  1. Feb 17, 2020 at 10:05 AM
    #811
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I'll check with my buddy Tim, chances are a USPS flat rate box would be cheapest. Hang tight!
  2. Feb 17, 2020 at 1:35 PM
    #812
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thought this was interesting to look at.
    Blue is for Honda Element 2.4L naturally aspirated
    Short black is for Tundra 4.7L naturally aspirated
    Tall black is for GTI 1.8T turbo
    VW on top, Toyota below
  3. Feb 17, 2020 at 2:55 PM
    #813
    Professional Hand Model
    Hand Protectors
    Mobil1 specs a smaller oil filter for our trucks, but there is a larger Mobil1 filter that fits even though its not spec’d.
    chrisb and NUDRAT[OP] like this.
  4. Feb 17, 2020 at 2:57 PM
    #814
    Hand Protectors
  5. Feb 17, 2020 at 3:01 PM
    #815
    Hand Protectors
  6. Feb 17, 2020 at 4:35 PM
    #816
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    So I think I'm gunna buy some retro'd headlights. Anybody seen this Nomad Retrofits in FB? They seem to specialize in Toyotas and the price is right. Might be able to budget it next month.
  7. Feb 17, 2020 at 5:21 PM
    #817
    Hand Protectors
    Pics?
  8. Feb 17, 2020 at 5:33 PM
    #818
    because_wumbo-truck
    Jon
    Houston, Texas
    I don't have any. The dude posted on one of the tundra groups I'm in on FB. It was a close up of a 3rd gen 4 runner headlight. Looked good. He quoted me $430 for new housings with the chrome reflector left intact (you can have em paint it black etc), retro'd projectors with amber halos, includes balasts and hid bulbs.
  9. Feb 17, 2020 at 11:40 PM
    #819
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Hmm I wonder if the oem filter can still be had. Looks like that bigger filter is from the fj40s and diesel Toyota pickups
  10. Feb 18, 2020 at 4:38 AM
    #820
    Hand Protectors
    Ppp
    I saw the M1-301A at the auto store last time I looked.
  11. Feb 18, 2020 at 5:26 AM
    #821
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I've always thought, given the choice - one would want the larger filter available. Theory being larger filter, more filtering, less potential for blockage / pressure buildup.
    Of course larger doesn't always fit. On the Pius, a longer filter would hang down & be susceptible to road rash or worse.
    ...& you'd need to add slightly more oil to properly fill the case, but only a little more.
    Any reason one wouldn't opt for a longer/ larger filter (assuming space allows)?
  12. Feb 18, 2020 at 5:46 AM
    #822
    Hand Protectors
    The OEM filter is the YZZD-3 on our Tundras. When you go to the auto store and ask for a Mobil1 filter they will give you the smaller one (why I don’t know). The point of my posts/pics is that the YZZD-3 Toy filter and M1-301A look to be the same size and will fit (even though the auto store won’t have it as a spec filter in their system). I ran the smaller M1 filter that came as a combo oil deal. Bought some bigger Toy YZZD-3 filters in a 10 multipack afterwards.
    I have no hard data other than preference. Seems our 4.7L engines have a oil cooler on them at the filter area and the more oil the filter can hold the better the cooling? This leads me to believe the bigger filter would work better on our systems.
    Another advantage of a bigger filter, outside of having a larger internal filter surface media, is the outside larger metal surface area acts as an oil cooler in itself.
    NUDRAT[QUOTED][OP] likes this.
  13. Feb 18, 2020 at 5:56 AM
    #823
    because_wumbo-truck
    Jon
    Houston, Texas
    Pretty sure.im going to go retro projectors when I get my tax refund. So @empty_lord was it you that wanted my ultimate headlight harness and h4s?
  14. Feb 18, 2020 at 8:07 AM
    #824
    empty_lord
    05 rollover special
    Yea
  15. Feb 18, 2020 at 9:22 AM
    #825
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Before I bought my truck I had it inspected at a Toyota dealer, they told me I need a new steering rack.
    Turns out I need:
    New LCA bushings
    2 new wheel bearings
    Valve cover gaskets
    Carrier bearing
    And had a leaking axle seal on the front dif
    I’m sure there is more I’ll find as I go but I’d be cautious of assuming they’re going to give you a thorough list of needed maintenance, unless you know someone good.
