  1. Dec 12, 2020 at 1:13 PM
    Professional Hand Model
    Hand Protectors
    You’ll want the Toyota Lithium Based Soap Grease. Its in my build page. Its Pink grease that is compatible with brake fluid. Grease those new cylinders before install.
    I just cleaned the inner cylinder walls with alcohol and acetone follow up. I didn’t hone them as some do. They had some light build up inside, but it cleaned off nicely with the alcohol/acetone on a stout cloth rag.
  2. Dec 12, 2020 at 1:57 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Think I'm going.to buy an eBay snorkel for myself for Xmas.
    NUDRAT[OP] likes this.
  3. Dec 12, 2020 at 2:01 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    This video took me from SPC novice to expert.
    https://m.youtube.com/watch?v=v1RXnk7b2Bs&list=PLKlIoWQay4vosofXcWx-WzFae45FIT5D9&index=29
    abcinv, Darkness and Tundra2[QUOTED] like this.
  4. Dec 12, 2020 at 2:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Dec 12, 2020 at 2:23 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I had both my UCAs caster set to the D aka neutral or stock setting but my camber was not even close from side to side. So I finally fixed that after 2 years or shitty alignments and now I'm on the B setting so I can actually clear my tires when off roading and turning
  6. Dec 12, 2020 at 2:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What's your tire set up? I'm running 265/70/R16 on stock wheels.
    Once I get my front end refresh completed I'll slap these on. Same specs as what I've got on right now, but different tires. More of a road tire with less aggressive tread.
    jpink likes this.
  7. Dec 12, 2020 at 2:57 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    295/75r16
    Tundra2[QUOTED] and FrenchToasty like this.
  8. Dec 12, 2020 at 3:02 PM
    Hand Protectors
    Whoa! Huge. I thought 285/75/r16 was the biggest.
    TRDGen[QUOTED], Tundra2 and des2mtn like this.
  9. Dec 12, 2020 at 3:06 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    They're the wumbo 33s haha
  10. Dec 12, 2020 at 3:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  11. Dec 12, 2020 at 3:14 PM
    Hand Protectors
  12. Dec 12, 2020 at 3:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well @TRDGen, what size socket for the big nut on the spc ball joint, and what torque spec?
  13. Dec 12, 2020 at 3:32 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    That video goes over all that inbetween the 3 to 5 minute marks I believe. Iirc it's a 32mm. I just torque everything down by the tight plus a 1/4 turn rule if by hand or just use my 20v DeWalt impact
    Tundra2[QUOTED] likes this.
  14. Dec 12, 2020 at 3:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okay, thanks. I haven't had time to watch yet. Hoping to get my educational video in tonight during lunch time.
    FrenchToasty and TRDGen[QUOTED] like this.
  15. Dec 12, 2020 at 4:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not sure on the the size nut but it's 150ft-lbs.
    Tundra2 and TRDGen like this.
  16. Dec 12, 2020 at 4:52 PM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Any size is possible if you have an angle grinder and welder.
  17. Dec 12, 2020 at 4:58 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Don’t forget the BFH
    Darkness likes this.
  18. Dec 12, 2020 at 5:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I watched that video. Everything looks surprisingly easy... much easier than I thought.
    I wish that he had went more in-dept on how the cams work, but thats okay. There's probably another video for that.
    I'll scrounge around at work, and see if I can find. ½" drive 32mm socket to sign out for the weekend. My biggest socket is like 24mm. If I can't find one I'll order one.
  19. Dec 12, 2020 at 5:06 PM
    alee891
    Now/here
    Shitbox
    Sometimes the hammer just has to watch from a distance while the power tools have fun.
  20. Dec 12, 2020 at 5:40 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    1 1/4" or so will probably fit too.
  21. Dec 12, 2020 at 7:40 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    I do take the interchanges like I'm playing Mario Kart! Earlier this week I had to go to Phoenix, I had the cruise control at 75mph and left it engaged while merging onto the 10 from the HOV lane. It's usually a 55-60mph curve and if left at 75 it used to feel a little unnerving. She tracked nice and steady, able to hold the line much easier with the fat sway bar up front. When my backordered Addco arrives, I hope to be able to install HD rear springs at the same time. Then, lookout interchanges!
    In the summer, I often head north to Pine on Highway 87 via N Bush Hwy, it's a fun twisty road. And for really twisty stuff, Apache Trail isn't far from me.
    Apache Trail by Lost Dutchman State Park.
    Internet photo
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-798#post-2003567
    And a little more info in a follow up post. I'm waiting on the Addco rear sway bar, it's on backorder.
  22. Dec 12, 2020 at 7:50 PM
    FrenchToasty
    Mo
    Bone stock
    Let me guess, the 60wb onto the 10? Both the hov-10wb and just onto the 10eb WERE always nuts. I usually took my loaded work van over those 75-85!
    I haven’t touched those roads in over two years!!!! It’s been great!!!
  23. Dec 12, 2020 at 9:01 PM
    Lil Steve
    Gilbert, AZ
    I usually stay on the 202wb to the 10, I sometimes have to do the 60 on the way back depending on traffic. Previously having lived all my life in NYC, I laugh at what's considered "traffic" out here. You know what's great? No snow! :D
  24. Dec 13, 2020 at 12:41 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] She’s goin to the farm till I can locate an engine. Till then. Hibernation a little bit longer for her
  25. Dec 13, 2020 at 5:37 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Anyone know if a head unit out of a 2015 Tacoma will factory plug into a 2005 Tundra?
    From what I’ve been read the wire harness is the same on a lot of Toyotas. Wondering if anyone has done it here.
    Thanks.
  26. Dec 13, 2020 at 6:04 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Indeed!
    Tundra2 likes this.
  27. Dec 13, 2020 at 8:40 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Awww. That's too bad. Give her a thick coat of wax before she slumbers.
    Tundra2 and YardBird like this.
  28. Dec 13, 2020 at 9:04 AM
    empty_lord
    05 rollover special
    It’ll be in a garage. It needs a repaint too.
  29. Dec 13, 2020 at 9:05 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have no idea what's going on with my headlights since installing these new ballasts. I'm either getting no headlights, one headlight or both. Each time I drive the truck it's a complete guess as to which one will work. I've checked all the connections and they are snug.
    Tundra2 likes this.
  30. Dec 13, 2020 at 9:05 AM
    empty_lord
    05 rollover special
    Physically
    It won’t fit. But it will mostly plug in and work
    GIN•OKUMA[QUOTED] likes this.
