  1. Jan 13, 2025 at 5:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    txagg likes this.
  2. Jan 13, 2025 at 5:23 PM
    The part numbers I gave you are from Denso, who makes the radiator for Toyota, and Toyota's EPC actual part number for a 2006 DC V8/2WD.
    I'm not saying the part number you gave is wrong, but the picture is wrong. I do see a couple of dealer websites online saying that radiator part you listed is good for V8 Sequioa 00-07 and supposedly Tundra 00-06, but it says "for double cab", but DC wasn't made until 2004.
    I trust my number direct from the EPC. I don't trust random dealer website part number.
  3. Jan 13, 2025 at 5:36 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    thanks guys. People have had good luck with these rads from rock auto? I’ve gotten a few things from them that the packages have been through the wringer and didn’t want to worry about having to send back a damaged part. Especially something as delicate and with the surface area as a radiator.
  4. Jan 13, 2025 at 6:05 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I purchased my Denso Rad from RA Dec of 2023. One of the trans line inlets was slightly bent, but just slightly. The surface of the rad was perfectly fine. Not that it means they will pay attention, but the box IS marked fragile.
  5. Jan 13, 2025 at 6:10 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    A full sized american truck with an 8' long bed can just barely carry a full cord...IF the wood is meticulously stacked to be precariously well over the top of the height of the cab.... Then that would be close to a full cord. Count on loosing many rounds on the highway on the way home too. Pretty much the only way to fit 1 cord of wood in a full sized 8' bed is with side boards installed on the bed rails.
  6. Jan 13, 2025 at 7:27 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mine came in fine as well.
    Voss, BroHon and FrenchToasty like this.
  7. Jan 13, 2025 at 7:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've been wanting to finally install one of the sets of blacked out headlights/corners I got from Beau and Ryan recently. I've already modified them and installed the CoLight mini projector LEDs. But I've only got one day off per week all month and last week it was 40°F and raining. This week it's supposed to be cold and raining. Damnit... I put this off for too long. I got to see first hand how bright the CoLights are on Frank's truck and Josh's truck. They definitely looked good to me, from in front and the passenger seat.
  8. Jan 13, 2025 at 7:55 PM
    They are awesome
  9. Jan 13, 2025 at 8:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I stand corrected, now it's showing no rain Thursday. The problem with Texas weather is its unpredictable and can change minute by minute. That especially applies to the coast.
  10. Jan 13, 2025 at 9:13 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I’ve purchased two radiators from RockAuto, and both times they came very slightly damaged. Never had any issue with the core/fins and both have worked fine for years.
  11. Jan 13, 2025 at 9:18 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I haven’t heard of these headlights. Do I need them? I thought my DC headlights were actually pretty good for stocks
  12. Jan 13, 2025 at 9:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean it's up to you. They aren't too expensive. I'm not impressed with the light output on the halogens on my 03. Especially after one of the expensive silver stars burned out and I replaced it with a cheapo I had laying around the garage. Doesn't help my OEM headlights were a little rough.
    https://youtu.be/vDi-fIp0jkw?si=aPeuQhk1XsSiMLpF
    https://m.youtube.com/watch?v=5QAYWycrOyU&pp=ygUOQ29saWdodCB0aW1kcmE=
    CodyP[QUOTED] and G_unit3000 like this.
  13. Jan 13, 2025 at 9:24 PM
    FiatRunner
    Jack
    Built this cabinet specifically for all of my drafting/modeling supplies. I salvaged an old well-built cabinet to make the box and the drawers are all 1/2” ply that I had laying around.
    I’m an architecture student and I use hundreds of pens, knives, pencils, rulers, glues, you name it. I needed something that could keep my stuff organized and would fit in my small studio space, but also be strong and work well for the next 5 years.
    The box is really nice 3/4” Birch plywood. It’s really sturdy. It’s got full extension drawer slides and strong casters on the bottom so it can be moved. I might paint it- but I’m kinda liking the bare plywood look. To quote Tom Sachs: “steel is the king of all building materials. Plywood is the queen.”
