  1. Dec 10, 2020 at 8:03 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It all looks clean still, call or email the company you ordered from and tell them they messed up and you just noticed it
    Darkness and Tundra2[QUOTED] like this.
  2. Dec 10, 2020 at 8:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I sent an email. I'm gonna hit the hay while I wait on a response.
    If I don't hear back from them in 7 days the sleeve will be for sale.
    Along with
    • OEM Upper ball joints X2 Unused
    • OEM 194 incandescents with the green condom X3 Unused.
    • A few Toyota 1157 sockets X? Most are used.
    Darkness likes this.
  3. Dec 10, 2020 at 8:38 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Small cracks are pretty hard to see on these because they have those built in washers blocking the view. Unless its seriously collapsedI don'tthink you can get a good visual.
    Mine looked okay but were making awful sounds. Since I was replacing everything else on my front suspension I got new arms as well. When I disconnected the spindle I grabbed the lower arm and started twisting it, it had what seemed to be a lot of play.
    chrisb likes this.
  4. Dec 10, 2020 at 8:39 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
  5. Dec 10, 2020 at 9:00 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    10-4, I don't have any noticeable sounds at this time. I may just grab ahold this weekend and see if I can generate any movement which would be indicative of vibes :notsure:. Otherwise I'm not opening the LCA can of worms until I have to.
    Darkness[QUOTED] and Tundra2 like this.
  6. Dec 10, 2020 at 9:32 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Good plan.
    If you do need to replace them, ignore all of those burning videos, I just used pb blaster and a bottle jack. Pushed them out and it makes a really cool pop when they let go and launch about 3 feet. Used a ball joint press to push them back in. (like the video below but without the heat)
    https://www.youtube.com/watch?v=kmaZNBp1gZM
    chrisb, w666, Lil Steve and 1 other person like this.
  7. Dec 10, 2020 at 9:37 AM
    alee891
    Now/here
    Shitbox
    Ha, I actually watched that vid last night! Though my Tundra has lived its entire life in Colorado, I still fear after 300k miles those sumbitches are gonna be stuck solid. Heat / bottle jack (Timmy's approach) is the most intriguing approach I've viewed thus far, though!
  8. Dec 10, 2020 at 11:12 AM
    rock climber
    Mine was 225 when I did it. Plan it for a weekend and I'll come up!
    chrisb and alee891[QUOTED] like this.
  9. Dec 10, 2020 at 11:24 AM
    alee891
    Now/here
    Shitbox
    :cheers:
    NUDRAT[OP] likes this.
  10. Dec 10, 2020 at 2:18 PM
    Professional Hand Model
    Hand Protectors
    Tundra2 likes this.
  11. Dec 10, 2020 at 2:31 PM
    Hand Protectors
    And the Unicarns Farts smell like The Carib Summer Breezes!
  12. Dec 10, 2020 at 2:39 PM
    jpink
    Knoxville
    lol I still can't smell anything so I'll take your word for it! Which is a bummer because I was hoping to see if I could smell any difference with the new O2 Sensors..... Drove to St. Louis and back this morning first thing, got 14.7MPG if you go off the odometer, but because the tires are oversized my math puts it at 15.53MPG highway on 91 non-ethanol today. That was also going fairly fast.....definitely not going for MPGs, definitely going for MPHs.
  13. Dec 10, 2020 at 2:44 PM
    Hand Protectors
    Yeah. My exhaust (seriously) smells like steam now since the all new o2’s. Used to have a gas oil twinge especially when early morning start ups.
  14. Dec 10, 2020 at 4:19 PM
    Hand Protectors
    Found a pic from about 2 years ago when I did my Valve Covers Gaskets. I used the Toy FIPG 103 on the 2 half moons on the backside there. My internals look good. Lobes all smoov a shiny.
    speedtre and Tundra2 like this.
  15. Dec 10, 2020 at 5:56 PM
    Hand Protectors
    Fantasy Island Reflections.
    abcinv, des2mtn, chrisb and 3 others like this.
  16. Dec 10, 2020 at 6:45 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    One of these things is not like the other
    One of these things just doesn't belong ;)
    Tundra2[QUOTED] likes this.
  17. Dec 10, 2020 at 10:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I just watched an interesting series of videos.
    https://youtu.be/pC-xusHSWdo
    https://youtu.be/mB66u4pr8FQ
    TL/DW The Upper ball joint adapters from SPC were too small by .007-.008 of an inch causing wiggle on his upper ball joint.
    I'll take my digital calipers home tonight, and compare my adapters to my OEM Upper ball joints.
    I know @FirstGenVol is running SPC, but is anybody else running these, and did you have any issues on the install?
