  1. Apr 13, 2025 at 10:55 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Another good one I never seem to remember is “Big Boys Race Our Young Girls But Violet Generally Wins” to remember the color bands on resistors and their values.
    bmf4069[QUOTED] likes this.
  2. Apr 13, 2025 at 1:39 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    My kids are actually watching a @des25mtn political ad right now
    Edit, I really need to change the battery in that clock
  3. Apr 13, 2025 at 1:45 PM
    Jack McCarthy
    Bill
    North of Boston
    Dakillacore and shifty` like this.
  4. Apr 13, 2025 at 9:03 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I just used BB ROY G BIV.
  5. Apr 14, 2025 at 6:53 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Transmission shop just called me, they say that solenoid E likely needs to be replaced and that it'll be $500. I gave them the go ahead. I'm a little bit skeptical, but I'm not sure what other option I've got at this point.
    It's about time they called, it's been two full weeks.
    The Black Mamba likes this.
  6. Apr 14, 2025 at 6:59 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    We were heathens back in the day or Heatheren (Hee-there-in.) as @Tundra2 would say.
    “Bad Boys Rape Our Young Girls But Violet Gives Willingly”
    and
    “Willy Ran By Your Place”
  7. Apr 14, 2025 at 7:27 AM
    shifty` Goons of Hazzard
    I assume you let them know that’s been done twice already, and asked them what recourse you have if it suddenly goes bad again? I’m curious what they’ll tell you would cause E to fail back to back.
    FrenchToasty and Dakillacore like this.
  8. Apr 14, 2025 at 9:56 AM
    FiatRunner
    Jack
    Yeah, they're aware that it's had solenoid issues before. I was in class when they called me so I didn't have very long to talk to them, but I'm going to call again later today to ask what specific diag has been done. The guy on the phone mentioned that they might be dropping the valve body- which I don't think has been done before. I told him that they absolutely need to use an OEM solenoid from the dealership, which he assured me they would do.
    The last time I had an issue with solenoid E specifically was at least 2 years ago. Last time I had a solenoid issue it was solenoid A. I don't know. I'm going to make sure to let them know that I'll be back if it has an issue again.
  9. Apr 14, 2025 at 11:04 AM
    sloppylbjs
    sloppylbjs New Member
    04 SR5 DC 4x4 4.7
    Is purchasing soundproofing worth it? I'm installing a couple of PowerBass OE-700 front speakers and have seen people recommend adding some sound proofing while the door panel is off, but have also heard it makes minimal difference. Would love to hear anyone's opinions/product recommendations.
  10. Apr 14, 2025 at 11:20 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    I think that it does help with the door trim rattle and such. Vibration absorption. Some nicely placed felt pads will also do the trick for any pinpoint rattle noises as seen on my speaker in the photo below.
  11. Apr 14, 2025 at 11:30 AM
    FiatRunner
    Jack
    UPDATE: just called them again.
    I talked to the owner this time, who was also the person that test drove the truck.
    He said that during the test drive, the computer was commanding lockup for a second, then it would immediately turn lockup off and throw a pending P0773. If the pending code was cleared, it would do the same thing. Command lockup for a second then turn off. He said that this was really odd, since normally the computer will try a bunch of times before giving up and throwing a code.
    He also said that he doesn’t think anything is wrong with the transmission physically. He told me that all the other sensors and switches related to the transmission were working normally on the test drive.
    I don’t believe that they have pulled the pan or valve body yet. Apparently they’re super short staffed at the moment, that’s why he wanted to replace the solenoid as a first step instead of spending the time to diag if it was good or not. He’s worried that it’ll cost a bunch in diag time just for the solenoid to be bad. I told him to do whatever he thinks is best, but I absolutely need the truck back by the middle of next week.
  12. Apr 14, 2025 at 2:30 PM
    Sound proofing is definitely worth it. But it’s less an insulator as it is a vibration dampener. You want to apply some to the outer door skin from inside. With the door card off, have the window rolled up to get access. Your adding mass, you don’t have to wallpaper the whole door. So a sq.ft. Or two is plenty. The inside door skin or frame portion can also benefit from some. Most will cover the area the speaker mounts to and cutout the speaker opening to help create air separation as well.
    shifty` likes this.
