  1. Nov 12, 2020 at 6:22 AM
    #9271
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    How did the kings perform on the highway? There seems to be very few people running king or fox.
  2. Nov 12, 2020 at 6:35 AM
    #9272
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Somebody with Kings will chime in I'm sure. Any aftermarket coilover should ride fine on highways, its on streets at low speed where you'll feel a bit more harshness from the linear springs. Stock springs are progressive so you don't feel little bumps, linear springs don't flex for little bumps so your truck will jolt a bit more.
    Fox were badly designed for these trucks, I have them, I regret getting them, I cannot recommend them. Unless you plan to run a small skinny tire with minimal backspacing you will need to rethink the reservoir mounts. They also interfere with brake line where it meets the caliper, that is the real problem.
  3. Nov 12, 2020 at 7:03 AM
    #9273
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    You've given me a bit more to think about. I have read some of your past posts on the issues with fox. Has any one confirmed that this is still an issue? Are there any coilover setups with progressive springs? Maybe I should be looking at 5100's and new stock springs for a better ride on long stretches of highway?
  4. Nov 12, 2020 at 7:18 AM
    #9274
    Professional Hand Model
    Hand Protectors
    I’m still on original TRD Heavy Duty Springs from 2002 with the Billybob5100 shocks. Rides very nicely on the highway and street. Setting is at one notch up from bottom most notch. 2 years on the set up and very happy. A great value.
  5. Nov 12, 2020 at 7:29 AM
    #9275
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What is a billybob5100?
  6. Nov 12, 2020 at 7:32 AM
    #9276
    Hand Protectors
    Bilstien 5100 shocks. They do well in tow haul, as well.
    Whats your budget on your shock job?
  7. Nov 12, 2020 at 7:41 AM
    #9277
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Oh got ya. I put 5100s and some ome springs in the back of my 4runner. The back of my 4runner does ride harsh especially unloaded. I know that may not be a good comparison to 5100s on this truck though.
    I have around 1500 doll hairs set aside at the moment. Currently the truck has some monroe struts up front so if I go with the 5100s I will also need springs from what I have read. The back has new grey kyb shocks.
  8. Nov 12, 2020 at 7:47 AM
    #9278
    Hand Protectors
    The 5100 do ride firm. I had the KYB prior and they were a nice shock that were softer in ride quality. Try finding some used front coils from junkyard and new KYB or the firmer 5100. That will put you under or on budget depending if you do the labor or others.
  9. Nov 12, 2020 at 7:59 AM
    #9279
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Someone asked about Fox in the past few months and I think the consensus was that it was still a problem. I wouldn't risk it. I've not seen anyone complain about King though. We have several members running them.
  10. Nov 12, 2020 at 8:07 AM
    #9280
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fox has not resolved the issue, they never will because there is very low demand.
    If you are just looking for a little bit of lift up front I would definitely go the 5100 route. Your ride won't change much and they are significantly less expensive. For the cost of Fox you could replace 4 sets of 5100s.
    If your coils are not rusty or visually damaged I would probably keep them. Or you can look for a set of used TRD coils in the classifieds here for a cheap upgrade.
  11. Nov 12, 2020 at 8:08 AM
    #9281
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    ADS is another highly reputable / customizable coilover option.
  12. Nov 12, 2020 at 8:47 AM
    #9282
    Hand Protectors
    FrenchToasty likes this.
  13. Nov 12, 2020 at 9:11 AM
    #9283
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    just ordered a set of 4.56 tacoma differentials from a junkyard for $450. score! :yes:
  14. Nov 12, 2020 at 9:13 AM
    #9284
    Hand Protectors
    lsaami[QUOTED] likes this.
  15. Nov 12, 2020 at 9:32 AM
    #9285
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had those monroes and they were awful!
    Are you looking for lift and ride quality or just ride quality? You can get Bilstein 5100's and ARB coils in different lengths that will give you lift and ride. I've got a whole spreadsheet worked up so if you let me know what you're shooting for I can share some research. The Bilstein are $240 for both, the coils are $200, new top hats and isolators are $60. Or you can buy them from a few places completely assembled.
    You can't go wrong with Kings, but if you're not doing some serious off-roading, they are overkill.