    Edit: I have NOT seen part 3 which may hold the resolution.
    https://youtu.be/Jqf9Jc67b3k
    Edit: In part 3 he revealed that he is using Tuff country spindles instead of OEM. Watching part 1-2 as an "uninformed" observer like me, key details were missed. I'm sure someone with more aftermarket suspension experience like @Darkness or others could have noticed that before getting to part 3 like me.
    Anyways, still taking my digital calipers home with me. I won't be able to measure my spindle holes, but I figure a comparison between the OEM UBJ, and the SPC adapter should be fine.
  18. Dec 10, 2020 at 11:39 PM
    jpink
    Knoxville
    Eesh, you have more than one? Yeah I wouldn’t want to shove calipers in my spindle hole either!
  19. Dec 11, 2020 at 3:31 AM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Thoughts on JBAS ? Anyone
    https://jbaoffroad.com/jba-std-high-caster-upper-a-arms-for-toyota-tundra-2000-2006.html
  20. Dec 11, 2020 at 4:21 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I watched that also, if you have OEM control arms and you've never used Moog Problem Solver ball joints you won't have any issues. SPC has taken both of those into account also and now offers these to solve the issue. I'm not sure if the newer revisions of the arms comes with them already.
    https://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=25008
  21. Dec 11, 2020 at 4:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Everything up front is OEM except the coilovers obviously. So I'll be okay according to the specs, your reccomendation, and my own verifications.
    OEM. Its hard to see, but I did rotate it for measurements.
    SPC. While they are indeed smaller it'll be alright due to the expansion seam.
  22. Dec 11, 2020 at 6:28 AM
    alee891
    Now/here
    Shitbox
    I have SPCs and enjoy them. Beat the piss out of them on my old Tacoma as well.
  23. Dec 11, 2020 at 6:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @alee891 Sounds like a winner.
    While I'm planning things for the front, and still acquiring the correct parts...
    I guess now would be the best time to.upgrade the bumpstops. I drive on some poorly maintained country roads most of the time. The roads are always beaten up by tractors, and tractor trailers.
    Added vibration absorption in the front isn't a bad thing?
    Whats reccomended?
  24. Dec 11, 2020 at 6:39 AM
    alee891
    Now/here
    Shitbox
    I haven't found new bumps for myself yet, but I'll let ya know if/when I come across something. I've heard wheelers and durobumps are used by others. Seems like some have to modify 2nd gen Taco bumps to fit our rigs, too. Don't quote me on any of that, though, I'll let someone who's tackled that project chime in.
    As for your SPC videos from Kyle (The Other Guy), I believe part of his issue is that he has a spindle lift of some sort / isn't running factory spindles. I've never had wiggle or loose ubj's with my SPCs. Food for thought is all.
  25. Dec 11, 2020 at 6:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Question. I need to install my new ballasts. These come with a ground while the previous ones didn't. Can I just mount the ground where the existing grounds are? Unscrew that bold pictured and reinstall with both grounds?
    The one in my hand is the one I need to install. The black ground is coming off the negative terminal and I think it's from a trailer brake controller the previous owner installed.
  26. Dec 11, 2020 at 6:42 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I have SPCs and I very much enjoy them. My alignment guy says some shops have problems adjusting them but he doesn't.
    I replaced my front-rear OEM bumpstops with Timbren ABSTOFs. They're a lot taller than the OEM ones and I notice they're a lot smoother when bottoming out offroad. Eventually down the line I might buy a set for the front-forwards.
    Tundra2 and alee891 like this.
  27. Dec 11, 2020 at 6:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Honestly, I wouldn't worry about bump stops. There are only two options. Expensive durobumps or Wheelers which are made for current gen Tundra. The wheelers option is what I have and since they are not made for our trucks, the bump is almost constantly riding on the LCA. You are not doing major offroading in your truck so I wouldn't waste your money on something that's overkill and doesn't even fit our trucks properly.
  28. Dec 11, 2020 at 6:44 AM
    alee891
    Now/here
    Shitbox
    @Tundra2 exactly this. Make sure you have a guy that knows how to adjust SPCs. That's priority. Otherwise some idiot is going to give you a dog shit alignment every time.
    TRDGen and Tundra2 like this.
  29. Dec 11, 2020 at 6:45 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Good point. Money saved can be put towards future rock auto bill...
    As far as that ground on your new ballasts. You could give it a shot. That's how I've been hooking up the few added grounds I needed.
  30. Dec 11, 2020 at 6:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @alee891 @des2mtn @FirstGenVol
    This is some excellent feed back you guys are providing.
    I'm sure SPC makes stuff for other brands of vehicles, but I am kind of nervous now about finding a reputable shop. It wasn't something that I thought about before going this route.
    That pretty much nixes places like wallburt werld, and Raben?
