  1. Jun 24, 2025 at 7:33 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    If you could find a used sheet of aluminum on craigslist or the marketplace, then it might be worth the extra bucks to have a machine shop put a couple bends in it. It would take them all of 5 minutes….closer to 30 minutes if they have to shear it to size.
    TXTundraGuy23[QUOTED] likes this.
  2. Jun 24, 2025 at 7:57 PM
    MacFixes
    MacFixes New Member
    mac
    2000 Tundra Limited TRD
    planning on getting SPC Performance Upper Control Arms (25460) since i got the bilstein lift and my alignment numbers are close, but not exactly in specs. has anyone gotten these? worth the buy or go with another brand? says there specifically designed for 4 runner/ tacoma but after some digging it says they will fit fine on my tundra
  3. Jun 24, 2025 at 8:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    SPC are nice, if you want the extra adjustability -- like for anything bigger than a 33" tire. But you'll have to either know exactly what you want from em or find a competent alignment guy for em. You can adjust camber and caster with the SPCs, and the upper ball joints are greasable. Not sure if their newer UBJs still are. But the odd ones like I have are, and should be greased at least every other oil change.
    There are other options with no extra alignment settings to mess with, like the JBAs, with sealed UBJs and greasable bushings. Total Chaos uniball, Camburg uniball -- just gotta make sure to clean and spray grease on those somewhat often.
    What else..? I'm pretty sure I'm missing at least one more decent brand UCA.
    I don't recommend KSP or Freedumb off-road UCAs.
    G_unit3000 and shifty` like this.
  4. Jun 24, 2025 at 8:29 PM
    shifty` Goons of Hazzard
    Skip it. Get JBA uppers. Most people don’t need the added adjustability of SPC arms. Even more shops don’t understand how they work enough to help you leverage that. Speaking as someone with SPCs here, I’ve experienced the shop shortcomings directly.
  5. Jun 24, 2025 at 9:53 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    I just put 6112 bilsteins in and the JBA UCAs. The JBAs are good quality, more affordable, and simple. I like them.
  6. Jun 25, 2025 at 6:30 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    GA had seen a lot of rain lately and this is the first week that it's been dry so we had a bit of postponement of the heat. Now it's here in all it's glory and the humidity is just smothering. Walking outside feels like you get immediately wrapped in a hot, damp, wool blanket. I was coated in sweat just trimming the hedges yesterday in a 30 minute period. Yuck.
    shifty`, BroHon, bmf4069 and 2 others like this.
  7. Jun 25, 2025 at 8:59 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    We've got some rain here recently, which made it humid here. We do not like the humid here.
    Voss likes this.
  8. Jun 25, 2025 at 9:23 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I’m mowing grandmas yard in volleyball shorts atm. Gonna knock it out before the afternoon rains cool everything off.
    just kidding perv.
  9. Jun 25, 2025 at 9:28 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Anyone running a Makita impact wrench? Looking at getting one so I can stop using the 1/4" impact driver. Not going to purchase a Milwaukee. Even though I have a 120v 1/2" impact, I'm thinking the Makita 1/2" mid torque would be better than the compact 3/8" even though it's 2lbs heavier.
    The Black Mamba likes this.
  10. Jun 25, 2025 at 10:00 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I have the scamazon knock off version of that exact same one and it's great.
    BroHon and des2mtn[QUOTED] like this.
  11. Jun 25, 2025 at 10:19 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    What don’t you like about Milwaukee?
  12. Jun 25, 2025 at 10:21 AM
    des2mtn
    SW
    Tonto cover
    Already have plenty of Makita tools/ batteries.
    Voss, shifty`, FirstGenVol and 2 others like this.
  13. Jun 25, 2025 at 10:46 AM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I have a question on the coolant tube that runs under the intake:
    When I did timing belt and made post about aluminum corrosion.
    Due to color I now think it was actually crystallized coolant.
    I think, going to give it some time to make sure wasn’t just air in system, may have a leak where line connects to water pump.
