  1. Nov 21, 2024 at 6:59 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Cylinder deactivation is a lot more complicated than just some plug and play ordeal. You gotta find ways to deactivate valves as well as cylinders. And adjust fuel/air accordingly. Also gotta make sure the cylinders your shutting off keep everything properly balanced in the engine.
    And that's to save some MPG. If you fuck this up. That's a toasted engine.
    high risk for not that much reward.
    bmf4069 and BroHon like this.
  2. Nov 21, 2024 at 7:19 AM
    daveeasa
    David
    I hear you guys. But I do wonder how the tech evolves over the next two decades. Obviously not remotely ready for any sort of retrofit today.
  3. Nov 21, 2024 at 7:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    One crank per bank maybe. Shit off the crank and shut off the entire bank.
    daveeasa[QUOTED] likes this.
  4. Nov 21, 2024 at 7:30 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The ol crank bank
    bmf4069, BroHon and 455h0le_dachshund like this.
  5. Nov 21, 2024 at 7:35 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds expensive. I’ll have to check if they have a 1st gen model.
  6. Nov 21, 2024 at 7:37 AM
    Jack McCarthy
    Bill
    North of Boston
    So how many people pass you doing 65-70 mph yet? (Or is it backroads only?)
  7. Nov 21, 2024 at 7:38 AM
    a dozen or more. Also the ones that pull out in front of you from side roads and can’t get traction to get moving nearly causing you to rear end them or run off in the ditch count was about 3 or 4
  8. Nov 21, 2024 at 7:51 AM
    shifty` Inside his chest they found ten thousand pencils
    Id like to make a withdrawal, please.
  9. Nov 21, 2024 at 7:56 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Those of you with the dancing cams might be able to tune in an adkinson cycle, might need different pistons & a blower for the lean burn, but shutting the intake valve early effectively turns the engine into a smaller air pump.
    ok, had that backwards, intake valve stays open longer and the compression stroke pushes some of the intake charge back into the intake manifold.
    And like uncle ben said, 'less air requires less fuel' or something.
    bmf4069 and 455h0le_dachshund like this.
  10. Nov 21, 2024 at 7:59 AM
    Ah yes. Or was it Colt Seaver? FML!
  11. Nov 21, 2024 at 8:08 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Growing Pains?
    That guy named Boner was hilarious.
  12. Nov 21, 2024 at 8:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I have Trekz. Jawbone is I think another brand.
  13. Nov 21, 2024 at 8:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Little early for Missouri to get snow.
  14. Nov 21, 2024 at 8:50 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yes! Show us your......on second thought, I don't need a ban.
  15. Nov 21, 2024 at 9:04 AM
    daveeasa
    David
    I’m thinking similar to ECT buttons. Eco vs turbo / performance modes. Might be nice to have options. I like my v8 torque but for long road trips I feel significant guilt over excessive fuel burn.
  16. Nov 21, 2024 at 9:04 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Anybody know how much travel ,5100's and/or 5160's yield on our trucks? I can't seem to find that info
  17. Nov 21, 2024 at 9:06 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't feel guilty. Jets and ships use way more fuel. We should be able to drive our v8's guilt free.
    BroHon likes this.
  18. Nov 21, 2024 at 9:12 AM
    Think it adds about an inch of travel over stock setup iirc
  19. Nov 21, 2024 at 9:20 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So how much is that?
    Only reason I ask is the Archive garage shock relocation says up to 12" travel and the kings they recommend are 10" travel, while the foxes are 12". Weighing my
    options and want to know it 10 is worth it or if I should mix n match my Kings with fox for the full 12.
  20. Nov 21, 2024 at 9:22 AM
    Outbound
    Aaron
    Northern Alberta
    Aftershokz.
    https://shokz.com/
    FrenchToasty[QUOTED] and bmf4069 like this.
  21. Nov 21, 2024 at 9:22 AM
    daveeasa
    David
    The math on jets is interesting. High burn rate of expensive fuel but per passenger per mile it’s pretty decent.
    My guilt is Tundra vs Tacoma on a long road trip. The Tundra is very comfortable and has the best sleeping option. But Taco #1 is better on fuel and the wimp 2wd 4 cylinder Taco is almost decent fuel wise on the highway.
    Really that’s the one to optimize for road trips. Bed replacement with waterproof pod for sleeping and some sort of EV / hybrid for urban driving to bump up MPG’s and it’s killer. But not quite as comfortable and max 2 passenger.
  22. Nov 21, 2024 at 9:24 AM
    daveeasa
    David
    I went fox. In case you want to test drive. I have a legit clunk I haven’t chased down yet. Not sure if gears or axle wrap from relocate.
  23. Nov 21, 2024 at 9:24 AM
    I see reports of 10” of travel on 5100s on T4Rs
  24. Nov 21, 2024 at 9:27 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Marlin Crawler’s Totally Integrated Transmissions?
  25. Nov 21, 2024 at 9:32 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I've always been a fan of California's Ubiquitous Natural Tundra Scene.
  26. Nov 21, 2024 at 9:36 AM
    Minnealopiss, Breau
    BroHon and bmf4069[QUOTED] like this.
  27. Nov 21, 2024 at 9:52 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If I'm ever out in the PNW I'll let you know haha
  28. Nov 21, 2024 at 9:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok so likely ours is a little less I would imagine.
    Edit: side note, I talked to Toy Lex today and Juan said my 03 should be ready Tuesday.
    :muscleflexing:
    KNABORES[QUOTED] and bmf4069 like this.
  29. Nov 21, 2024 at 10:18 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    8.5"ish.
  30. Nov 21, 2024 at 10:25 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    I've decided to keep my eyes out for a set of these. I like them and believe I can make them work with my future paint scheme, even if they're the black or grey ones. Also added a remote trans cooler to my to-do list. Never did like the idea of it being integrated into the radiator.
