after all this.
    chrisb, jpink and TX-TRD1stGEN like this.
  10. Jan 9, 2021 at 6:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's a thing for sure. FWIW I used something like this in a different vehicle and it's bright.
    https://www.amazon.com/dp/B00IXKTW6C
    Sticking with your light strips you could try hiding them into the trim above the doors.
  11. Jan 9, 2021 at 7:15 AM
    Hand Protectors
    Yeah. I had been looking at those as well. Pretty cool, but from pics seems not as bright/customizable as something like Stevies or hopefully this HIR Bulb. This HIR Bulb had better work or I’ll be going Postal around here!:annoyed::rofl:
    Lil Steve likes this.
  12. Jan 9, 2021 at 8:34 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    The reverse bulbs are just some Phillips 921WLED's I added to my Rock Auto cart when I first got my Tundra last April. The pods are from HF. Very happy with how much I can "see" when backing up last night.
  13. Jan 9, 2021 at 8:45 AM
    Lil Steve
    Gilbert, AZ
    Browsing Big Gurl the other day I came across these interior strips with an on/off switch on them which would probably be pretty bright. @Tundra2
    Tundra2 likes this.
  14. Jan 9, 2021 at 12:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was tequila drunk when I thought that was a good idea.
    :cheers:
    I tried out those squares once before. They got hot enough to melt the solder on the led. :bananadead:
  15. Jan 9, 2021 at 1:08 PM
    Hand Protectors
    Just to be clear, yours are the ‘Flood’ Type?
    Reason I ask is your beam in your picture seems more ‘Spot’ Type shaped. I’m also looking at these which are a lower profile type ‘Flood’.
    Lil Steve[QUOTED] and Tundra2 like this.
  16. Jan 9, 2021 at 2:02 PM
    Hand Protectors
    Mentioned this before and also saw @speedtre mention it the other day: Been using Duck Duck Go as my internet search engine for about 5 years now. Its not intuitive and doesn’t ‘think’ for you which sharpens ones discernment as it should be. Highly suggest!
    speedtre and des2mtn like this.
  17. Jan 9, 2021 at 3:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Me likey... drunk me is SMRT
    Darkness, jpink and NUDRAT[OP] like this.
  18. Jan 9, 2021 at 4:14 PM
    Lil Steve
    Gilbert, AZ
    Correct, mine are the flood type. I saw those lower profile single row lights last time I was at HF, they look nice and are relatively new. In fact, I think I prefer that lower profile than the double row square pod. Maybe I'll throw the square pods on my van and get a pair of those low profile one's for the Tundra. It will only be a matter of time before HF puts them on sale.
    I think the slim one's will look better.
  19. Jan 9, 2021 at 5:03 PM
    Hand Protectors
    Darkness, chrisb, NWPirate and 5 others like this.
  20. Jan 9, 2021 at 5:20 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Me think the deer are spotlighting people. They'll be coming for you....
    Tundra2[QUOTED] and Darkness like this.
  21. Jan 9, 2021 at 7:44 PM
    jpink
    Knoxville
    @Tundra2 i seem to have made more mess than results. The $45 3M Adhesive Eraser Wheel was fairly worthless against this area. The channel prevents getting good contact on the area.
    The only way I was able to make some progress was scoring the adhesive, heating the area with the heat gun and then using a small flat head to pry out a section. The adhesive seems to have pulled paint with it which makes me wonder if roof repair people replaced this stuff and felt the need to add adhesive? It doesn’t seem like the adhesive on the new roof drip is this intense.
    You can see where I got too. Intense.
    Goo gone didn’t do junk.
    FirstGenVol likes this.
  22. Jan 9, 2021 at 8:46 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I wonder if its panel bond or seam sealer then, that stuff would laugh at chemicals and the eraser.
    I'd smooth it down with a wire wheel, seal/paint any exposed metal and see how the new trim fits. If it fits fine I'd just install it.
    jpink likes this.
  23. Jan 9, 2021 at 9:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ok. so. first off. if i ever come across a factory blower. im grabbing it and making it fit the 05 engine. second. I got a free transfercase today.. needs an actuator. so i guess i'll get that all fixed up and keep it as a spare.. so no FJ case swap.. .yet
    lsaami and NUDRAT[OP] like this.
  24. Jan 9, 2021 at 10:55 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Anyone ever try a tonneau cover from a double cab bed on an access cab?
    I found someones used a cap (@FirstGenVol iirc) while searching but not sure if a tonneau would also work.
    6' 2" bed DC vs 6' 3" AC. Not sure on exact width between the rails. Anyone with a DC mind measuring?
  25. Jan 10, 2021 at 12:10 AM
    empty_lord
    05 rollover special
    Man.. I have an urge to find a 2nd gen reg cab taco, swap the 3rd gen bed and front end on, and shove a 4.7l into it.... that’d be one hell of a ride
  26. Jan 10, 2021 at 12:31 AM
    empty_lord
    05 rollover special
    abcinv, FrenchToasty and Tundra2 like this.
  27. Jan 10, 2021 at 12:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That'd be cool as hell. Only thing stopping you, is you.
  28. Jan 10, 2021 at 1:07 AM
    empty_lord
    05 rollover special
    oh trust me. if a wreaked or dirt cheap 4x4 reg cab pops up im jumping on it.. it would be a costly swap to do. but damnit it'd be badass seeing a unicorn.. because 3rd gen reg cab tacos dont exist. nor do any factory v8 tacos... it would be unique.
    and yes. i would totally paint it army green
  29. Jan 10, 2021 at 2:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I like the way you think. :devil:
  30. Jan 10, 2021 at 2:05 AM
    empty_lord
    05 rollover special
    Hell I would probably do full TRD pro suspension and exterior mods including all the badging. Why? Because I can. I like shit that looks factory, but was never actually available.
