  1. Oct 26, 2020 at 3:24 PM
    #8701
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just under 50k. Runs nice, even went to the smog guy direct from the shop and it passed. Doesn't feel as lazy and cumbersome as it used to, its kind of like when you buy new shoes then realize how beat up your old shoes were. I'm pretty excited to drive it again.
  2. Oct 26, 2020 at 3:41 PM
    #8702
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Are you worried about led headlights in the snow? I thought they didn't melt the snow off the headlights
  3. Oct 26, 2020 at 3:49 PM
    #8703
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The compressor I installed 3-4 months back, shit the bed. I told them not to put any more money into it(12ish years old ice machine) but they didn’t want to listen. I was kinda frustrated because I know it didn’t fail due to my install, and ice machines can be a pain to diagnose and trouble shoot! Well when I started it up everything ran fine, it shut off properly, then I sent it into freeze cycle......the head pressure rose and rose and rose. There’s a head master(maintains a constant head pressure) control that was stuck in bypass(not cooling thru the condenser) so it was pumping 400psi +, gave it the old tap tap smack with my crescent, nothing. Cut the capillary tube dome charge, still nothing. So I shut her down to live another day after I install a new head pressure control.
    Stupid pigeons!
  4. Oct 26, 2020 at 4:26 PM
    #8704
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    These headlights are pretty rounded off. Likely not much of an issue with wax on them
  5. Oct 26, 2020 at 4:30 PM
    #8705
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I was able to get them out with an adjustable Pitman arm puller.
  6. Oct 26, 2020 at 4:34 PM
    #8706
    FrenchToasty
    Mo
    Bone stock
    I’ve had good luck just hitting the surface that’s holding the bolt/ball joint stud/tie rod end, and then hitting up on it with a nut protecting the treads. I did it last night to help my neighbor, he looked destroyed when I popped the tie rod out so easy.
    Darkness likes this.
  7. Oct 26, 2020 at 4:44 PM
    #8707
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Screenshot_20201026-184414_Gallery.jpg hand and hand, best friends for ever!
    bmf4069 and shifty` like this.
  8. Oct 26, 2020 at 11:04 PM
    #8708
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Oct 27, 2020 at 4:29 AM
    #8709
    Professional Hand Model
    Hand Protectors
    OMG that poor little piglet! He was minding his business fertilizing the Earths Vegetation and wasn’t harming anyone and you killed him.
  10. Oct 27, 2020 at 8:30 AM
    #8710
    TomGreen
    TomGreen New Member
    Hogs are a nuisance that must be managed with extreme prejudice. :infantry::laser::fenforcer::quickdraw::hungry::dancingbacon:
    bmf4069, Pucks18 and Tundra2 like this.
  11. Oct 27, 2020 at 9:05 AM
    #8711
    shifty` Inside his chest they found ten thousand pencils
    ... and a smoker or caja china!
  12. Oct 27, 2020 at 9:07 AM
    #8712
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I feel the same way about humans.
  13. Oct 27, 2020 at 9:10 AM
    #8713
    bmf4069 and Tundra2 like this.
  14. Oct 27, 2020 at 9:22 AM
    #8714
    Hand Protectors
    Little Vegan Animals are our friends! We should not be killing them!!!
  15. Oct 27, 2020 at 10:07 AM
    #8715
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Alright, I'll be losing my brake job virginity with this project. I've only ever helped a buddy with his Nissan Rogue.
    Dan the Fix it Man used some Sil-Glyde on the back of the shims. I have the shim kit and Toyota pads. Should I pick up a tube of that? Any other tips I should know about?
    For some reason he went 100 ft lbs on the caliper bolts for the 2004 in the video, but my FSM says 90 ft lbs. Maybe 04 was different.
  16. Oct 27, 2020 at 10:09 AM
    #8716
    Hand Protectors
    Yes on the Sil-Glyde.
    TomGreen likes this.
  17. Oct 27, 2020 at 10:40 AM
    #8717
    Hand Protectors
  18. Oct 27, 2020 at 10:45 AM
    #8718
    Azblue
    The Dirty T ( ^_^)_且
    Don't forget to grease the rotors really good too, wouldn't want them to rust.
    bmf4069, Lil Steve, Darkness and 2 others like this.
  19. Oct 27, 2020 at 10:50 AM
    #8719
    Hand Protectors
    Yeah. Thats a good idea. You could also turn your pads around to save some wear and tear. :rofl:
    Pucks18, bmf4069, Darkness and 2 others like this.
  20. Oct 27, 2020 at 11:05 AM
    #8720
    empty_lord
    05 rollover special
    Use the grease that came with the shims.. sil-glide is meant for caliper pins. At work for shims we use a paste, called noise free, disc brake squeal silencer
    it’s a brush in bottle, grey bottle with white sticker and blue letters
    bmf4069 and TomGreen like this.
  21. Oct 27, 2020 at 11:45 AM
    #8721
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ugh. I just picked them up. I didn't notice it until I got home but it looks like they shaved both sides of the ears. So instead of shaving off 3.5mm from one side they took that total amount off the entire ear. :annoyed:
    I'd like to think I can bring them back and have them shave a little more off the inside portion.. Right?
  22. Oct 27, 2020 at 11:46 AM
    #8722
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    They didn't come with any grease sadly.
  23. Oct 27, 2020 at 11:47 AM
    #8723
    empty_lord
    05 rollover special
    Now that they shaved the opposite side, you also need to watch the caliper bolt isn’t too long and hits the rotor.
  24. Oct 27, 2020 at 11:47 AM
    #8724
    Hand Protectors
  25. Oct 27, 2020 at 11:50 AM
    #8725
    Hand Protectors
    Flare Nut wrenches. 8mm-10mm-12mm.
    Fluido Supremo. DOT3 Sacrificial. Widdy Wack PHM Bleeder Bottle. NAPA Self Bleeders.
  26. Oct 27, 2020 at 11:52 AM
    #8726
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah....F**K. Who was it that complained about redneck machine shops? I think it was BMF. I explained it to this guy 3 times and he even repeated it back to me. At no point did we discuss machining the outside edge. I would like to think if he took equal amounts off both sides then I should tell him to take another 1.75mm off the inside edge. I don't have much faith in him at this point.
    bmf4069 and Darkness like this.
  27. Oct 27, 2020 at 11:56 AM
    #8727
    TomGreen
    TomGreen New Member
  28. Oct 27, 2020 at 11:58 AM
    #8728
    Hand Protectors
    This isn’t boding well. Also, I thought it was 3mm not 3.5mm. Either way you’re now losing more meat if you have the proper side shaved another +/-1.5mm. :annoyed:
    I hate being right on this one. :annoyed:
  29. Oct 27, 2020 at 12:01 PM
    #8729
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Both numbers were given by the Geholf dude. I'm sure as long as you're in that 3.0-3.5mm range it's fine. I confirmed with @imDementeD he did 3.5mm so that's what I went with.
    Well, I'm an asshole. I really need to stop jumping to conclusions. I got to looking at old pictures I took from a few days ago and realized that's how they come. So I called the shop and he confirmed he didn't shave the outside. All should be well.
  30. Oct 27, 2020 at 12:02 PM
    #8730
    Hand Protectors
    Good news! Getter dun now and don’t come back until done its right. :rofl:
    bmf4069, chrisb and TomGreen like this.