    Eibach, Dobinson and OME are also some solid options depending on what you are looking for. I had the OME on my last tundra and was very happy with them, firm in a good way, loved to hit stuff at speed off-road and all around good road manners. (I never towed though). My new truck will get the Bilstein eventually just because everyone here likes them and they are a good bit cheaper than the Old Man EMU.
  16. Nov 12, 2020 at 9:54 AM
    #9286
    Hand Protectors
    Your spread sheet would act as an objective reference point for people unsure about shocks/lifts etc.
    What I’ve found from reading here is much subjectivism on the subject where what is working on one Access Cab may not work on another DC. The other compounded variable is people mixing and matching various components with varying degrees of success.
    You should post up your Spread Sheet and it should become a Sticky!
    Ballpark Costs can/should be added later as the other thing I’ve found is some people have desires that don’t match the budget $$$. DIY vs. Shop is the other variable.
  17. Nov 12, 2020 at 9:55 AM
    #9287
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am looking for maybe 2 inches of lift. This spends most of it's time on pavement but most of my weekend adventures end in washboard or gravel. This won't see any rock crawling I have a TJ and 4runner for those outings. Small bump compliance is pretty important to me on this pickup.
  18. Nov 12, 2020 at 10:02 AM
    #9288
    rock climber
    To much pressure :) I'm not ready for prime time.
  19. Nov 12, 2020 at 10:12 AM
    #9289
    Some might say you're gearing up for a change.
    :bananadance::broccoli::dancingbacon::jellydance::kona::locked:
  20. Nov 12, 2020 at 10:13 AM
    #9290
    rock climber
    Makes sense. Another option to throw into the mix is the Bilstein 4600 with ARB coil. You can get a 2 inch lift and the valving "should" be a bit softer. I say should because lots of things by Bilstein say the valving can be different, but nothing solidly confirmed for our trucks.
    You can also go stock Toyota coil so it is digressive and then Bilstein 5100 to get the lift. I have stock coils that I'd be happy to get rid of, but I'm guessing shipping would be stupid expensive. Junkyard could be a really good option there and then you have top hats and isolators.
    One more thought, my OME gave me too much lift and I hadn't done the research yet on different coils so I sold them and got the toytec boss coilovers. The boss are very lightly valved and soft, rode so smooth and soft, but too much body lean because they were so soft. I was going to get 700lb springs to try and stiffen them up but ended up selling the truck to my nephew and he loves the way it rides. Toytec sells them with 700lb springs if you ask for it.
  21. Nov 12, 2020 at 11:54 AM
    #9291
    TomGreen
    TomGreen New Member
    :burp:
    bmf4069 likes this.
  22. Nov 12, 2020 at 11:56 AM
    #9292
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you just......
    shifty`[QUOTED] and Darkness like this.
  23. Nov 12, 2020 at 11:56 AM
    #9293
    TomGreen
    TomGreen New Member
    I said "why wouldn't it?"
    I don't know. I.assumed it was 00-06?
    I can try to find the email receipt
  24. Nov 12, 2020 at 11:57 AM
    #9294
    TomGreen
    TomGreen New Member
    Yes... Wait what offer?
  25. Nov 12, 2020 at 12:06 PM
    #9295
    TomGreen
    TomGreen New Member
    What's crazy is all the FB guys swear by Fox
  26. Nov 12, 2020 at 12:13 PM
    #9296
    Hand Protectors
    Are you casting doubt on @Darkness credibility?:poking:
    TomGreen[QUOTED] and Darkness like this.
  27. Nov 12, 2020 at 12:22 PM
    #9297
    TomGreen
    TomGreen New Member
    Never. I doubt the FB people lol
  28. Nov 12, 2020 at 12:22 PM
    #9298
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If they're first gen maybe they haven't gone off road, or maybe they haven't looked at their brake lines. That's where the real carnage happens.
    I've seen three trucks where brake lines got smashed and only one where its damn close but isn't hitting.
  29. Nov 12, 2020 at 12:23 PM
    #9299
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I told him if he wants it I will send it.
  30. Nov 12, 2020 at 12:27 PM
    #9300
    alee891
    Now/here
    Shitbox
    Are we referring to the cancerous First Gen Tundras FB group? That page went off the rails this year...
    TomGreen[QUOTED] likes this.
