  1. Aug 25, 2020 at 3:40 PM
    #7201
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  2. Aug 25, 2020 at 3:58 PM
    #7202
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  3. Aug 25, 2020 at 4:05 PM
    #7203
    Festerw
    Festerw New Member
    04 Tundra DC
    Wouldn't be hard to make. Some 2" flat stock aluminum, cut, bend, and drill a few holes.
  4. Aug 25, 2020 at 5:01 PM
    #7204
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    @FirstGenVol 3mpg is pretty drastic, was he running with flat tires lol. I would be willing to bet you would get more wind noise than mpg loss. I'd say get 1x1 square Alu tubing and make feet to raise it up about 1". Cut 45° angles on both sides of the feet so you have easy access to the mounting bolts head. It looks good you just have to upgrade hardwear to stainless and get that diamond plate on the bottom of the rack to up the load capacity. If you make er look good I'll get one too
    Pucks18 likes this.
  5. Aug 25, 2020 at 5:14 PM
    #7205
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah I just spoke to a few people and they didn't notice any MPG dip. I think I'll give the basket a shot. Might as well try it.
  6. Aug 25, 2020 at 5:20 PM
    #7206
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @FirstGenVol you should think about making some kind of wind fairing, unless I didn’t see it, you will get a mpg loss.......but the fairing might help with wind noise and some mpg action. I have a roof rack on the 4runner......I know things.
    bmf4069, Tundra2 and Darkness like this.
  7. Aug 25, 2020 at 5:57 PM
    #7207
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    https://youtu.be/55-B_EICis8
    It came with a fairing but the mounting bolts are too short. I'll have to run out and get better hardware.
    bmf4069 likes this.
  8. Aug 25, 2020 at 6:27 PM
    #7208
    FrenchToasty
    Mo
    Bone stock
    Also, there is a dealer, Raingler nets, that is top knotch, if you end up liking it and want some better options for securing stuff, they make bad ass cargo webbing for roof racks, and all kinds of other cool stuff to actually. You can customize any way you want, and great customer service
    bmf4069 and FirstGenVol[QUOTED] like this.
  9. Aug 25, 2020 at 8:41 PM
    #7209
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Aug 26, 2020 at 4:52 AM
    #7210
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Since I pulled my cluster out, I've been curious about something.
    To satisfy my curiosity I'm gonna ask you all:
    The experts.​
    I noticed my cluster has a spot for a low washer fluid level light. Recently, I ran out of fluid. I found out because she quit squirting.
    The light has never worked for me.
    How hard would it be to add the parts needed to make the loght come on as needed?
    My gut instinct says that it would be to replace the washer fluid reservoir with one that has a float sensor in it.
    I'm not sure, and am mainly curious.
    What do you all think? :)
  11. Aug 26, 2020 at 4:55 AM
    #7211
    Professional Hand Model
    Hand Protectors
    Check your little sensor thingy on the rez first before reinventing the wheel. Meter test, check connection, wires, etc. Report back!
    Tundra2[QUOTED] likes this.
  12. Aug 26, 2020 at 5:17 AM
    #7212
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I just assumed I didn't have it. Will consult FSM, and then tinker.
  13. Aug 26, 2020 at 6:29 AM
    #7213
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okay, after a wheel well liner mangling that even @bmf4069 would be proud of I've determined I have a washer pump. Lol
    Before I realized it was the washer pump I checked the wiring harness after I got the brown recluse to leave... it read zero volts which puzzled me then I saw the washer hose.
    If I've got a "float sensor" than its in the front where I can't see.
    Can't even see it with the bumper removed. Hmm.
    FSM was little help...
    My washer motor is in the rear of the reservoir. According to those two documents they are one, and the same. The connector on the pump has 2 pins, and the wiring connector has a possible 3.
    Guessing that 3rd pin is the sensor wire.
    Edit:
    Hit pay dirt, but now where is it... if I've got it...
  14. Aug 26, 2020 at 7:39 AM
    #7214
    Wonder if it's possible it's using the liquid in the tank as the conduit or the float is internal to the pump. The latter would be more typical.
    Anyway, drain the fluid, siphon it. See if the light in the dash lights up. It's way easier than dicking around with a DMM man!
  15. Aug 26, 2020 at 8:29 AM
    #7215
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Aug 26, 2020 at 8:35 AM
    #7216
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm thinking its a different sensor instead of internal on the pump. I'm no expert, and might be wrong.
    Seen below is the pump per FSM
    Seen below is the washer fluid level switch per FSM.
    20200826_083237.jpgIt looks different to me, maybe I'm just tired..
    I would have to agree, draining it bone dry would be easier than a DMM. I ran it until the pump couldn't pump anymore with no light sometime last week. Then again, I'm not even sure I had a bulb in.
    May have to tinker with that this weekend.
    Edit: https://www.ebay.com/itm/233668171171
    Just wanted to see what it looked like. :)
  17. Aug 26, 2020 at 8:42 AM
    #7217
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My new corollas new engine showed up today.
    amazing for $900
  18. Aug 26, 2020 at 8:50 AM
    #7218
    Casper421
    In the woods
    06 DC
    So clean! 12k miles you said?
    empty_lord[QUOTED] likes this.
  19. Aug 26, 2020 at 9:44 AM
    #7219
    empty_lord
    05 rollover special
    Yup
    Casper421[QUOTED] likes this.
  20. Aug 26, 2020 at 10:51 AM
    #7220
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hmmm.......
  21. Aug 26, 2020 at 11:27 AM
    #7221
    Hand Protectors
    Waiting for it...
    GODZILLA, Tundra2, shifty` and 2 others like this.
  22. Aug 26, 2020 at 11:51 AM
    #7222
    Have you tried probing around inside with your finger or something more significant?
  23. Aug 26, 2020 at 12:00 PM
    #7223
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    There it is...
    artsr2002, Tundra2, shifty` and 3 others like this.
  24. Aug 26, 2020 at 12:34 PM
    #7224
    Hand Protectors
    Maybe put on his snorkles?
  25. Aug 26, 2020 at 3:32 PM
    #7225
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I dunno, he's got them cold fingers from the dry ice gun thingy. That may not work.
  26. Aug 26, 2020 at 5:09 PM
    #7226
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  27. Aug 26, 2020 at 5:23 PM
    #7227
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    https://youtu.be/lmNSS0jtu0E?t=13
    Unfortunately, that wasn't significant enough either...
    bmf4069 and FrenchToasty like this.
  28. Aug 26, 2020 at 6:16 PM
    #7228
    FrenchToasty
    Mo
    Bone stock
    This thread got jacked!
    bmf4069 and Tundra2 like this.
  29. Aug 26, 2020 at 6:37 PM
    #7229
    ... off!
    Hooptytrix, bmf4069, Tundra2 and 3 others like this.
  30. Aug 26, 2020 at 7:43 PM
    #7230
    empty_lord
    05 rollover special
    [​IMG]Looks good on the inside... painting the oil pan that was scratched up to avoid rust and it should be in the car Friday evening running. First 30 minutes of life will be with 0w-20 synthetic Bulk then It’ll start its life of Mobil one extended 0w-20
