  1. Dec 29, 2024 at 8:04 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Cleaning my trucks naughty bits.
    seems like my front driverside brake is dragging a bit more than i’d like.
    Got an audience of no-good, dirty, beggers.
    Think i could build a coop & ‘adopt’ these aholes? Is chicken rustling a thing?
  2. Dec 29, 2024 at 8:23 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    They are just a piece of 1 1/2 pipe from the factory. I love the sound, but that could just be some Stockholm syndrome from hearing it for hours on end.
    https://youtu.be/_NnV0CL9j-4?si=YcwkYxVqGYzTA1qF&t=291
  3. Dec 29, 2024 at 8:27 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    if it was used as a generator, what kinda kw could it push?
  4. Dec 29, 2024 at 8:48 AM
    JakeJake
    2000 Tundra AC 4X4
    Im the wrong kinda sparky for that :rofl:
    rated for 40v 200 amps 60% duty cycle.
    Oh and its DC Constant current only
  5. Dec 29, 2024 at 8:52 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  6. Dec 29, 2024 at 9:20 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Hey, i wasnt paying attention a few days ago when a discussion about lugnuts came up, what are the lugs for aluminum wheels called? And do the steelies call for conical or the rounded ones? My stockers seem to snug up fine, but that might be because of the paint. & the washers would rattle.
    i think i’d like my patricks powdercoated white. It’d give me an excuse to wash my truck more often.
    Still need to find the right grey or black for my offroad shoes.
    Verified with an unpainted wheel that the cone on the stock lugs seat right.
  7. Dec 29, 2024 at 9:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    After procrastinating for 13 months(@KNABORES would be proud), I'm finally starting on the front end suspension rebuild for Ravioli. New LCA's, LBJ' and outer tie rods. 161k miles. I have to lower the subframe to remove the control arms. Should be fun.
  8. Dec 29, 2024 at 9:29 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    May the mangling gods be with you
  9. Dec 29, 2024 at 10:18 AM
    See this? It's your dipstick housing going into the pan.
    See all that oil on it, and how the oil is pretty much saturating it? Your valve cover gaskets are likely leaking at the front corner, exactly where mine were, at the front corner of the cam tower, and the oil is dripping down the oil dipstick mount, is clearly boating the top of the oil pain, and it looks like it's running down the lip. If you have that much leakage at the front of the valve covers, I can almost guarantee you have it leaking from the rears similarly. See here and note the oil coming from the front corner bolt of my valve cover, and all the oil built up on the arm of the dipstick support, and see here along the valve cover/manifold heat flange where oil was puddling when I did nothing about it.
  10. Dec 29, 2024 at 10:24 AM
    Also notice here, way higher up, you clearly have oil coming from above, you can see the residue in the circle, I'd be looking higher up on the block from this point to see the origin:
    My suspicion is, you're leaking at the half-moon plugs which live on the back of the head here and pull up/out, they get pulled, cleaned, and resealed with FIPG any time you do valve cover gaskets. You can probably check this easily with a mirror, or with your phone in selfie mode, look for oil dripping on the back of the driver's side head, then running down the block to wick/soak everything below. Oil does travel in metal, via capillary action.
  11. Dec 29, 2024 at 10:26 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Thanks as always! I am going to borrow my dad's endoscope to do some real digging once I get it from him.
    Hoping it's just the items that you said. What difficulty level is the head gasket replacement?
  12. Dec 29, 2024 at 10:52 AM
    @Dakillacore here's another really bad example where someone let their VC gaskets go way too long: https://www.tundras.com/threads/recent-owner-questions.130108/#post-3315260
    Not head gasket. Valve cover gasket. It's not bad. Took me about 90 minutes. Again, extending a branch here, if we can sync up on a day, I'm happy to help.
  13. Dec 29, 2024 at 11:02 AM
    Dakillacore
    Georgia
    Yeah, sorry I meant valve cover gasket. Not sure where that slipped into my mind.
    And absolutely, man. Anytime you have the free time we can link up. I'm off some days during the week so we can plan a time then. We have a rotating 4 day work week at my place now. I'll compensate you for your time and experience you just name the price! I'll work around your time.
