  1. Feb 18, 2025 at 5:30 AM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    I knew a guy back in the day who bought a brand new Yugo for about $4k and then dropped about $4k on rims, stereo, subwoofer, etc. That's kinda the same thing.
  2. Feb 18, 2025 at 6:21 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Well at least the wheels outlasted the car.
    455h0le_dachshund likes this.
  3. Feb 18, 2025 at 9:48 AM
    bdbrown528
    bdbrown528 New Member
    2002 Tundra Sr5
    For those that were wondering about the ability to clock the shifter. There are cut slots on the shifter ball end that force them to slot in with the detents that also hold down the spring collar. The end is pressed onto the shift lever so you could try to pull it off the splines and then re press it in the position you want it.
  4. Feb 18, 2025 at 11:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Anybody with an 01 or newer ever try E15 88 octane? It's like 10¢/gal cheaper than 87 at Walmart. I might give it a try next time. It said must be an 01 or newer vehicle
  5. Feb 18, 2025 at 12:20 PM
    Jack McCarthy
    Bill
    North of Boston
    Don’t you need a flex fuel vehicle for that?
  6. Feb 18, 2025 at 12:20 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I think 2001 was when “flex fuel” vehicles started being built, but I don’t think that means that all 01+ vehicles can use it.
    Not positive about that but I looked into it on my Lexus and they can’t run it. My moms minivan could, and it said so on the gas cap.
    Jack McCarthy likes this.
  7. Feb 18, 2025 at 12:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The pump said flex fuel or any vehicle made 01+
    Google seems to agree.
    But I'm not convinced either.
    Seems the only logical solution is to check the owners manual.
  8. Feb 18, 2025 at 12:26 PM
    FiatRunner
    Jack
    I don’t know. Part of me thinks “What could the extra 5% ethanol really do?” but I’m pretty sure our trucks don’t have an ethanol sensor, and the engine needs to run abnormally richer when using E85/E15. I wouldn’t want to run my engine lean.
    455h0le_dachshund and KNABORES like this.
  9. Feb 18, 2025 at 2:07 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Plus you get worse mileage with increased ethanol.
    CC80guy likes this.
  10. Feb 18, 2025 at 2:14 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, my truck says not to use more than 10% ethanol. I might set up one of those plastic drums to start washing the ethanol out of my fuel.
  11. Feb 18, 2025 at 2:33 PM
    Jack McCarthy
    Bill
    North of Boston
    But then you’ll lose 10% of your fuel so there goes your effective 1 mpg extra. :p
    bmf4069 likes this.
  12. Feb 18, 2025 at 2:54 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    the ethanol water mixture i wash out would be good for something. And i’d have an extra ?12hp? On tap to outrun race trucks.
  13. Feb 18, 2025 at 3:45 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not in the Tundra, but I pretty much run it every fill in my Altima. Absolutely no mileage difference from 87 that I've seen and it's 30 cents cheaper here.
    Not with E15. EPA says any vehicle newer than 01 should be good, officially I think it was 2014 that Toyota ok'd it.
  14. Feb 18, 2025 at 6:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Whoa whoa whoa... I forgot to turn off the AC the first time. :p
    The second time I was talking to you when the light turned green and you got the drop on me. :angrygirl:
    Re-rematch! :D
    BroHon and Sirfive[QUOTED] like this.
  15. Feb 18, 2025 at 6:17 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    you were catching me the 2nd time.
  16. Feb 18, 2025 at 6:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think in the next few weeks I'm going to try to schedule a tune with @texoma because I don't think Quantum even tuned the ECU they sold me. Or if they did, they did a shit job. So if you're ready by then, I could come to your place too, and we could get your truck ready for T2S.
    I've been on the lookout for a cheap spare 33 for you too. What size wheels you have laying around without a tire? Those 33's I grabbed from @TX-TRD1stGEN are 285/70r17 IIRC, but even a 285/75r16 would make a suitable spare for ya.
  17. Feb 18, 2025 at 6:29 PM
    Jack McCarthy
    Bill
    North of Boston
    I guess I confused it with E85 which I thought was the same but obviously not. I wasn’t aware E85 was 51-83% ethanol. I was thinking that it was 85% gasoline and 15% ethanol. So confusing.
  18. Feb 18, 2025 at 6:41 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    +1 notch on the front, bastard pack, & bitchelins.
  19. Feb 18, 2025 at 6:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You're going to run the 30.5's instead of the 32.7's?
  20. Feb 18, 2025 at 7:04 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    They havent been a problem yet.
  21. Feb 18, 2025 at 7:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Well at least you'll save on fuel.
  22. Feb 19, 2025 at 4:53 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    You aren't the only one. Sheetz here will drop the E15 to $1.99/gallon randomly and all of then people get in an uproar that it will ruin peoples vehicles.
  23. Feb 19, 2025 at 4:58 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Fell off a ladder from about 4 feet up at work last night 0 stars, will hopefully not be repeating.
    Couple scrapes and a impressive bruise on my left side but ok otherwise. Except for my pride, that is in shambles.
    Accident report filed of course
  24. Feb 19, 2025 at 5:02 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Texas crew:
    G_unit3000, bmf4069 and FrenchToasty like this.
  25. Feb 19, 2025 at 5:22 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn dude, be careful out there! Glad you're OK.
  26. Feb 19, 2025 at 5:30 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Me and Beau both seen it, but we also already have em. :)
    I paid that much for two sets of em before covid. And mine weren't used.
    Cool he got em re-coated, but he's asking damn the near new price from DD.
    What ever happened to that dude that was working on some headers?
    Thundra04 likes this.
  27. Feb 19, 2025 at 5:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, I saw it too. I was gonna post it but like assdawg said, that price. wowee.
    IIRC, it was @BluegrapeVr6 working on the headers?
  28. Feb 19, 2025 at 5:48 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Fawkking spring cant come soon enough. Currently 3 degrees, and another 72 hours before we will be above freezing. It wouldn't be so bad if we had a consistent winter, but I was in shorts and a t shirt a couple of days last week.
  29. Feb 19, 2025 at 5:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah it shifts so often, that you can never get used to it, and if you're like me, I tend to get mildly ill nearly every time the weather shifts from one end of the spectrum to the other. This weekend I was in my Crocs and shorts. Last night I was freezing my ass off at work
    JakeJake[QUOTED] likes this.
  30. Feb 19, 2025 at 5:55 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Fuck man, I hate the heat, but this is ridiculous. This weather needs to stop with the powerball ass numbers. 80! 32! 6! 45! 69! I need to put my fuel pump in! I might be able to on Friday. I dunno.