  16. Feb 18, 2020 at 10:01 AM
    #826
    Outbound
    Aaron
    Northern Alberta
    I talked with my dad last night, he has a 2005 Tundra coming up on 500,000KMS. Apparently he has a really good independent mechanic who specializes in Toyotas and was formerly a Toyota master tech. Dad figures I should have this guy do the work. The catch is, the shop is a 24 hour round trip for me...
  17. Feb 18, 2020 at 10:31 AM
    #827
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Professional Hand Model , other than clean, did you do any prep when you painted your plastic trim? My bed liner spray only lasted a few weeks. I cleaned them with alcohol before painting.
    kodyquist21 likes this.
  18. Feb 18, 2020 at 10:43 AM
    #828
    empty_lord
    05 rollover special
    Scored some Cali raised lights, a scan gauge and a blue sea fuse box with a 100a breaker on a used Tacoma we bought at auction
    Darkness and FrenchToasty like this.
  19. Feb 18, 2020 at 2:25 PM
    #829
    Hand Protectors
    I only wiped mine down with acetone. I did not sand them but should have as I have a few spots like yours which I’ve sanded down and then touched up. I do not have this problem on any outside trim where I’ve used the bed liner or on any areas where I used Acrylic Lacquer as a prime coat first.
    Must be some bad mojo between the bed liner and interior trim when lacquer primer isn’t used. Should be an easy fix with some spot sanding and repaint.
    I’ll only use Acrylic Lacquer on interior trim, now that I know this, as that stuff has a better finish and bonds like its part of the plastic.
    bmf4069 and tvpierce like this.
  20. Feb 18, 2020 at 4:57 PM
    #830
    tvpierce
    tvpierce Formerly New Member
    Maine
    Man, you guys are full of all kinds of give-a-shit that's way beyond me.
    Good on ya!:thumbsup:
  21. Feb 18, 2020 at 5:19 PM
    #831
    Hand Protectors
    Check out this 1st Gen rear frame member near the back bumper. Saw it in a for sale ad. I wonder what the rest of the frame looks like?
    Darkness and NUDRAT[OP] like this.
  22. Feb 18, 2020 at 6:31 PM
    #832
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Would you guys trust a 14 year old topper to handle the weight of a roof top tent? I've seen plenty of people do it but others have said the fiberglass cracked. I called ARE and they said it "should" be ok.
    kodyquist21 and NUDRAT[OP] like this.
  23. Feb 18, 2020 at 6:32 PM
    #833
    empty_lord
    05 rollover special
    I plan on running a roof rack on mine. But I’m also planning on a small cage to support it inside of the cap
    Call the maker and see what they say. Dynamic load is what your looking for. Static will be way higher
  24. Feb 18, 2020 at 6:43 PM
    #834
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I mentioned in my last post that I called ARE. I just saw other ARE shells crack that are way newer than mine. So I'm not sure I trust their answer. May just go for it anyways.
    NUDRAT[OP] likes this.
  25. Feb 18, 2020 at 6:54 PM
    #835
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    What bulbs, projectors, and such?
  26. Feb 18, 2020 at 7:32 PM
    #836
    because_wumbo-truck
    Jon
    Houston, Texas
    Not sure. I just found out about this guy here that makes em and I think I'm going to buy from him instead.
    NUDRAT[OP] and FrenchToasty like this.
  27. Feb 18, 2020 at 7:53 PM
    #837
    KarmaKannon
    Utah
    Some junk
    No biggie I was just curious. I have my current set I'll be selling after my new set is complete and it's always nice to get a sanity check on pricing. I'll probably still let them go for a pretty low price. Nothing wrong with them, but like all things I've done, I know I can do better next time.
  28. Feb 18, 2020 at 8:17 PM
    #838
    because_wumbo-truck
    Jon
    Houston, Texas
    Have you checked out this thread?
    https://www.tundras.com/threads/the-ultimate-headlight-project.60945/
    If I had a DC I'd consider buying yours for sure.
    The guy on FB can do different colored halos but he charges like $100 more than the guy here. So white halo will do me fine haha
  29. Feb 18, 2020 at 9:40 PM
    #839
    empty_lord
    05 rollover special
    Well here’s what happens to your rear diff if you let bad axle seals leak all your gear oil out, $3200 to fix this case of severe neglect on a 2008 fj cruiser With 220k on the odo
    Amazing how the ring gear looks Relatively ok. The pinion is smooth
  30. Feb 19, 2020 at 2:33 AM
    #840
    KarmaKannon
    Utah
    Some junk
    Wow that is crazy. I'm assuming the bearings went bad and the pinion started skipping?