  13. Apr 14, 2025 at 2:40 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Found this on the ole interwebs today. I think they put the wrong vehicle on there...
  14. Apr 14, 2025 at 11:56 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Anyone got a tip on non-VVTI cam seal? Everything I see when searching seems to refer to VVTI 2UZ's. I'm trying to find the part numbers while I'm amassing parts right now, and a good guide to doing the replacement.
  15. Apr 15, 2025 at 2:41 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    DarkMint[QUOTED] likes this.
  16. Apr 15, 2025 at 3:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I just saw the Discount Tire has my Cooper AT3XLT tires in 295/75R16 marked as discontinued. I wonder if they'd honor my certs in a different size or a different Cooper tire. Both? Hmmm
    Looks like in that size they have.
    Nitto Terra Grappler AT
    Yokohama Geolander A/T G015
    Yokohama Geolander A/T4
    Toyo Open Country A/T III
    Nitto Ridge Grappler
    BFGoodrich All Terrain T/A KO3
  17. Apr 15, 2025 at 3:46 AM
    Dakillacore
    Georgia
    I'm going for the KO3s here soon-ish.
    It's odd that discount tire is the only place that I've seen them in stock. I wonder why that is.
  18. Apr 15, 2025 at 4:07 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Can you get the Cooper st maxx? I love these tires.
    KNABORES likes this.
  19. Apr 15, 2025 at 4:10 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Not in the size I have now. But I'll have to ask DT next time I destroy a tire. I have no clue what accomodations, if any, that they'd give me for my certs, when they discontinued my tires in my size.
  20. Apr 15, 2025 at 4:36 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Take the terra grapplers off the list. One of the worst tires in the rain. I'm a big fan of my Toyo at3's. I've put 40-45k on them and they have so much life left.
  21. Apr 15, 2025 at 4:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Honestly I'm hoping that I've got the body lift installed by the time I shred a 295 and maybe I can convince DT to give me a 34x10.5r17 or 35x11.5r17 instead.
  22. Apr 15, 2025 at 6:49 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    90311-38065 - non-VVTI, 2000-04 4.7 Tundra
    SirFives link shows correct part, but listing is in error since it states 2000-05 Tundra and 2001-05 Sequoia. The later seal for 2005-06 VVTI is different.
  23. Apr 15, 2025 at 12:07 PM
    Previous owner was supposed to cut those tabs off. You’re only supposed to leave the tabs you need intact. Sometimes that means leaving up to 3-4 tabs to mount to the speaker, 3-4 to mount to the stock housing. But it looks like they used a too-small housing adapter also.
    Dakillacore[QUOTED] likes this.
  24. Apr 15, 2025 at 12:13 PM
    Best sound deadening advice I’ve seen on this forum. I’d add a couple things…
    Get a good roller to install. Seriously. Ideally one with a ball bearing with roughly a 1” roller.
    Thickness, in mils, matters. More thickness adds more weight. Weight is what you want to achieve, not coverage.
    Noico, Kilmat, Siless, there’s a ton of solid brands that aren’t as overpriced as Dynamat but work 90%+ as effective.
  25. Apr 15, 2025 at 12:29 PM
    Dakillacore
    Georgia
    Flexseal spray probably also would do well, but it would be horrible to remove.
  26. Apr 15, 2025 at 12:31 PM
    Not enough mass to make it worth it compared to noise deadening mat
  27. Apr 15, 2025 at 1:04 PM
    Download the FSM from the megathread.
  28. Apr 15, 2025 at 1:05 PM
    I have some extra Noico we can slap in your doors when the time comes.
  29. Apr 15, 2025 at 1:50 PM
    Dakillacore
    Georgia
    Depends on how many cans you use ;)
    Sweet! Thanks for that. The PO failed to put in some of the door hardware too, so I'll be replacing some odd and in hardware. When I got the truck originally the right front lock cylinder wasn't even bolted in. It was just floating loose, hah.
  30. Apr 15, 2025 at 2:34 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Have the G015 on a taco and the DT Pathfinder Allterrains on the bestgen.
