  1. Oct 15, 2020 at 4:20 AM
    #8461
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Will do, I order the cali raised bracket last night. I started with it since I had it on a 11 dc taco. And it’s the cheapest.
    Diode dynamics, Baja designs, and rigid all list their brackets as fitting a 2nd gen taco and 2nd gen tundra both. So I’ve got some options to try if Cali doesn’t work out
  2. Oct 15, 2020 at 7:59 AM
    #8462
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I didn't want to start a new thread, but those of you who have run wiring from the engine to the cab, where do you enter in the firewall?
    I started to run some wiring and only saw the wire loom and hood release cable on the driver side. Am I missing something?
  3. Oct 15, 2020 at 8:15 AM
    #8463
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I've run 4 ga power wire and two sets of finer gauge through that circular hole on the driver's side. I've also got wiring from the back of the truck entering in through a spot under the driver's seat which you need to remove the seat/carpet/side trim etc to get at.
  4. Oct 15, 2020 at 8:20 AM
    #8464
    Professional Hand Model
    Hand Protectors
    shifty`, NUDRAT[OP], bmf4069 and 2 others like this.
  5. Oct 15, 2020 at 8:48 AM
    #8465
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks for the info @robabeatle and @Professional Hand Model I think I'll go with the one on the driver's side. Did you do anything special to seal around the wiring through the grommet? I was thinking of adding some silicone to help ensure it's completely sealed.
  6. Oct 15, 2020 at 8:55 AM
    #8466
    Hand Protectors
    I used a skinny probe (very carefully) to push through the grommet hole. I pierced a hole in the rubber and fed the wire through the hole which basically self sealed. I then used FuzeIt along the entire Seal (after cleaning it first). It actually stopped some noise and air infiltration. Painted black to match back.
    Kimosabe[QUOTED] likes this.
  7. Oct 15, 2020 at 8:58 AM
    #8467
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have run a few wires through that gromet. Where it is you have nothing to worry about in terms of water. It's up high on the firewall right between the fender and brake booster.
  8. Oct 15, 2020 at 9:07 AM
    #8468
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks. I was worried about water running down the cowl and dripping there.
  9. Oct 15, 2020 at 10:16 AM
    #8469
    robabeatle
    AZ
    I put some silicone around the opening.
  10. Oct 15, 2020 at 11:52 AM
    #8470
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I ran wires into the cab with a grommet from a junkyard tundra and under the passenger seat. Sealed just as good as factory.
    NUDRAT[OP] likes this.
  11. Oct 16, 2020 at 10:33 AM
    #8471
    empty_lord
    05 rollover special
    Well today just went to shit. The dog took a turn. Looks like I have to put the little girl down... I’ve done all I can do. Considering when she was born they figured 4 years max, 11 is one hell of a run for the little girl.
  12. Oct 16, 2020 at 12:34 PM
    #8472
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sorry to hear this Dan. :(
  13. Oct 16, 2020 at 1:38 PM
    #8473
    empty_lord
    05 rollover special
    This years been rough. First the cat, my dads wreak and now the dog.
  14. Oct 16, 2020 at 3:23 PM
    #8474
    Hand Protectors
    Sorry, too. I always plant some flowers/seeds in the garden for remembrance of the pet. Every Spring the new blooms remind of their coolness they bestowed on us while here on Earth.
    bmf4069, MS22 and empty_lord[QUOTED] like this.
  15. Oct 16, 2020 at 7:22 PM
    #8475
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Did I ever tell you guys don't buy VWs? :D
    shifty`, bmf4069, ktundra and 2 others like this.
  16. Oct 16, 2020 at 7:26 PM
    #8476
    Azblue
    The Dirty T ( ^_^)_且
    Well, no shit Sherlock. I've also learned not to touch the burner on the stove when it's glowing red.
    bmf4069, CodyP, Kimosabe and 3 others like this.
  17. Oct 16, 2020 at 7:36 PM
    #8477
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm determined to get another 2 years out of this car before I buy myself a 40 birthday present Lexo.
  18. Oct 16, 2020 at 9:01 PM
    #8478
    empty_lord
    05 rollover special
    RCF
    Darkness[QUOTED] likes this.
  19. Oct 16, 2020 at 9:10 PM
    #8479
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nah, going old man style with an LS 460. Over the next year I'll have my 12 second bug worked out for fun driving and my 30 second bug for cruising. I want a land yacht that I can fall asleep driving as my mid-life crisis mobile.
  20. Oct 16, 2020 at 9:12 PM
    #8480
    empty_lord
    05 rollover special
    ok.. just a heads up, the ls460 is the WORST LS lexus made.. wind noise issues due to a design flaw, engines burn oil. suspension issues that cost an arm and a leg to repair.
    (the wind noise, if it wasnt fixed at the dealer under tsb, requires like the top half of the front doors to be replaced)
    ls430 is a far superior car if your ok with older. my buddies got 410k on his!
    bmf4069, ktundra, MS22 and 3 others like this.
  21. Oct 16, 2020 at 9:17 PM
    #8481
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Which year? I haven't heard this and I've been researching the 2013-2017 version.
  22. Oct 16, 2020 at 9:19 PM
    #8482
    empty_lord
    05 rollover special
    oh those are probably better. i haven't dealt with those. the 07-10s are cheap enough people buying them who really shouldnt are buying them and having issues like no other.
  23. Oct 16, 2020 at 9:20 PM
    #8483
    empty_lord
    05 rollover special
    i still dont think lexus will ever produce a car that tops the ls430.. their biggest issue is air suspension stuff and heat shields rotting off.. other than that as long as the timing belts replaced they run forever. 3uz is also a stupid smooth engine.. more so than the 4.6l in the ls460
  24. Oct 16, 2020 at 9:22 PM
    #8484
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm ideally looking the later of those years, hopefully around $20k but I would pay more if lower miles and well kept. From what I've been seeing the price hikes at 2015 today. Hoping to find one where the first owner had money to buy a $75k car and maintain it. I know too well what happens when people buy cars and can't afford to care for them, thats typical of VW money pits.
  25. Oct 16, 2020 at 9:23 PM
    #8485
    empty_lord
    05 rollover special
    first owners usually keep them in check. the early ones had issues that just made people sell them off pretty quickly. now their on their 3rd-4th owners.
  26. Oct 16, 2020 at 9:31 PM
    #8486
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah exactly. Right now a 2015-2017 is a little more than I would like to pay for but in 2 years should hit the 25k mark when depreciation has just about set in.
    I have heard a good number of people say the 430 is the better car but I'm coming from a GTI so I'm sure I can put up with whatever quirks the 460 has. I'm actually looking forward to having a car I won't modify. I haven't had a car with some form of irregular tire wear in 20 years.
  27. Oct 16, 2020 at 9:40 PM
    #8487
    empty_lord
    05 rollover special
    I will say the stock ls460 sounds neat (albeit quiet) the one I heard with an exhaust sounded amazing outside the car, you could barely tell inside!
  28. Oct 16, 2020 at 9:51 PM
    #8488
    empty_lord
    05 rollover special
    This is the current trans temps after a 30-40 minute drive. Temps do creep up (to be expected) but I’ll know Sunday once I tow the Mercedes how it will be with towing
    Darkness likes this.
  29. Oct 17, 2020 at 9:16 AM
    #8489
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've heard a few Lexuses... Lexus'... Lexi? V8s With exhaust and they always sound killer.
  30. Oct 17, 2020 at 9:11 PM
    #8490
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Does anyone know what kind of weird ass wrench you need to get the inner tie rod end off? It’s like a 90mm span and the facets are only a few mm wide. @empty_lord
