  1. Dec 19, 2020 at 5:46 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Thick frost this morning.
    GODZILLA, Darkness, Tundra2 and 4 others like this.
  2. Dec 19, 2020 at 6:16 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    3F this am. Still not motivated to dig out the Tundra, it's likely 2 hours shoveling from the road unless I make a mess driving over it. That would just make final clean-up harder.
    jpink, Tundra2 and Rex Kramer like this.
  3. Dec 19, 2020 at 6:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You need some power!
  4. Dec 19, 2020 at 8:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Dec 19, 2020 at 8:29 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was going to recommend the kit I got but it doesn't go that big. Is 32mm for the axle nut? I already bought one of those back in the spring.
    Been loving this set though.
    https://www.amazon.com/dp/B07MXB85S3/ref=cm_sw_r_cp_apa_fabc_HNI3Fb2SD1PA6?_encoding=UTF8&psc=1
    lsaami and Tundra2[QUOTED] like this.
  6. Dec 19, 2020 at 8:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The big nut on the SPC ball joint where it tightens down on the upper control arm.
    32mm, at 150 Ft.Lbs of torque.
    https://youtu.be/v1RXnk7b2Bs?t=11m20s
    Link is set to start right before he talks about adjusting camber.
  7. Dec 19, 2020 at 8:44 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  8. Dec 19, 2020 at 4:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Y’all really don’t want to know the $& I have tied up in the taco
  9. Dec 19, 2020 at 4:20 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  10. Dec 20, 2020 at 6:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hooptytrix likes this.
  11. Dec 20, 2020 at 7:05 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Dec 20, 2020 at 7:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What in the actual f!&$... How did he not notice that thing leaning.
    Darkness and NUDRAT[OP] like this.
  13. Dec 20, 2020 at 7:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Must have been a Monday, and he was still hung over. Maybe it was his first day on his own.
    When I saw the truck I expected it to snap in half...
    NUDRAT[OP] likes this.
  14. Dec 20, 2020 at 7:39 AM
    Professional Hand Model
    Hand Protectors
    The boy is a Natural Born Mangler.:rofl:
    Tundra2[QUOTED] likes this.
  15. Dec 20, 2020 at 9:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My master cylinder rebuild kit and my replacement inspection plug for the rear drums have arrived.
    MC rebuild kit part # is 04311-34020
    jpink, Darkness, Lil Steve and 2 others like this.
  16. Dec 20, 2020 at 9:28 AM
    Hand Protectors
    I’d like to see a side by side of the new vs. old plunger if you can get one when you do the work. I’ve considered this as a PM issue for a while and look forward to doing it on the next brake bleeding within the year.
    I bet that cylinder port needs a good cleaning with Alcohol/Acetone and some type of reamer if its anything like my rear drum cylinders. They had a coating on the inner walls that wiped off with the solvents on a dense woven rag.
    Question is what/how to clean inside that skinny port?
    Tundra2 likes this.
  17. Dec 20, 2020 at 9:46 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'll be sure to post pictures when I get around to it. I'm on the fence about replacing the rubber seal that the plastic reservoir sits in. I feel like I'm more likely to break the old plastic trying to remove it. This kit came with it but I'm tempted to replace only the guts. We'll see how it goes when I get started.
    I should be able to fit something skinny in there and clean it out. Maybe an acetone soaked rag with a screwdriver. That hole might be a bit bigger than it looks.
    This is a screen grab from a video I found helpful. It's not for a Tundra but it gives me an idea of what to expect.
    https://www.youtube.com/watch?v=WYB4vOv7Iag
  18. Dec 20, 2020 at 4:55 PM
    NUDRAT
    SW CT
    Some dumb ass left the gas in the tank & carb & you know what happens then.... :anonymous:
    Rain Thursday, then I will be able to get into garage & figure out what carb i need to order, which will insure no more snow this winter for me.
    Festerw[QUOTED] likes this.
  19. Dec 20, 2020 at 5:03 PM
    empty_lord
    05 rollover special
    Just clean the sucker out. I’ve never had to replace a carb because of varnish
    Darkness and NUDRAT[QUOTED][OP] like this.
