  1. Oct 22, 2024 at 1:03 PM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    Thanks, both! There is a captive washer AND lock washer on this bolt. I feel pretty confident that I can add the washer stack to a plain bolt. I just didn't have enough understanding of the language like "M6x1.00" to know what to look for.
  2. Oct 22, 2024 at 1:22 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    That's what I'd do. Most fasteners you'll encounter on the truck will be metric fasteners. They're sold in the M6-1.00x30 format
    M is metric thread designation
    6 is the thread diameter in MM
    1.00 is the thread pitch in MM
    30 is the length of the bolt in MM
    Thread pitch measures distance between threads. Pitch can vary depending on thread size. Thread pitch will also tell you how many threads per inch there are. A bolt with a 1.00mm pitch will have 25.4 threads per inch, and a 1.25mm pitch will have 20.32 threads per inch.
    Fasteners can also be graded depending on their strength. Most stuff on the truck will be Metric Class 8.8 or less, but there's no harm in using Metric Class 10.9 (commonly referred to as Grade 8)
    Further reading: https://www.fastenermart.com/understanding-metric-fasteners.html
    Thread strength: https://www.fastenermart.com/understanding-fastener-grades-and-classes.html
    O'Reilly's, Autozone, etc should have a display that sells various sizes of metric nuts and bolts in bubble packs that are metric class 10.9.
  3. Oct 22, 2024 at 4:24 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    The 4 pin alternator plug for 05/06 tundra and 05-07 sequoia, in case anyone yanks the wires out of the plug like I did on mine.
    5 years later and battery light is gone.
    bmf4069 likes this.
  4. Oct 22, 2024 at 5:42 PM
    shifty` Goons of Hazzard
    Rock Auto discount code.
    Code: 282246821250618065
    RockAuto Code Expires on November 22, 2024, 12:00 Midnight CT, so do not wait!
  5. Oct 22, 2024 at 6:11 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    455h0le_dachshund likes this.
  6. Oct 22, 2024 at 6:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Has anyone found a garage door opener solution? Our visors are too thick for the clips to work. The holder thing doesn't work either
    I've tried double sided tape but this only lasts a month or so.
  7. Oct 22, 2024 at 6:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's win win. You got free, new parts.
    I got your help on retainer. :cheers:
    I think the "truck setting" will be good for your truck. Unless you want to be a hottboi and go for something between "truck" and "rotrod", as I've read several people doing. Seems most just go with "truck" and like it. The ones that go with "hotrod" usually aren't happy with daily driving.
  8. Oct 22, 2024 at 6:22 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    We're heading to New Orleans tomorrow for T. Swift and all I know is I want an alligator po' boy.
    bmf4069 and des2mtn like this.
  9. Oct 22, 2024 at 6:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It won't stay in the garage door opener cubby?
    FrenchToasty likes this.
  10. Oct 22, 2024 at 6:34 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    New code from Rock Auto today
    282077251250479099
  11. Oct 22, 2024 at 6:38 PM
    @shifty` had a Kia mirror with home link on it.
  12. Oct 22, 2024 at 6:41 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I could have used this when I ordered my bearings this afternoon...... lol
    bmf4069 and FrenchToasty like this.
  13. Oct 22, 2024 at 6:44 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    FaFo
    bmf4069 and FishNinja[QUOTED] like this.
  14. Oct 22, 2024 at 6:51 PM
    des2mtn
    SW
    Tonto cover
    RockAuto pretty much always has a 5% off code floating on the internet, you just have to go looking for it.
    NickB_01TRD likes this.
  15. Oct 22, 2024 at 7:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It might but I would have to open it every time I need to use it. We have two garage doors. Plus the cubby door isn't that easy to open.
  16. Oct 22, 2024 at 7:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Open it?
    What you think that square in the middle is?
    Hint: it's where you push to push the garage door opener if ones inside
    KNABORES likes this.
  17. Oct 22, 2024 at 8:20 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I have mine in the same spot. It’s stayed over a year with TX heat.
  18. Oct 22, 2024 at 9:13 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
  19. Oct 23, 2024 at 4:28 AM
    Neo
    Neo New Member
    Alabama
    Dude, I just placed an order with them Monday! Next time.
  20. Oct 23, 2024 at 6:23 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Just a thought, but why not use the garage door holder clip under the trim where you have it stuck to? I'm not sure if it would even be able to be secured under it, but it's worth a shot.
  21. Oct 23, 2024 at 6:29 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm aware of how it works. That's why I mentioned we have two garage doors. If I position it inside the cubby, it can only be used to press one garage door button.
    bmf4069 likes this.
  22. Oct 23, 2024 at 6:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sounds like I need better double sided tape. I'm using the Gorilla brand I think. I had 3M before but ran out.
  23. Oct 23, 2024 at 6:34 AM
    SAGE63
    San Diego County
    I use 3m vhb to keep my solar panel mounted to my rtt. has been there for a rew years.
    FirstGenVol[QUOTED] likes this.
  24. Oct 23, 2024 at 6:36 AM
    I have. I installed a Toyota battery-powered Homelink mirror. Part number is in my signature (PT374-00210), and it pops right onto any standard windshield keystone**. However, Gentex undoubtedly sells a similar battery powered unit.
    Battery isn't serviceable but they supposedly has a 15 year lifespan similar to TPMS sensors, and I figure by then, I'll have finally gotten around to wiring in a proper, ACC powered mirror :D
    ** Some earlier model trucks used the weird Donnelly brand mirrors and would need to swap out the windshield mount​
  25. Oct 23, 2024 at 6:39 AM
    PS - you need to use "industrial strength" velcro. They sell (3M brand) it at the big box parts stores, it's what we typically used on all of our digital racks in our labs, and for tradeshows, to hold all kinds of things, including jumbo TV remotes.
    You just need a small square for something like that. Trick to it is, hit the surface you're sticking it to with an alcohol wipe before installing, the adhesive will grab better. If you've ever put coatings (303, Armor All, etc.) on the plastic surface in question, you need to remove that, alcohol will do the job.
  26. Oct 23, 2024 at 6:40 AM
  27. Oct 23, 2024 at 6:47 AM
    Dakillacore
    Georgia
    Could even us adhesion promoter wipes for added strength.
    https://www.napaonline.com/en/p/MMM06396
  28. Oct 23, 2024 at 6:52 AM
    I know I'm a nerd for doing this, but I was interested in knowing if this was just a simple alcohol wipe, so I looked up the SDS for that product.
    It would appear maybe it's not just basic Isopropyl alcohol. I'm going to assume the active ingredients are the bottom two with the ultra-long names in ultra-low concentrations, while the larger is filler. Given the organ damage warnings in the SDS with repeated exposure, uh ... I guess as long as you're not huffing them in a baggie, you should be OK? :rofl:
  29. Oct 23, 2024 at 6:57 AM
    Dakillacore
    Georgia
    Considering all of the other noxious fumes that I'm around in the body shop, I think my body doesn't mind that amount, hah. The alcohol prep wipes that we have has a disclaimer that it can cause neurological issues.....We had a guy that would clean his face with them. :rofl:
  30. Oct 23, 2024 at 6:58 AM
    I mean, that's one way to get rid of acne. If there's no living tissue, there's no pores to get clogged up!
    For that industrial strength Velcro though, I've found that even lens cleaning wipes (for glasses) work fabulous in a pinch, and will allow stuff to hold for 5-10 years, even in hot or cold environments (we had both in our datacenters, hot side/cold side)
    bmf4069 likes this.