    I can get the materials kit ahead of time to be ready.
    shifty`[QUOTED] likes this.
  14. Dec 29, 2024 at 11:04 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    low ball him. He’s worth so much, mere mortals arent worth the effort.
  15. Dec 29, 2024 at 11:05 AM
    It's virtually impossible to pop off the dustcaps without denting them to some degree. They're on there good & tight. Work around the clock, 3/6/9/12 and tap to lift the cap away from the hub. When you got a 3-4mm gap, screwdriver in there and twist at 3/6/9/12.
    On torque for CV nut, max it out, check the cotter position, then bump it forward at least one more cotter position, or two if it's easy enough.
    On the bolts and misc, pulling from my coilover install pics here on the forum:
    I remember distinctly being here, ready to pop the rotor off, and install my new coilover, before popping off the UCA and pressing out the UBJ: https://tnstatic.net/attachments/upload_2023-9-2_14-42-31-png.912110/
    FU UBJ! So easy to pop them free with the knuckle on your floor https://tnstatic.net/attachments/upload_2023-9-2_18-29-24-png.912224/
    Proof it's easier to install the lower shock bolt (and strut/coilover totally) with the knuckle out, no CV axle in the way, and the swaybar disco'd: https://tnstatic.net/attachments/img_9049-jpg.912377/
    DarkMint likes this.
  16. Dec 29, 2024 at 11:05 AM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    This is the good stuff
    Voss[QUOTED] likes this.
  17. Dec 29, 2024 at 11:08 AM
    Dakillacore
    Georgia
    I might have to sign into an indentured servitude contract with him. We'll see
  18. Dec 29, 2024 at 11:11 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Doubt he’s looking for first borns, but maybe offer an arm or a leg.
  19. Dec 29, 2024 at 11:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    These bushings don't look as bad as I thought. I'm putting Toyota arms back in.
    bmf4069 and BroHon like this.
  20. Dec 29, 2024 at 11:52 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  21. Dec 29, 2024 at 12:12 PM
    I mean, they weren’t more than a couple years from being trashed either! Good on ya for the proactive action.
    FrenchToasty likes this.
  22. Dec 29, 2024 at 12:18 PM
    Dakillacore
    Georgia
    It does look more like the valve cover gasket the deeper I inspect. This is the driver side.
  23. Dec 29, 2024 at 1:57 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Awesome, thanks for the info and pics!
  24. Dec 29, 2024 at 2:38 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Best tool I’ve found is a wood chisel about 1 inch wide. Carefully tap the sharp edge bevel forward around the perimeter between the lip and hub. Don’t use your high quality woodworking tools however. Get a cheap wood chisel for this.
    on my 68 Porsche I put a large hose clamp around the cap and then pull on that with a pair of channel locks.
  25. Dec 29, 2024 at 2:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean if they're free range and on your property, build em a lay box, with a roof, and see if they leave you any presents. Possession Is 9/10th of the law.
    I need to clean my trucks naughty bits. Been putting it off for weeks. Typically really.
  26. Dec 29, 2024 at 2:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dakillacore likes this.
  27. Dec 29, 2024 at 3:32 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    +1. This ^^^
    TXTundraGuy23 and shifty` like this.
  28. Dec 29, 2024 at 3:52 PM
    Firing a pot of year end chili up just how my homeboys in Texas LOVE IT. Tons of beans, no meat, and a heaping glob of chile in adobo. :rofl:
  29. Dec 29, 2024 at 4:02 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What's the saying? Something about engineers, mechanics and virgins?
    I'm almost done but it's impossible to get a socket on this LCA bolt. Transmission pan is in the way. Best I can do is a box end wrench. I'm supposed to be torquing this bastard to 172. That ain't happening.
    My only other option would be to lower the subframe again, torque it, then put it back. That was a giant hassle earlier.
    Would you guys go as hard as I can with the wrench and send it?
  30. Dec 29, 2024 at 4:04 PM
    FrenchToasty
    Mo
    Bone stock
    Wobble/u joint extension? Good n tite if you can’t
    shifty` and Jack McCarthy like this.
