  1. Jul 18, 2024 at 8:08 PM
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Happened to me. Doesn’t cause an issue. Decided to remove both and tie off the sway bar till I got new links.
  2. Jul 18, 2024 at 8:10 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I tied mine off as well, then I thought it was a great weigh reduction mod…….. loving it!
  3. Jul 18, 2024 at 8:26 PM
    Yup, we're absolutely on the same wavelength.
    :fistbump:
  4. Jul 18, 2024 at 8:36 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I’m pretty sure I rode for about two years 2016 to 18 with no links
    Jack McCarthy and FrenchToasty like this.
  5. Jul 18, 2024 at 9:06 PM
    GeminiProject
    GeminiProject New Member
    Commifornia
    1st Gen Tundra AC
    Leave them off, Rock Crawler Certified :evil:
  6. Jul 18, 2024 at 9:19 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I forgot I got a pic of this the other day. I was playing some terraria and there's these things called town slimes. My cursor fell on this one and I got a kick out of his name.
  7. Jul 18, 2024 at 9:22 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Hahaha, @shifty` is now internet famous. :D
    GODZILLA and shifty` like this.
  8. Jul 18, 2024 at 9:34 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Fully removed the side that broke, I’ll see how it goes
    455h0le_dachshund likes this.
  9. Jul 19, 2024 at 12:18 AM
    18" TRD Off Road Wheels
    Pretty sure that's an accurate quote, too!
    bmf4069[QUOTED] and shifty` like this.
  10. Jul 19, 2024 at 1:22 AM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    I was looking at the stock SuspensionMaxx links as part of my steering and suspension overhaul after reading about them on a recent post. I understand there is a problem with installation and accessing the lower bolt on the links. Could you and others explain the access issue at a simple level and workaround to install?
    I see that the SuperThin Capri is part of the solution. BTW, I ordered the 30x32 mm wrench earlier this week to hold the steering rack during future ITR install. Timmy the Tool...lol...measured the flats on a 4Runner with 9mm and 10mm on ITR and Rack respectively, so the Capri at 7mm should work as long as the length is not an issue in getting it in there. So I am hoping.
    BTW, my swaybar seems to be larger than most at approx 28mm. Besides larger D-bushings, which apparently affects manufacturer options since most seem to be sized at 23-24mm, is there any reason that the links might be affected with fitment issues?
    Anyone else have the larger stabilizer installed during production? I think I read a long time ago, that this was the Sequoias were equipped with the larger swaybar
    455h0le_dachshund and Hutcheson like this.
  11. Jul 19, 2024 at 6:59 AM
    GeminiProject
    Commifornia
    1st Gen Tundra AC
    I got the extended SuspensionMaxx arriving today. I'll update later.
    The Black Mamba likes this.
  12. Jul 19, 2024 at 7:32 AM
    Hutcheson
    Caleb
    2004 DC Limited
    Mine should be in by the end of next week so I’ll get back to you then.
  13. Jul 19, 2024 at 8:47 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    When you guys put in new struts / coils are the mounts something you typically do at the same time? No sign of failure at the moment but don’t want to have to service before I need to do susp work again
  14. Jul 19, 2024 at 9:00 AM
    GeminiProject
    Commifornia
    1st Gen Tundra AC
    Are you talking about the strut mount that comes new with struts/coilovers?
  15. Jul 19, 2024 at 9:07 AM
    MEWaters
    MEWaters New Member
    Maine
    I need to replace my front eibachs. They come only as the strut and I am removing the lift springs off the old ones. I didn’t get the coilover pkg
  16. Jul 19, 2024 at 9:44 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I got new isolators, but didnt really need em. How rusty is your hardware?
  17. Jul 19, 2024 at 9:45 AM
    GeminiProject
    Commifornia
    1st Gen Tundra AC
    Ah ok. I went with coilovers so maybe I'm not the best person to reply, but if I where you I'd go with new hardware.
  18. Jul 19, 2024 at 10:47 AM
    MEWaters
    MEWaters New Member
    Maine
    Not rusty at all really but they have 212k
  19. Jul 19, 2024 at 12:09 PM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    The Last of Us and Fable 2 are awesome games.
  20. Jul 19, 2024 at 1:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Y'all better get in a line to pick this up.
    FirstGenVol and FrenchToasty like this.
  21. Jul 19, 2024 at 1:51 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    and with his posted “hiss! Gargle! Ggrrrr!!”, how can you be so sure it’s not indeed our local legend? :rofl:
    bmf4069[QUOTED] likes this.
  22. Jul 19, 2024 at 2:04 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    The key to the nearly inaccessible bolt, is to get at it before it becomes inaccessible. You can get at it once completely installed with a thin enough wrench, and after a break in period, you’ll want to do that anyways. For the initial install however, you can just tighten the vertical bolt to the right amount of bushing ‘squish’, then force the side-stud thru it’s mounting hole in the LCA, and wrench that down. It’s the mounting flange that blocks access to the bolt head, if that makes sense. If you’ve got any amount of lift, you’re going to want the extended length links. Stock ride height - stock length links.
    Be warned; while the SusMax links do their job well, they do have a tendency to make a bit of noise, like loud popping sounds. At least they have for me and plenty others. Also, they need to be periodically tightened, for life. Just an fyi.
  23. Jul 19, 2024 at 2:46 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Just got off the phone with my alignment guy and he agreed that the alignment should be done with the planned load. Looks Like I need to have the camper mounted for Monday morning. I'll make up the difference with 80lb bags of Quickcrete. As a bonus I can play with the bag pressures and really see how it's going to ride!
    Cool guy. One man show and in business for 20 something years. Basically insisted that I bring it loaded after hearing some of the build details.
  24. Jul 19, 2024 at 2:49 PM
    Dakillacore
    Georgia
    Huh, I would never have thought to do that. Pretty cool guy and good information for a heavy load.
    JakeJake[QUOTED] likes this.
  25. Jul 19, 2024 at 3:27 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    :duh:
    you drinking again??? Lol maybe if you painted them black, you know, so nobody can see what they actually look like.
    crush bushings. It'll probably limit travel on the side that's still connected.
  26. Jul 19, 2024 at 3:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    when you google it, its chinese restraunts. I want people who google his name to be sent down a cultural rabbit hole. And he's rhodesian, but not a colonizer. So its sesotho.
    FishNinja[QUOTED] likes this.
  27. Jul 19, 2024 at 4:18 PM
    FishNinja
    Lee
    06DC2wd
    best name for a dog I had ever heard was "DeeOhGee" just say it fast. Took me a second to figure it out but then I was floored
    The Black Mamba and FrenchToasty like this.
  28. Jul 19, 2024 at 4:59 PM
    My buddy Sean had a dog with that name. And a pretty cool squareback.
  29. Jul 19, 2024 at 5:01 PM
    In that case, I'd just buy these. $300, but that's still asking too much IMO if it's just the rims. Wasn't clear to me. I wonder if anyone over on the sister Taco site have anything for sale. Guess I could check.
  30. Jul 19, 2024 at 5:36 PM
    I could get these. Powder coated black. I hate black wheels on white trucks. Price is pretty high too. Seller came down from $600, to $525. I would probably bite at $100/whl. I'd do the original silver BBS in this style (17x8 @ +5, so 4.7) in a heartbeat.