    When putting on the water pump i thought the water bypass No. 2 had too much movement, but since the back bolt on line at back of intake was solid I rationalized that must be the way supposed to be.
    Now examining exploded views it seems there is another bolt that holds it to the starter.
    Is this correct??
    FSM shows it on CO-5 but doesn’t show the bolts.
    Looking at exploded view on parts finder looks like there is maybe a second bolt holding it to starter??
    Can anyone confirm this?
    If so I think mine is loose at the starter due to the play I noticed when I reassembled.
  14. Jun 25, 2025 at 12:49 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    FYI: $6
    Voss and shifty` like this.
  15. Jun 25, 2025 at 1:59 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    G_unit3000, shifty`, bmf4069 and 4 others like this.
  16. Jun 25, 2025 at 2:10 PM
    Redoak
    Redoak New Member
    Dave
    none
  17. Jun 25, 2025 at 2:15 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I know a guy with an engine :curls:
  18. Jun 25, 2025 at 2:32 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Hovered... and clicked, yep, it's me hahaha
    Both those DCs are really nice.
    I did do an engine pull, (had it rebuilt) and re-install way back in the 90s on an OBS. what could go wrong...
  19. Jun 25, 2025 at 2:45 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    bmf4069 likes this.
  20. Jun 25, 2025 at 2:52 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    bmf4069 likes this.
  21. Jun 25, 2025 at 2:57 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    BroHon[QUOTED] and bmf4069 like this.
  22. Jun 25, 2025 at 3:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Welcome to my world 24/7/365
  23. Jun 25, 2025 at 5:35 PM
    Jack McCarthy
    Bill
    North of Boston
    Today I finally realized the need for a steering wheel wrap when I practically burned my hands touching the wheel even after putting a sun shade under the windshield.
    Damn, it’s both hot and soupy out. Feels like I’m in the Everglades. Not sure how people acclimate themselves to it when you break out in a sweat doing any work outside.
  24. Jun 25, 2025 at 5:43 PM
    Redoak
    Redoak New Member
    Dave
    none
    Something is up with the sun.
    Much stronger than normal.
    I don’t sunburn, but I did today. I Even burned through/under my shirt :confused::monocle:
    BroHon and Jack McCarthy[QUOTED] like this.
  25. Jun 25, 2025 at 5:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    G_unit3000 and bmf4069 like this.
  26. Jun 25, 2025 at 6:05 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    You saying you wouldn't buy Ironman for 10k?
    I wouldn't either.
  27. Jun 25, 2025 at 6:06 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Our normal humidity is around 20%. It's at 66% now. WE DO NOT LIKE THE HUMIDITY. Keep that shit down south.
  28. Jun 25, 2025 at 6:54 PM
    Yup, exactly why I installed irrigation/sprinkler setup for the yard recently. They're kicking on in the next 10mins, actually. Gotta monitor those tonight to make sure they work as expected with my most-recent smarthome hub update.
    Looks great. Could be a good buy for someone, hardest part will be finding a VVTi engine ... unless you were to, like, do yourself a solid, and toss an LQ9 into that joker, and have some real fun....
    bmf4069 and 455h0le_dachshund like this.
  29. Jun 25, 2025 at 7:36 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The truth is you never really do acclimate.
    You just suffer through it like a man, learn to strategically time your outside exposures (both when and duration), or all the above.
    I go through baby powder like crazy down here. ;)
    If I gotta work on the truck, it's in the garage with fans going. But I try to avoid all that this time of year. If I'm outside it's because I'm doing yard work, I'm exercising, I'm going from my truck to a building (or vice versa) or I'm relaxing in the pool/river.
    Jack McCarthy[QUOTED] and BroHon like this.
  30. Jun 25, 2025 at 7:58 PM
    Redoak
    Redoak New Member
    Dave
    none
    Finally found my answer to the No. 2 bypass hose question here in the first picture.
    Yes it does bolt to starter too, and because there was so much slack in mine I think my bolt might have come out.
    Don't know for sure yet, but just thought there was too much front to rear movement when installing the water pump to be correct.
    shifty` likes this.