  14. Jan 13, 2025 at 9:34 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Made something similar, but larger for my drill press 8 or 10 years ago. You can see it at the far right in this picture. It’s one of the most useful things I’ve ever made. I’m a big fan of personalized items made for utility. Explains the first gen purchase too…IMG_1854.jpg
  15. Jan 13, 2025 at 9:36 PM
    FiatRunner
    Jack
    For the price- which is around $60, they’re awesome. Instead of a LED bulb inside a halogen housing, which requires the beam of light to be reflected multiple times, the projectors use a lens to amplify the beam and provide a very sharp cutoff while retaining crazy brightness and power.
    What’s really nice about these is that you get very good performance with minimal modification to your headlight housings, and a stock look. A full size projector retrofit will provide better results but will cost like four times as much (I think).
  16. Jan 13, 2025 at 9:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  17. Jan 13, 2025 at 9:43 PM
    FiatRunner
    Jack
    Exactly! My dad used to own/operate a custom furniture business. We had a whole woodshop with planer/jointer/table saw/bandsaw/etc. The whole nine.
    We built so many custom cabinets- for hardware, tools, parts, you name it. Built exactly to fit our needs. You could work SO efficiently in that space. Nothing beats a custom plywood cabinet.
    I wish I had a photo of the woodshop- my dad went back to his previous job so he closed up shop.
    txagg, BroHon and FrenchToasty like this.
  18. Jan 14, 2025 at 12:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What brand bellows do y'all recommend for tie rods, besides the obvious OEM?
    Or do any of y'all reuse your bellows when changing inner tie rods?
    jerryallday likes this.
  19. Jan 14, 2025 at 3:25 AM
    If the OE is still serviceable, run it. I bought a Detroit axle one for the drivers side since mine was fuckered, but my passenger is still stock. I tried a Rockauto special there first when I redid my front end years ago and it fell apart over the last 5-6 years.
  20. Jan 14, 2025 at 3:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    shifty`, JakeJake, KNABORES and 2 others like this.
  21. Jan 14, 2025 at 5:36 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    If they are in okay condition with no holes I wouldn't hesitate to reuse them. I planned on using Moog, but ended up with going oem as the sale price isn't that bad.
  22. Jan 14, 2025 at 7:06 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Yeah I did some custom woodwork for a couple years part time. Had all the tools and loved it. But I knew it was gonna be very tough to support a family that way, so I ended up selling a lot and getting a more stable job. I do smaller stuff now like chairs/stools when I have time. Next to the best gen, my woodworking tools are some of the only other material possessions that I really love. I have a 1940's Delta lathe that I refurbished and a 1968 powermatic bandsaw that is just wicked cool.
    FiatRunner[QUOTED] and JakeJake like this.
  23. Jan 14, 2025 at 7:44 AM
    Good watch. Close friend just had to replace the D1S bulbs in her Bimmer. Helped her out by spending my Speedperks bucks to get her halogens because her VIN said that’s what it took. Apparently you can’t rely on the VIN as stores and major light brands suggested.
    Needless to say we almost bought the DMEX bulbs in that video. Ended up going with OSRAM, I believe. It’s what the local P-car/Bimmer shop recommended for bang vs. buck. I didn’t install. Too much hassle, gotta jack the car, remove the wheel, remove the fender liner, then start tearing open the light bulb housing. This is exactly the type of crap I can’t stand about BMWs.
  24. Jan 14, 2025 at 7:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    WTF is p-car?
  25. Jan 14, 2025 at 8:19 AM
    NUDRAT[OP] likes this.
  26. Jan 14, 2025 at 8:23 AM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    bmf4069 and Dakillacore like this.
  27. Jan 14, 2025 at 8:25 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I didn't know either :rofl::fistbump:
  28. Jan 14, 2025 at 8:29 AM
    RockAuto Discount Code: 291154072250618065
    Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied to shipping, gift certificates, or to an order once it is marked as shipped.
    How did you hear about us
    Your code expires on February 14, 2025, 12:00 Midnight CT, so do not wait!
    Fragman, tpope, bmf4069 and 1 other person like this.
  29. Jan 14, 2025 at 8:43 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    I believe Toyota part numbers with an 'AZ' in them are actually budget/economy versions and not the same as the original OEM spec. I guess it's to meet the need for cheaper parts for these older vehicles? I'd spring the extra for the Denso.
  30. Jan 14, 2025 at 8:50 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I have a set of moog, inner, and boots I never used if you are interested. They just been sitting collecting dust. Bought from rockauto
