  1. Dec 11, 2020 at 6:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. Here is how much they rub just sitting in my driveway.
  2. Dec 11, 2020 at 6:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nervous about finding a shop to align it? You might have to drive a little ways but I bet there is someone around that can do it correctly. I took mine to a 4x4 shop and they got it right the first time.
    Darkness, alee891 and Tundra2[QUOTED] like this.
  3. Dec 11, 2020 at 6:53 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    I second Erik. I have faith there's someone nearby that can get you squared away. Just don't take it to a big box shop, unsupervised, and expect greatness is really what we're trying to get across.
    Darkness and Tundra2 like this.
  4. Dec 11, 2020 at 6:57 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I second this. Looking around at 4x4 shops first might be worthwhile. Alignment is one of those things you want done right and it's done infrequently enough it's worth going a little ways if you have to. I think my last alignment when I annihilated my driver's shock was around $80.
  5. Dec 11, 2020 at 7:01 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Both of you have fair points. Admittedly... I forgot all about that place I posted until right now.
    I was planning on driving 1.5 hours to get to them anyways. I like to drive, and don't mind it.
    Darkness likes this.
  6. Dec 11, 2020 at 7:07 AM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Obviously not a quote from the stealership shop. just got quoted nearly 2k for the same work on my carrier bearing and seals. where is this quote from? good prices man.
    Outbound[QUOTED] likes this.
  7. Dec 11, 2020 at 8:07 AM
    Outbound
    Aaron
    Northern Alberta
    It's from a local independent shop. He's $110/hr, most shops in town are $130/hr and the dealership is $165/hr.
    We went to him for the first time for this insurance inspection. We were pretty happy with him and we'll go to him again for work that I don't want to or can't do myself.
  8. Dec 11, 2020 at 8:16 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sadly I’m a many hour drive. Lol otherwise... I can align anything if given specific specs. (Or in the case of a tundra, know what I like when lifted)
    Pucks18 and FrenchToasty like this.
  9. Dec 11, 2020 at 9:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is this an acceptable place to put that ground for my ballast? I didn't see another option.
    I told y'all my wiring game was weak. I've never had to ground anything in my life. :oops:
  10. Dec 11, 2020 at 9:49 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The stud to the left would be a better choice.
    abcinv and FrenchToasty like this.
  11. Dec 11, 2020 at 9:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just to help educate me, why is the stud better?
    FrenchToasty likes this.
  12. Dec 11, 2020 at 10:08 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The stud to the left is closer to the body and if the stud and female threads in the body aren't painted it might be a decent ground.
    The spot you are in doesn't have a clean path to unpainted body.
    I would look at the top of the fender near where the hood touches, there might be a bolt there where you can sand the area down to metal and use that for your ground. There are a few factory grounds done this way on your driver side.
    There is a bolt in the fender just above where your intake tube passes through if you can reach it. Otherwise I might pop the airbox off and look at what is close enough. There are a few pretty good spots to consider below your airbox. Try going direct to the body rather than going to a bracket attached to the body.
  13. Dec 11, 2020 at 10:14 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was wondering about painted surfaces but all the grounds I can see are touching painted areas.
    I see the one behind the air tube. Not sure I can reach it but I'll try.
    Not sure if the hood would pinch this one but it's a lot closer.
  14. Dec 11, 2020 at 10:14 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Like darkness said.
    You want the shortest, least interrupted path to ground. Anything on the fender or firewall
  15. Dec 11, 2020 at 10:16 AM
    FrenchToasty
    Mo
    Bone stock
    While they are painted, usually the threads are what make contact with bare metal, so an eyelet under the screw is good to go
    Darkness, alee891 and des2mtn like this.
  16. Dec 11, 2020 at 10:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think this might work. It's already unpainted.
    So long as the hood doesn't smash it.
    alee891 and FrenchToasty like this.
  17. Dec 11, 2020 at 10:29 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah, that's the ticket Nice work boys. :hattip:
    I can actually see through the crack and it's not touching the wire.
    jpink, Darkness and FrenchToasty like this.
  18. Dec 11, 2020 at 10:33 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That should work, I might try to route a little like this to avoid pinching. Put the eyelet parallel to the fender and move the wire to drop down by the pad.
  19. Dec 11, 2020 at 11:35 AM
    empty_lord
    05 rollover special
    There should be a factory ground wire near that spot I would use
  20. Dec 11, 2020 at 11:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That is exactly what I did. Initially I ran it under the bumper but realized it would constantly be rubbing. The way you drew has it not even touching anything.
    Darkness[QUOTED] likes this.
  21. Dec 11, 2020 at 2:22 PM
    Professional Hand Model
    Hand Protectors
    Should be good to install right up on the other ground bolt. Sand off the paint under the bolt and rub some Electrical Goo all around.
  22. Dec 11, 2020 at 2:25 PM
    Hand Protectors
  23. Dec 11, 2020 at 2:27 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just got this email from Blackstone. Last time I sent a sample I was using a cheap synthetic blend. So I guess oil quality does make a difference. No coolant in the oil.
  24. Dec 11, 2020 at 2:56 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    How's the light output with the new ballast? I hope it's as significant as it was for mine.
  25. Dec 11, 2020 at 3:08 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    So when the Skid Row plate is attached to the crossmember with the 3 bolts up front this is how far I am from mounting the back two bolts.
    Even if I were to tap here, the rest of the progression is going to be/likely is off. The rest of this is all frame and not exactly just a bolt on swap out deal.
  26. Dec 11, 2020 at 3:08 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Where his wire is the factory grounds are out of reach. I remember going through this with my ballasts, driver side was a no brainer but passenger side took some consideration. Initially I went with under an airbox mounting bolt but I didn't like that. I can't recall where I went from there.
  27. Dec 11, 2020 at 3:10 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @jpink are you working with a rwd or 4x4? I'm not sure if access cab vs double cab is different but I think rwd has a different cross member near the trans. I have a similar issue with another brand trans plat for my rwd.
  28. Dec 11, 2020 at 3:14 PM
    jpink
    Knoxville
    RWD. I recently replaced the front crossmember because it was bent but looks like this will require more than just that.
  29. Dec 11, 2020 at 11:17 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    NUDRAT[OP] likes this.
  30. Dec 12, 2020 at 12:10 AM
    empty_lord
    05 rollover special
    Actually, my mother’s coworker is going to sell him her 2004 with a brand new frame come January. So I’m good! Access cab, but works out for him. Body’s a wee bit rough in spots, but it’s a work truck for him to get things done around the farm now
