  1. Dec 21, 2024 at 6:03 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Yup that it is. There are a lot of wild names for paint. The newer models with 040 are called "Ice white" now instead of Super white, but it's the same color.
    Toyota has paint names that range from Blizzard Pearl, Ooh La La Rouge, Voodoo Blue, Predawn Gray Mica(1H1), Magnetic Gray(1G3), Underground (New dark gray), Blueprint(8X8) Classic Silver and so forth.
  2. Dec 21, 2024 at 6:03 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Maybe there's an aluminum option?
    Like this, but with more lid.
    The big screw lid would be a challenge in aluminum. A man can dream.
  3. Dec 21, 2024 at 6:27 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Maybe when I buy a house with a garage I’ll get one of these Mishimoto oil catch pans I can hand pump into a separate container. Lifetime guarantee.
  4. Dec 21, 2024 at 7:01 AM
    shifty` Inside his chest they found ten thousand pencils
    Man, that takes up a lotta floor space though!
  5. Dec 21, 2024 at 7:27 AM
    Jack McCarthy
    Bill
    North of Boston
    I’ll keep it stored under the Tundra next to my new vehicle. ;)
    FrenchToasty and shifty`[QUOTED] like this.
  6. Dec 21, 2024 at 7:51 AM
    Anyone want these yellow fogs? Plug-and-play option. They'll come preloaded with new halogens. You pay the ride and they're yours.
  7. Dec 21, 2024 at 8:36 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Hey quick question does anyone have thread for rear wheel bearing part numbers? I plan to do seals as well but I’m not 100% what else I will need. Thank you
  8. Dec 21, 2024 at 8:40 AM
    Jack McCarthy
    Bill
    North of Boston
    Wow. They’ve got a new term for people like me who badge into work in the morning, get their coffee, hit a meeting or two, socialize with a few coworkers and leave at lunch to finish out the day at home working online.
    It’s now called “coffee badging”. Who knew it was a trend? :pccoffee:
    bmf4069, 455h0le_dachshund and BroHon like this.
  9. Dec 21, 2024 at 8:42 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This is what I used, double check with your VIN when you order. You might not need everything I listed here, but I needed a tone ring and retainers because mine were damaged.
    • 90363-40068 - BEARING, RADIAL BALL (x2)
    • 42423-20010 - RETAINER, RR AXLE BE (x4)
    • 90301-88077 - RING, O (x2)
    • 90520-36045 - RING, SHAFT SNAP (x2)
    • 43517-35010 - ROTOR, SKID CONTROL (x2) - Tone Ring
    • 90313-54001 - SEAL, TYPE K OIL (x2) - Outer Axle Seal
    • 90310-50006 - SEAL, TYPE S OIL (x2) - Inner Axle Seal *recommend to order a few extras in case they're damaged during install
    bmf4069, Voss, Dakillacore and 5 others like this.
  10. Dec 21, 2024 at 8:46 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Might have to change my title. Looks like a good day to quit kicking this can.
    big eff. We didnt freeze last night, and this is a bigger drip than normal. Think it might be the water pump.
    not the usual suspect.
    Got wetness in the valley of the block, dripping off the a/c compressor, and off the bellhousing.
    front drip, and rear drip.
    Why is the #5 exhaust flange wet?
    damp on the back side of the oil pan, too.
    might be getting myself worked up over nothing. Got wet spots under the rad & t-stat worm clamps (no clue who replaced the spring clamps) warming it up now, to see if i can find an active drip. Front of the engine is dry, and rear coolant crossover looks dry from above. No bubbles in the coolant...
  11. Dec 21, 2024 at 8:46 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    So well organized thank you, I appreciate it very much
  12. Dec 21, 2024 at 10:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Drove up to Madisonville to meet Mamba at the Buccee's to trade my old LSD for some headlights. I left about ten mins later than I planned and got here about 30 mins earlier than expected. Racetrucks gotta race...
