  1. Nov 18, 2020 at 5:41 AM
    #9571
    Professional Hand Model
    Hand Protectors
    Know your situation in life. Become situationally aware. Talk with neighbors. Build support groups. Stock up on Hand Lotion.
  2. Nov 18, 2020 at 7:33 AM
    #9572
    Hand Protectors
  3. Nov 18, 2020 at 7:34 AM
    #9573
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Tom "Jello" Green
  4. Nov 18, 2020 at 7:38 AM
    #9574
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Nov 18, 2020 at 9:28 AM
    #9575
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    I don't think it matters, should be the same 2WD or 4WD. This ebay listing shows compatibility for all 2000-2006 Tundra's. The sellers web page has a PDF of the install instructions here.
  6. Nov 18, 2020 at 9:33 AM
    #9576
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I’m still pissed with myself that I didn’t buy these on Amazon last year when they were $89 shipped
  7. Nov 18, 2020 at 9:35 AM
    #9577
    Lil Steve
    Gilbert, AZ
    That's a really good price. I haven't purchased these yet, hoping for a Black Friday deal somewhere.
    CodyP[QUOTED] likes this.
  8. Nov 18, 2020 at 9:45 AM
    #9578
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I think I have pretty much decided to go with the 6112/5160 combo. I will probably run these on 7 and 5 for what billstien says is 1.6" of lift on the double cab. I have read that I can go either way on upper control arms at this height but that it would improve the ride if I do stick a set of camburg or spc on there. Any thoughts on that?
    https://productdeskapi.cart.bilsteinus.com/media/products/bilstein/E4-WM5-Y509A00_1.pdf
    I have never done anything with leaf springs. What options do I have for adding 1-1.5" in the back without loosing the overload?
    Use case:
    MS22 and Darkness like this.
  9. Nov 18, 2020 at 10:06 AM
    #9579
    Hand Protectors
    Bener
    General Springs and there is another company I cannot remember. Both have HD Springs that accommodate 500 extra pounds and provide about 1.5” of rear lift.
  10. Nov 18, 2020 at 10:41 AM
    #9580
    speedtre
    speedtre New Member
    Inland Northwest
    I'm running that setup....get UCA or you may not be able to get alignment to a spec that prevents wandering. If you use stock numbers for alignment with that lift, it will likely wander...it did for me. Mine settled down with caster at 2.5
    onesojourner[QUOTED] likes this.
  11. Nov 18, 2020 at 11:02 AM
    #9581
    alee891
    Now/here
    Shitbox
    x2 on getting uppers to achieve alignment. I have SPC / prefer them over uniballs, but nearly all aftermarket uppers are a good choice.
    For extra rear lift, icon and toytec provide a "3-pack" add a leaf if you don't want to go full spring pack replacement. The 3-pack allows you to achieve ~1.5" lift while keeping overload in (that's what I have).
  12. Nov 18, 2020 at 11:06 AM
    #9582
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Results vary on the 3 leaf packs
  13. Nov 18, 2020 at 11:09 AM
    #9583
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What do these spring do to the ride with only a 200# topper? I may end up with airbags and cradles to manage a big load of firewood. If I did that I could ditch the overload I think. Most of my towing is done with a weight distribution setup so the weight balances out pretty good to all 4 corners.
  14. Nov 18, 2020 at 11:11 AM
    #9584
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Alright I will plan on upper control arms. Is there anything else out there other than spc and camburg? out of those which will last the longest with the least amount of maintenance?
  15. Nov 18, 2020 at 11:14 AM
    #9585
    alee891
    Now/here
    Shitbox
    I'll agree with this entirely. The 3 pack is just what suits my needs / budget, but by all means isn't a solution for all. I'll echo the same word of caution for UCAs, as that debate will never end. SPC, Camburg, Icon, JBA, Total Chaos, Solo Motorsports. There's a ton.
    jImmegart likes this.
  16. Nov 18, 2020 at 11:24 AM
    #9586
    Hand Protectors
    Unsure as I still have OEM Springs. Others have reported the HD Springs are very nice. Maybe they will chime in.
