  1. Sep 16, 2024 at 8:29 PM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
    But i dont have any expierience with any of this. It'll have some beefy wires to the isolator, and i'll probably run one plug outlet to 3+ outlets (engine bay, front seat, back seat) and try my best not to overload em.
  2. Sep 16, 2024 at 8:32 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    2004 4x4 V8 RCLB 2006 4x4 V8 RCLB
    Bypass oil filters have a tiny orifice built into the downstream side of the filter. That orifice is about .015". Not enough to have any effect on oil pressure. Bypass filters filter a small amount of oil constantly and dump the filtered oil into the crankcase which is the exact opposite of what full flow filters accomplish.
    In diesel engines they completely eliminate soot.
  3. Sep 16, 2024 at 8:34 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    Cleaning a river with a coffee filter.
    j/k i know the benefits. But my truck is hardly working, and i wouldnt hate an excuse for an engine swap.
    Jack McCarthy likes this.
  4. Sep 16, 2024 at 8:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pics, plans, parts?
    I need this on the virus. The magnetic drain plug has been getting grittier and grittier with every oil change
  5. Sep 16, 2024 at 9:01 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    find a 2zz to build up & swap in.
    455h0le_dachshund and bmf4069 like this.
  6. Sep 16, 2024 at 9:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How would you spec it? What would you kit it with?
    I need economy
  7. Sep 16, 2024 at 9:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Sep 16, 2024 at 9:07 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    the yamaha head, long runner intake & header, a gentle foot.
    get coated pistons, loose rings and run it lean.
  9. Sep 17, 2024 at 3:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    They are going out of business. Tried to find a buyer and couldn't. RIP
  10. Sep 17, 2024 at 4:02 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    I had a corolla xrs bitd. I was not nice to it and still got around 34 mpg. I will say, it sacrifices down low tourqe that the 1zz has for up high hp the 1zz doesn't. But that 8200 redline is pretty fun to hit.
    455h0le_dachshund likes this.
  11. Sep 17, 2024 at 4:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can't see my fuelly mpg on mobile
    This things sips when cruising but I'm always on the highway like this
    Sirfive and Jack McCarthy like this.
  12. Sep 17, 2024 at 6:05 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    If the drain plug has grit, the full flow filter didn't catch it. Then you wonder how much non-magnetic grit it didn't catch.
    I don't have any pics other than the ones I posted. It's pretty simple. The inlet line is plumbed to a tee at the oil sending unit. The outlet line goes back to the oil pan...or the oil filler neck is often easier. Frantz has a kit to puncture the side of the oil pan for the clean oil line, I've done it that way on other vehicles. On my Tundras I just use a bulkhead type fitting on the filler neck.
  13. Sep 17, 2024 at 6:09 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    River flow is measured in cubic feet per second. My Tundra oil pan only holds 2 gallons including both filters. How long does it take 2 gallons of hot oil to flow through a .015 orifice? You guess, but it isn't that long. Sure it's random, unlike a full flow filter, but eventually all the oil is filtered and you are amazed at the results n the dipstick.
    Sirfive[QUOTED] likes this.
  14. Sep 17, 2024 at 6:14 AM
    What’s the Franz setup cost? Looks simple
  15. Sep 17, 2024 at 6:52 AM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    The 5vz sounds awesome though.
    So does the one that shall not be named in this forum...
    bmf4069 likes this.
  16. Sep 17, 2024 at 7:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  17. Sep 17, 2024 at 7:06 AM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Isn't your Tundra mostly highway miles anyways?
  18. Sep 17, 2024 at 7:08 AM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Is that a NE thing?
    BroHon and Jack McCarthy[QUOTED] like this.
  19. Sep 17, 2024 at 7:13 AM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
  20. Sep 17, 2024 at 7:49 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    I bought mine on ebay used, already had lots of 1/8" NPT fittings, bought the hose from Napa. So I guess they cost about $130 each. You can buy either cellulose or synthetic filter media. I use cellulose because it's rated smaller microns, the synthetic media is 2 micron which is just perfect for trapping soot on diesel engines.
    https://www.frantzfilters.com/
    KNABORES[QUOTED] likes this.
  21. Sep 17, 2024 at 9:13 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I think many would be surprised that gas mileage can actually improve with modifications. Sounds crazy- but when you modify an engine, you're simply making it more efficient. I'd bet that you could make a bunch of power from a 2ZZ and still get good gas mileage, especially with modern fuel injection and tuning.
    My Fiat 124 has a 1.6L engine that's been bored .010", has ~10:1 compression, headers, exhaust, big cams, intake, big carb, you name it. It gets upwards of 26mpg, and I drive it like a racecar. Even on the highway when it's spinning 4000+ RPM, it still gets 23+.
  22. Sep 17, 2024 at 10:45 AM
    Wow.
    Mpressive......
    My wifes 3.6L V6 in her 5000# SUV gets 26mpg.
    Maybe not the best example
  23. Sep 17, 2024 at 11:10 AM
    FiatRunner
    Jack
    Can someone explain to me how to link posts on here without the full link? Like so the link says what text I want it to?
    For some reason I can't figure this out.
  24. Sep 17, 2024 at 11:12 AM
    Type the phrase you want to display, select it, then use the link icon next to the text edit buttons on the toolbar above to paste your link
  25. Sep 17, 2024 at 11:13 AM
    FiatRunner
    Jack
    Ohhhhhhhh. Can't believe I couldn't figure that out.
    Thanks
  26. Sep 17, 2024 at 11:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Took me a while too
  27. Sep 17, 2024 at 11:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  28. Sep 17, 2024 at 11:50 AM
    shifty` Got patience on my neck like a cold, cold knife
    Once you get the stripper pole installed, I'll be right over!
  29. Sep 17, 2024 at 12:04 PM
    FiatRunner
    Jack
  30. Sep 17, 2024 at 12:38 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I found an imposter Ironman today.
    455h0le_dachshund and BroHon like this.