    Got like 18mpg. Found out I hit 3k rpm at about 85mph, speedo says 90.
    I think my oil pressure gauge started working again.
  13. Dec 21, 2024 at 10:17 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    I gotta get me one of those things
  14. Dec 21, 2024 at 10:33 AM
    Dakillacore
    Georgia
    I'll grab em from ya. Mine are wore out.
    shifty`[QUOTED] likes this.
  15. Dec 21, 2024 at 10:49 AM
    That looks more like oil to me. Like your VC gaskets are leaking.
    Sirfive[QUOTED] likes this.
  16. Dec 21, 2024 at 10:52 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I know about the vc gaskets. But the coolant is what i'm focusing on today. You can see coolant on the front diff bracket in the last pic & on the crossmember in the 2nd pic.
    shifty` likes this.
  17. Dec 21, 2024 at 11:12 AM
    Alltimehigh
    Alltimehigh New Member
    Gladly take them off your hands.
  18. Dec 21, 2024 at 11:15 AM
    Dakillacore
    Georgia
    That really is an ugly Christmas sweater.
  19. Dec 21, 2024 at 11:19 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    New struts, plugs, O2 sensors, and snow tires for the daughters Sebring.
    The DeWalt big chungus impact made the struts a breeze, I'd still be fighting with the pinch bolts if I was doing it by hand.
    I can't even see the rear O2 sensors so that'll be fun.
    bmf4069, shifty` and Dakillacore like this.
  20. Dec 21, 2024 at 11:59 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Fumoto valve and just drain it back into the old containers?
    bmf4069 and BroHon like this.
  21. Dec 21, 2024 at 12:01 PM
    Jack McCarthy
    Bill
    North of Boston
    That doesn’t work since an oil change is 1+2/5 of a 5 quart jug. Too expensive to buy the individual quarts.
  22. Dec 21, 2024 at 12:26 PM
    If DKC a couple posts above you taps out on them, or we can't make it work, you're 2nd on the list!
    I mean, fitting right? Put the ugliest of the 1st gens on an ugly xmas sweater, amirite?
  23. Dec 21, 2024 at 1:25 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    We just got back to the house. Thank you for your generosity and your offering to meet me halfway :thumbsup:
    Now I can claim that assdog traded me some LSD :rofl:
  24. Dec 21, 2024 at 1:46 PM
    Jack McCarthy
    Bill
    North of Boston
    Im really starting to despise UPS now. Signed up for their premium service to have a package held at a customer service facility.
    Apparently not and option as of Dec 1st with no return date.
    Tried delaying a delivery date from Wednesday to today.
    Request accepted. No package delivered. Seems it’s because my local office isn’t open today for delivery.
    Delivery has now defaulted to Monday when I’m not here. :annoyed:
    Dakillacore likes this.
  25. Dec 21, 2024 at 1:49 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    She might be ugly, but she does everything you want her to :D
  26. Dec 21, 2024 at 5:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I have the 16 qt flo-tool drain pan. The drain plug doesn’t hold tight and the vent refuses to stay closed. I guess I shouldn’t expect much. For ten bucks.
  27. Dec 21, 2024 at 5:59 PM
    For me, the cap and drain plug are a bit squirrely The cap tightens but will keep spinning if you push it too hard. The drain plug has a similar sweet spot on it.
    The real winner is this one, yellow cap but a bit small which I'm pretty sure I got from Summit Racing, directly at the McDonough store when it first opened. It's made by a company "Scepter", based out of Canada. I checked their website, it doesn't appear to be made anymore. It's stout as hell, very thick walled. They do have a similar product, a 12-quart with a green cap and a large green cap on the side opening. I wonder if it's equally good?
  28. Dec 21, 2024 at 6:04 PM
    Jack McCarthy and FrenchToasty like this.
  29. Dec 21, 2024 at 7:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :hattip:
    Glad you made it back. I decided to stay in Huntsville.
  30. Dec 21, 2024 at 8:41 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