  20. Dec 20, 2020 at 5:21 PM
    NUDRAT
    SW CT
    Being lazy. no place to work indoor w/ cleaning solvents, too dang cold outdoors. I can work a screwdriver or socket with gloves on outdoors. Next spring or summer I can clean up the old one & have it ready on the shelf should :anonymous: do such a stupid thing again.
    Oh crap. Just realized I winterized the RV, but didn't put stabilizer in the tank. Sounds like a Christmas Friday task w/ a drive to mix it up after.
  21. Dec 20, 2020 at 5:24 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I believe there was a @bmf4069 sighting in there. Who else would have a driveshaft in the bathroom?
    CodyP and Tundra2[QUOTED] like this.
  22. Dec 20, 2020 at 8:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its just above freezing tonight. 34°f. I drove an hour to my lunch date with the side view mirrors covered in a very light film of condensation.
    No one followed me when I was southbound.
    Finished my date, and started trucking northbound home. Sideview still covered in condensate. I pull alanders hill, and am about ¾ of a mile away now. I see this car pop up over the hill.
    They catch up to me about 6 minutes later. They're following me about one car length behind. Too close.
    I look at the drivers side view, and think. "Wow, the beam pattern in the condensate is uber cool."
    I'm glancing between the road, and side views. I noticed the condensate was diminishing on the drivers side. I check the passengers side. Its dwindling too, but not at the same rate. Much slower.
    This car follows me for about 4 miles. Both side views are crystal clear now.
    I'm dumbfounded that the cars incandescent/halogen headlights are putting out enough thermal energy to clear my side views rolling at 55 mph...:eek:
  23. Dec 20, 2020 at 10:55 PM
    empty_lord
    05 rollover special
    well they confirmed that this year i AM getting the christmas bonus (thank god)... so the real question... do i buy the headers and just fuckin go full send? or invest it into the taco..
    i also have a 2012 corolla that may be mine for 1500 with a blown engine at 129k miles. new engine for 900 already on stand by if it happens.. KBB value of 5-8k depending on final condition (i think it'll clean up well).. that will be a big bump in funds for the taco.. sooo yea...
    AKA long tubes.. or focus purely on taco.. hmmmmm
  24. Dec 21, 2020 at 4:32 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    1. Buy and flip the Corolla
    2. Go full send on Tundra exhaust
    3. Put balance into Taco
    4. Party time
    5. Excellent
    bassman417, CodyP, Darkness and 2 others like this.
  25. Dec 21, 2020 at 4:33 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Also, it was super nice here in central Indiana yesterday.
    So I worked on the 911 instead of getting the knock sensor and injectors installed.
    derp
    Darkness, empty_lord and Tundra2 like this.
  26. Dec 21, 2020 at 6:14 AM
    NUDRAT
    SW CT
    Get the Taco done. The headers won't get you running, they're just an upgrade. Get yourself to that place where the projects you have are finished. Life is much less stressful when your projects are done. Besides, Taco parts will be getting harder to get as we move away from final (factory) build date.
    Do the Corolla too. That's side-work, not a project.
    Darkness likes this.
  27. Dec 21, 2020 at 6:22 AM
    NUDRAT
    SW CT
    All the hyperflash talk on the WHYDTYFGT thread. Let me venture a question at the risk of being 'shoo'd'.
    I have a vehicle from the late 1980's, If you are at side of road w/ emergency flashers on & you step on the brake pedal - you lose the flashers.
    Anyone know what I need to do to make the flashers take priority over the brakes? Other than use the right turning signal instead? There must be a fix, but I've never found it.
  28. Dec 21, 2020 at 6:30 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    A lot of older vehicles used separate turn/hazard flashers. Might be a simple as replacing the hazard with turn signal flasher.
  29. Dec 21, 2020 at 9:40 AM
    Azblue
    The Dirty T ( ^_^)_且
    I'd go down payment on a nice 3rd Gen. :crapstorm:
    CodyP and Darkness like this.
  30. Dec 21, 2020 at 9:45 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd be lying if I hadn't been eyeing a 21 Tacoma TRD with a 6 speed stick.
    :anonymous:
    Darkness and Azblue[QUOTED] like this.
