  1. Feb 13, 2020 at 10:45 AM
    #751
    speedtre
    speedtre New Member
    Inland Northwest
  2. Feb 13, 2020 at 11:08 AM
    #752
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  3. Feb 13, 2020 at 5:12 PM
    #753
    empty_lord
    05 rollover special
    Mods likely slowing down a bit On the tundra.
    lining up a rental deal on 2200 sq ft of warehouse that I can setup as a small shop and to store my shit.
  4. Feb 13, 2020 at 5:28 PM
    #754
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Black trucks matter
    bmf4069 and TX-TRD1stGEN like this.
  5. Feb 13, 2020 at 7:36 PM
    #755
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    T-100 begat the 1st Gen Tundra.
    Rex Kramer and BestGen like this.
  6. Feb 14, 2020 at 5:32 AM
    #756
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    and now with warehouse space.... definitely an @empty_lord project. :anonymous:
  7. Feb 14, 2020 at 7:34 AM
    #757
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Would you guys use brake fluid from a bottle that was opened 3 weeks ago? I was thinking about bleeding the brakes on the Rav4 since I have a lot left in my bottle.
    NUDRAT[OP] likes this.
  8. Feb 14, 2020 at 8:07 AM
    #758
    Professional Hand Model
    Hand Protectors
    Its so inexpensive, I’d by new.
  9. Feb 14, 2020 at 8:17 AM
    #759
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I just hate to waste it but you're probably right. My thoughts were that the plastic bottle it comes in is probably just as air tight as the plastic res under the the hood. The reservoir doesn't even have a screw top. I need to get that fancy brake fluid you bought!
    because_wumbo-truck likes this.
  10. Feb 14, 2020 at 8:32 AM
    #760
    Hand Protectors
    I’d use the 3 week stuff on my truck if the existing fluid in the lines was real gnarly just as the front line fluid to push out the old cack. I’d then back it up with some new bottle stuff. It just depends on your situation. To be safe just use new.
    The Bosch DOT5.1 plus is good stuff. I only used a litre can to do the whole job this last go around because I had become so good at it after about 3 flushes over a months time. Prior I had used about 2 litres per flush the first go around. The fluid was nasty! I guess it was from all the rubber hose/washer deterioration. The Bosch green color helps identify when to stop bleeding.
    I could feel a pedal difference between fresh DOT3 and 5.1 plus (which has a lower viscosity). Check out the reviews on big guurrl.
    Bosch plus stuff is better and less expensive than the competition 5.1.
    tvpierce likes this.
  11. Feb 14, 2020 at 8:34 AM
    #761
    empty_lord
    05 rollover special
    Hey now, I’m still in the process of finishing my Tacoma!
    NUDRAT[QUOTED][OP] likes this.
  12. Feb 14, 2020 at 8:46 AM
    #762
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    I wanna tackle that soon. Does Energy Suspension have a Tundra Application specific kit all put together and available?
  13. Feb 14, 2020 at 8:52 AM
    #763
    speedtre
    speedtre New Member
    Inland Northwest
  14. Feb 14, 2020 at 8:56 AM
    #764
    mcharfauros
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
  15. Feb 14, 2020 at 11:23 AM
    #765
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I need to flush mine soon. Any links for the fluid?
  16. Feb 14, 2020 at 11:34 AM
    #766
    tvpierce
    tvpierce Formerly New Member
    Maine
    If the 3 week old fluid in the bottle is no good, then neither is the fluid in your RAV4. Master cylinder reservoirs aren't air-tight: they have vents to allow atmospheric air in as the fluid level goes down. At least the brake fluid bottle seals air tight.
    Just use the stuff you have on hand.
    EDIT: If it was a year or two old, I'd say ditch the old stuff and buy new.
    NUDRAT[OP], YardBird, chrisb and 3 others like this.
  17. Feb 14, 2020 at 4:09 PM
    #767
    Hand Protectors
    Check out my pics above for the part number on the box.
    mcharfauros[QUOTED] likes this.
  18. Feb 15, 2020 at 5:09 AM
    #768
    Hand Protectors
    Working on my first Italian Dark Roast. Going to take her on a test drive today to see how these bushings feel on some familiar roads. She needs gas, so I’ll fill up while out in the wild South Coast. Its going to be a great day!
  19. Feb 15, 2020 at 5:53 AM
    #769
    NUDRAT
    SW CT
    @FirstGenVol I had this conversation with the owner of the good autoparts store in town. Little independent shop that's been there forever, the place you go to for quality parts/supplies.
    He told me it's about temperature change. If I'd kept it closed in a temp. stable environment go ahead & use it - it's fine. if it's been on a shelf in the unheated garage for three months, toss it. I keep it in the house, so I used my old stuff w/ no apparent issues.
  20. Feb 15, 2020 at 5:58 AM
    #770
    Hand Protectors
    He has a shmancy heated and cooled garage so he should be good to go!
  21. Feb 15, 2020 at 10:42 AM
    #771
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If I get time next weekend I'm gonna pick up supplies to clay and wax my truck. I picked up a pair of these $6 towels from Harbor Freight and I'm amazed how quick they dried my GTI. I need to get some wheel cleaner while I'm at it but damn it looks nice.
    If you're like me and hate drying your truck, buy two of these. Seriously.
    bmf4069, NUDRAT[OP], 02goes and 3 others like this.
  22. Feb 15, 2020 at 1:53 PM
    #772
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @empty_lord when adjusting the LSPV, what exactly are we doing? I've been messing with mine(up and down). By moving it up, are we making the front brakes do more work? Any reason why this would impact pedal feel?
    I adjusted it up and now it feels like the front are doing more work but the pedal is also firmer, or I'm imagining it.
  23. Feb 15, 2020 at 3:43 PM
    #773
    empty_lord
    05 rollover special
    Pushing it up causes more brake force in the rear. That’s why when you lift the ass
    Of these trucks the brakes feel like they get weaker
    FirstGenVol[QUOTED] and speedtre like this.
  24. Feb 15, 2020 at 3:51 PM
    #774
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Those appear to be effluent filters, the guy must be a plummer if he ordered that many.
  25. Feb 15, 2020 at 4:35 PM
    #775
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Interesting. They are about to go in my recycling. Dealing with Wal-Mart customer service was a pain.
  26. Feb 15, 2020 at 5:05 PM
    #776
    NUDRAT
    SW CT
    If you can't return them, sell them. Might as well get some value out of them, shame to trash brand new product. Or donate to church fund raiser, etc.
  27. Feb 15, 2020 at 11:48 PM
    #777
    PenderBen
    2003 Tundra AC 4x4
    Yeah, they should have some value, put them on Craigslist or something.
  28. Feb 16, 2020 at 4:51 AM
    #778
    tvpierce
    Maine
    +1
    I just Googled Walmart effluent filter, and similar products seem to be worth about $50 each!
  29. Feb 16, 2020 at 6:16 AM
    #779
    Hand Protectors
    Effluence to affluence!
  30. Feb 16, 2020 at 7:33 AM
    #780
    Outbound
    Aaron
    Northern Alberta
    I checked out the prices of a few 3rd gens, from 2014 to 2020. I think I'm going to bring my 1st Gen to Toyota this spring and pay them to go bumper to bumper on it and tell me what I need to do in order to bring it back to nearly factory new condition. Even if it costs me a few thousand bucks to renew this truck, it's way cheaper than the $35K to $45K a newer truck is gonna cost me.
    I have a feeling it's time for a full front end rebuild on the old girl. I still need to get a glovebox latch to replace my broken one. I need a new block heater installed as mine is leaking coolant. So I think I'm looking at around $3000 already.
