  1. Oct 4, 2024 at 7:29 AM
    Outbound[QUOTED] likes this.
  2. Oct 4, 2024 at 7:30 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I have a wire from my battery through the grill with an SAE connector, then use a Battery Tender brand trickle charger on my truck. My motorcycle and pop's tractors all use Battery Tender brand trickle chargers too.
    The tender doesn't stay on the truck when it's disconnected.
    https://www.amazon.com/Battery-Tend...&sr=8-12-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY
    https://www.amazon.com/Battery-Tend...086&sprefix=battery+tender+agm,aps,233&sr=8-7
    bmf4069 and shifty` like this.
  3. Oct 4, 2024 at 7:36 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    I use Genius 1 maintainers. In fact I have several for my trucks and tractors. They have a pair of pigtails with eyelets you can permanently attach to the battery and the cable from the Genius maintainer just snaps to the pigtail.
    Genius 1
    https://www.amazon.com/gp/product/B07W46BX31?th=1
    Pigtails with eyelets
    https://www.amazon.com/gp/product/B004LWWNLC
  4. Oct 4, 2024 at 9:09 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Looking for plastic fog light blanks for an 00-02. Like this:
    Only place I can seem to find them online is ToyotaPartsDeal and the dealership. They want $50 for each. Anyone have a link?
    I’m trying to mount LED fogs, but nobody makes a mount or kit for 00-02s. I need something to fill the space between the bumper and the light- just having a hole there would drive me nuts. I honestly didn’t know that you could get headlight blanks for pre-facelifts, must not have been common.
    455h0le_dachshund likes this.
  5. Oct 4, 2024 at 9:17 AM
    Just to be clear, you are wanting FOGlight opening blanks and not HEADlight opening blanks, correct?
    FiatRunner[QUOTED] likes this.
  6. Oct 4, 2024 at 9:18 AM
    FiatRunner
    Jack
    Doh! Yes, fog light blanks. Not headlight blanks! Original post edited.
    KNABORES[QUOTED] likes this.
  7. Oct 4, 2024 at 9:21 AM
  8. Oct 4, 2024 at 9:26 AM
    FiatRunner
    Jack
    Am I crazy for thinking that $50/ea is unreasonable?
    I really wish there was a custom/aftermarket bracket available. Because unless I spend the money on the OEM blanks, there's no telling if they're going to be suitable for mounting a light or not.
  9. Oct 4, 2024 at 9:31 AM
    These are low volume trucks when new, now there's been 20+ years of attrition and already modded units. Market is small, demand is low. Just having parts available is a plus. If it's something you cant build yourself, or needs to be pretty and finished instead of homemade, $50 each ain't exorbitant. That said, I would likely get fogs that fill the opening and skip the trim bits.
    shifty` and FiatRunner[QUOTED] like this.
  10. Oct 4, 2024 at 9:37 AM
    FiatRunner
    Jack
    Yeah, I guess I'll take what I can get.
    I actually have OEM fog housings/brackets to replace my old ones- I can't remember who on here gave them to me. My initial plan was to bake them open and mount Baja Design S2s or similar on the inside of the housing, then put the glass back on.
    I was thinking that flush mounting lights in those blanks would be a lot easier, if they're angled correctly. Just want something that looks OEM+.
  11. Oct 4, 2024 at 9:38 AM
    Outbound
    Aaron
    Northern Alberta
  12. Oct 4, 2024 at 9:41 AM
    455h0le_dachshund and FiatRunner like this.
  13. Oct 4, 2024 at 9:48 AM
    FiatRunner
    Jack
    Those don't look too bad. I like how simple his mounting solution is- just bolted right to be metal bumper. Doubles the light cost though, as you need 2 on each side.
  14. Oct 4, 2024 at 10:07 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I also have Battery Tender brand chargers for numerous vehicles and recommend them.
    I hardwired the pigtails like @des2mtn, easy to plug/unplug, plus then you can easily use it on another vehicle with the alligator clips if needed without unwiring it from whatever vehicle it’s used for primarily.
    One of the chargers is the ‘Marine’ model and is waterproof, I’ll use that on my tractors sometimes and it doesn’t matter if it gets rained on.
    Dakillacore and des2mtn[QUOTED] like this.
  15. Oct 4, 2024 at 10:45 AM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    Did anyone know this sort of driving was possible with a pickup? Out of all the guys who get pranked by this female professional driver, only one of them is having a good time.
  16. Oct 4, 2024 at 1:29 PM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    It might benefit you to go browse around the local junk yard to look first if you're on the fence with the Ebay ones.
  17. Oct 4, 2024 at 1:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    We got robbed in Big Sur.
    Heading north now!
  18. Oct 4, 2024 at 1:38 PM
    des2mtn
    Shady Grove
    Tonto cover
    Cue the mouth breathers that will think every CA station charges this much
  19. Oct 4, 2024 at 1:44 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Any of the recommendations are fine, I use Noco but anything will work.
    Wrap the extension cord around the side mirror though, you'll think "I'm not an idiot I'll remember to unplug it" you won't one time.
    Unless you're going to be fancy and get an auto ejector for the plug.
    FrenchToasty likes this.
  20. Oct 4, 2024 at 1:45 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah and this was sort of my fault. I only stopped here because our air pressure light came on and there aren't many gas stations in the area. Gas seems to be around $4.50 everywhere else. Which is still awful :notsure:. We tried to stop at a Costco north of San Fran but they don't sell gas.
  21. Oct 4, 2024 at 2:07 PM
    $2.60 here at Sam’s club
  22. Oct 4, 2024 at 2:09 PM
    des2mtn
    Shady Grove
    Tonto cover
    $4-4.50 is the norm down here but it's been slowly going down. I pay under $4 on the Rez.
    bmf4069 and 455h0le_dachshund like this.
  23. Oct 4, 2024 at 2:17 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    It's like $3.45 here in the Mitten
  24. Oct 4, 2024 at 2:33 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    2.46 at sam walton's mart. And the taco says i'm getting about 26mpg avg.
  25. Oct 4, 2024 at 2:35 PM
    I paid $2.85 yesterday intown ATL.
  26. Oct 4, 2024 at 3:07 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    $2.50-2.75 in TN.
    I'm seeing a lot of Best Gens on this trip. Benefits of not having frame rot here in CA. But most of them are clapped out.
  27. Oct 4, 2024 at 5:03 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    WTF
    The Cali gas tax is 0,60 per gallon, someone explain the other $3
  28. Oct 4, 2024 at 5:05 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I payed 3.09 today in The Dirty T
  29. Oct 4, 2024 at 5:09 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Trichomoniasis? :monocle:
    shifty` and FrenchToasty[QUOTED] like this.
  30. Oct 4, 2024 at 5:18 PM
    des2mtn
    Shady Grove
    Tonto cover
    Localized supply and demand, gas is an inelastic good, people paying what they are willing to pay, etc.
    bmf4069, FirstGenVol and FrenchToasty like this.