  17. Nov 18, 2020 at 11:30 AM
    #9587
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think on the 3 pack the unknown comes from the condition the stock springs. These trucks are 15+ years old. If going that route I would look for a heavy duty version and consider leaving the overload leaf in.
    For upper arms just don't go with an unknown company. Most people don't need TC or Camburg, SPC are fine and some new reports of JBA sound good too. I have been happy with Camburg arms since 2011 but back then they were the cheapest option. You guys these days are damn spoiled getting cheaper alternatives :santa:
    bmf4069 and FrenchToasty like this.
  18. Nov 18, 2020 at 11:46 AM
    #9588
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If it were me I'd do new leaf packs and an AAL all at the same time and leave the overload. You may end up at 2+ for a little while but after it settles I'd think it would be pretty good.
  19. Nov 18, 2020 at 11:53 AM
    #9589
    alee891
    Now/here
    Shitbox
    This is exactly what I did. I don't know if icon's 3 pack is considered heavy duty, but I threw the overload back in to get a little bit of lift back after driving around w/o for a few months. Has held up for multiple years now. That said, I certainly pursued the cheaper route for my needs.
    chrisb and Darkness[QUOTED] like this.
  20. Nov 18, 2020 at 12:04 PM
    #9590
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My last tundra I had a heavy fiberglass topper and usually some junk in the bed. I did the deaver 3 leaf AAL with the overload left in, but it was still too soft and eventually I replaced the leaf pack with the ATS heavy duty version. With those leaf springs, my rear hub to fender was 23 and it rode great loaded and unloaded.
    For the UCA, low maintenance and reasonable cost, I think it's hard to beat the JBA option right now. Eibach sells the SPC UCA under their name and it tends to run a bit cheaper, but it's the SPC arms and upgraded greaseable ball joints. I got mine for $500.
  21. Nov 18, 2020 at 12:11 PM
    #9591
    Hand Protectors
    ATS! Thanks for the reminder. A great value.
  22. Nov 18, 2020 at 12:48 PM
    #9592
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Well boys! Looks like im taking a surprise 850 mile roadtrip from Chicago illinois to south east Oklahoma! Im going solo and think I'll leave tommorow. My oil was changed 1,400 miles ago so I'm good on that. All my other stuff is good and I have a 2 left over ignition coils that I can use incase one goes out. I think im good right? My spare tire isnt in the greatest shape but eh screw it
  23. Nov 18, 2020 at 1:01 PM
    #9593
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I also tried on the Maxx website, setting my tundra too 2wd and 4x4 and both provided the same Links with the same product code.
  24. Nov 18, 2020 at 1:04 PM
    #9594
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :thumbsup:
  25. Nov 18, 2020 at 1:23 PM
    #9595
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I think I would rather have springs that were a bit to soft and add airbags for big loads down the road. Do you think the aal would work in that situation? SPCs, 6112s and 5160s are on order from the local shop and expected mid to late december. I will probably have them assemble the fronts and and I will bring them home to put on.
  26. Nov 18, 2020 at 1:36 PM
    #9596
    speedtre
    speedtre New Member
    Inland Northwest
    Freedom UCA, 6112s on 7\5, 5160s and Wheelers 3-Leaf AAL with the overload removed....rides great...
    bmf4069, MS22, MoonOverMarin and 4 others like this.
  27. Nov 18, 2020 at 1:48 PM
    #9597
    Hand Protectors
    I thought he wanted to keep the overload spring?
    I don’t know how I allow myself to get sucked into these suspension threads. :annoyed:
    bmf4069 and speedtre[QUOTED] like this.
  28. Nov 18, 2020 at 2:08 PM
    #9598
    Hand Protectors
    Check that blinker fluid.
  29. Nov 18, 2020 at 3:03 PM
    #9599
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Hmm,
    Me thinks your spare is more important that coils. But relax. Take your time and enjoy the trip
    jImmegart and FrenchToasty like this.
  30. Nov 18, 2020 at 5:36 PM
    #9600
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    So my heat has decided it wants to cut out while stopped at a red light. Still blows air out the vents just cold. Picks up once you start accelerating.
    truck is a little low on coolant. Ordered a new radiator cap also. Run by Toyota dealer tomorrow
    might toss a thermostat in for laughs. Any benefit to the under dog racing 170 thermostat?
