  1. Oct 2, 2020 at 11:19 PM
    #8281
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    No ones found a work around for the led headlights causing high beam issues right?
  2. Oct 3, 2020 at 5:40 AM
    #8282
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Roughly 2 beers....
  3. Oct 3, 2020 at 6:08 AM
    #8283
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    After dealing with a creosote fire inside an exhaust vent at work with a skeleton crew, and various other jobs i decided to come home and de-stress by working on moms truck before going to bed for work tonight.
    Fire is why I was on the roof. Maybe I should have just let her burn down...
    NUDRAT[OP] likes this.
  4. Oct 3, 2020 at 8:34 AM
    #8284
    Outbound
    Aaron
    Northern Alberta
    Didn't we have a post here somewhere with pictures on swapping out HVAC bulbs? I can't seem to find it. Pretty sure it's only a few screws to pull the panel out iirc. I'm gonna do that job this weekend.
  5. Oct 3, 2020 at 9:57 AM
    #8285
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I went to go check some out but they all only have 1/2 inch sized sockets instead of the 12mm that I need. I went to another sotr
    I ended up sledge hammering a piece of metal in between the bumper mounts and the frame, then sawed off the bolt :)
  6. Oct 3, 2020 at 10:31 AM
    #8286
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Thanks for the invite. I'd love to explore TX though I am stuck working in the desert for a while at this point. Same invite back to you if you get to Tucson, plenty of trails and the weather is just starting to get tolerable.
  7. Oct 3, 2020 at 10:42 AM
    #8287
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Tip the vents up and there's a screw in each, pull the vent knobs and there's a screw behind each. Then just grab a spot and pull straight out.
  8. Oct 3, 2020 at 10:47 AM
    #8288
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    ktundra and Outbound[QUOTED] like this.
  9. Oct 3, 2020 at 12:47 PM
    #8289
    Outbound
    Aaron
    Northern Alberta
    Lil Steve[QUOTED] likes this.
  10. Oct 3, 2020 at 12:50 PM
    #8290
    Outbound
    Aaron
    Northern Alberta
    Oh one other question before I pull things apart. My heater knob only turns 3/4 to the right. Is there a way to fix that while I'm in there?
  11. Oct 3, 2020 at 1:11 PM
    #8291
    Professional Hand Model
    Hand Protectors
    No problems on my 2002. I started with the LED Fogs install first, as I had just put in new headlight filament bulbs. A few months later decided to try the Katanas (HR Knock offs) and even spoke with HR first and they said if my LED Fogs were working proper then the Headlights would work fine. Ended up doing the Katanas because of the reviewers saying they were the same.
    Your 05 (per reviewers) need resistors to stop the HighBeam indicator.
  12. Oct 3, 2020 at 1:15 PM
    #8292
    Hand Protectors
    Have you tried removing the knob and gently trying to turn it the rest of the way with needle nose?
    Cable might be bound up in the rear. I lubed every cable and worked them back and forth while the panels were open.
  13. Oct 3, 2020 at 1:17 PM
    #8293
    Outbound
    Aaron
    Northern Alberta
    I can get it to turn all the way but then it springs back.
  14. Oct 3, 2020 at 1:28 PM
    #8294
    Outbound
    Aaron
    Northern Alberta
    Here's the other end of the cable. Looks like I'm running out of cable when try to set to max heat
    Set as far it will go to heat:
    Set to max cool
  15. Oct 3, 2020 at 3:01 PM
    #8295
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Something's binding. That's why it keeps bouncing back. Take the panel off and grease the wheels.
    Outbound likes this.
  16. Oct 3, 2020 at 3:03 PM
    #8296
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Trust me, they're trying to swim during a Tsunami.
    Amazing how many crap packaging jobs are failing in the system to boot...
    empty_lord[QUOTED] likes this.
  17. Oct 3, 2020 at 3:08 PM
    #8297
    Outbound
    Aaron
    Northern Alberta
    Wheels are greased. Something is binding up in the cables. Not sure where.
  18. Oct 4, 2020 at 7:21 PM
    #8298
    empty_lord
    05 rollover special
    Before
    [​IMG]After[​IMG]And this use to be a jungle but now it’s “tame”[​IMG]
    GODZILLA, Darkness, shifty` and 2 others like this.
  19. Oct 5, 2020 at 10:45 AM
    #8299
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm done with summer. Why is it still here!? Where is fall?
  20. Oct 5, 2020 at 11:02 AM
    #8300
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    We’ve been over 100 for 100 days or something stupid like that. Thursday it’s supposed to be sweater weather (98)
    But at least the night are dropping below 75 now, you can open your windows in the early morning and cool the house down with some fresh air
  21. Oct 5, 2020 at 11:04 AM
    #8301
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I was wondering how it was in AZ. I figured if we were 90s yall were still up there too. It was low 80s and high 70s all last week here too. It was just teasing us I guess...
  22. Oct 5, 2020 at 11:10 AM
    #8302
    Lil Steve
    Gilbert, AZ
    This has been my 3rd summer full time in AZ, holy hell this past summer was nutz! But riding season, and anything outdoors is almost finally here. :yes:
    Still hot but at least it's bearable compared to the rest of the summer.
  23. Oct 5, 2020 at 11:11 AM
    #8303
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oh hell. That's just stupid. I'll stick with my 90s.
    GODZILLA and FrenchToasty like this.
  24. Oct 5, 2020 at 11:14 AM
    #8304
    Lil Steve
    Gilbert, AZ
    Back east 90's + humidity was nasty. Low 100's and low humidity actually isn't so bad. It's a dry heat, you know? :) Like an oven! :bananadead:
  25. Oct 5, 2020 at 11:42 AM
    #8305
    NUDRAT
    SW CT
    I've got your fall right here. Might get to 70F this week 1 or 2 times. Bah. Trade you if it comes with a pool.
    ktundra and bmf4069[QUOTED] like this.
  26. Oct 5, 2020 at 12:08 PM
    #8306
    Hand Protectors
    Finally getting cooler here on St. Barts Isle. The Parkas are coming out of the closet tomorrow.
    bmf4069, Darkness and FrenchToasty like this.
  27. Oct 5, 2020 at 12:13 PM
    #8307
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    High temps were in the 60's with lows in the 40's last week and it gets a little warmer every day, but all good things come to an end.
    bmf4069 likes this.
  28. Oct 5, 2020 at 1:44 PM
    #8308
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Highs in the 60s, and lows in the lower 30s. Working nights, I always get to feel the lower end of the temperature shaft. Lol
    Hopefully won't be going back on the roof at work for a while. :rofl:
    ktundra and NUDRAT[OP] like this.
  29. Oct 5, 2020 at 3:21 PM
    #8309
    FrenchToasty
    Mo
    Bone stock
    Damn that chilly there already?
    I’m super glad I don’t have to get on commercial roofs anymore. We will get some frost or moisture condense on those white membrane roofing material, and usually the heat of your boot compressing the frost will make it melt, and now you’ve got a ice rink up there! I got pretty good at walking on them, but every so often one would sneak up and get me and send me sideways
    ktundra and bmf4069 like this.
  30. Oct 5, 2020 at 3:33 PM
    #8310
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @bmf4069 don't be jealous, I pay extra for this weather.
    ktundra, GODZILLA, YardBird and 5 others like this.
