  1. Jun 18, 2024 at 10:38 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The transmissions are completely different, so why not? Also the ECU's are completely different too.
  2. Jun 18, 2024 at 10:48 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    So how am I going to do this 5 speed swap?
  3. Jun 18, 2024 at 11:25 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    I’ll be going to 285’s in a couple weeks with stock gears on my 04 sequoia. Has anyone replaced their speedometer gear for larger tires to get a correct?
  4. Jun 18, 2024 at 11:41 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  5. Jun 19, 2024 at 2:02 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  6. Jun 19, 2024 at 3:31 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You're asking the wrong guy.
    I'd ask the master yota tech himself @empty_lord
  7. Jun 19, 2024 at 4:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Rock Auto discount code good through 7/19
    269813912174177774
  8. Jun 19, 2024 at 5:43 AM
    VR6T
  9. Jun 19, 2024 at 6:08 AM
    VR6T
    Why thank you good sir, put to use
    Screenshot_2024-06-19-08-00-59-15_40deb401b9ffe8e1df2f1cc5ba480b12.jpg IMG_20240619_081032.jpg
  10. Jun 19, 2024 at 6:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    VR6T[QUOTED] likes this.
  11. Jun 19, 2024 at 6:29 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    A750f?
    V8 4Runners without VVTI had it. You would need to make that ecu happy in your truck and run the 4runner engine harness. Then you’d have a 5 speed non vvti
  12. Jun 19, 2024 at 7:40 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Sent from our lift rep :rofl:
  13. Jun 19, 2024 at 7:41 AM
    VR6T
    Meh it's just a range rover
    455h0le_dachshund and Mr.bee like this.
  14. Jun 19, 2024 at 7:53 AM
    It's an HSE so some big $$$. But yeah, I feel nothing.
    455h0le_dachshund likes this.
  15. Jun 19, 2024 at 8:00 AM
    VR6T
    Oh so it's the "fast one" that gets gapped by a CIA, FMIC, TB Exhaust and tuned SRT4 Neons.
    We had a kid on of my ships who was just a bragert about everything. His shit didn't stink and it was the fucking best no one's could be better. Well I was buddies who had a sleeper as fuck SRT4, like I said bolts on and a tune, fuel mapped for 100, like 350 360 to the wheels. So Mr. High dollar started talking shit, so Neon said line it up where and when and how we race your call. Mr. Richy rich took it hook line and sinker. 40 roll on 264, need less to say Mr. Range Rover V8 Supercharged stoped talking shit the next day and the rest of the time I was at the command. Fucking cunts.
  16. Jun 19, 2024 at 8:02 AM
    VR6T
    The lesson I learned from that is people that are like that are bad for the car community. Because after losing instead of coming to us hat and hand and looking for knowledge on how to make his supercharged vehicle faster and how that shouldn't happen to him again he just completely disassociated with us. That's how you can tell when people weren't raised right when they can't eat their s*** that they f****** started and learn from it.
  17. Jun 19, 2024 at 8:10 AM
    Clowns, they are aplenty for sure. Thinking his big hulking SUV was any match for a compact tuned car, boosted no less, was his first mistake. Fast is about lb/HP. Less pounds is easier to make fast.
    455h0le_dachshund, bmf4069 and VR6T like this.
  18. Jun 19, 2024 at 8:22 AM
    VR6T
    That's the day it was cemented with out doubt for me that built will always be better than bought.
  19. Jun 19, 2024 at 8:33 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Why do I get the feeling the customer will never know?
  20. Jun 19, 2024 at 8:37 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  21. Jun 19, 2024 at 8:43 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  22. Jun 19, 2024 at 8:47 AM
    VR6T
    FrenchToasty and KNABORES like this.
  23. Jun 19, 2024 at 8:49 AM
  24. Jun 19, 2024 at 9:05 AM
    VR6T
    Shit weld on a rear weight mounting bar for like plate weights and you got your self a engine and trans puller as well
  25. Jun 19, 2024 at 9:05 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    With the timing belt maintenance taken care of I'm looking move on to suspension.
    upper&lower ball joints...(moog :p)
    ARP hardware
    poly upper&lower control arm bushings
    poly steering rack bushings
    poly sway bar bushings
    Billies 5100 (x4)
    OME 2884
    KYB top hats 5442
    KYB isolators 5413
    Airbags+fittings/tubing
    Airbag cradles
    Leaf spring isolators
    Leaf spring bushings
    fabricate airbag brackets/u-bolt eliminators.
    I plan to strip the front and rear down and remove the bed to cleanup/prep/paint the frame. Re-used parts-control arms/rear axle/leafs will get the same treatment and be reinstalled with new balljoints/bushings.
    I have some of the listed parts, but need to pull the trigger on about $1k worth of stuff. What am I missing? Spend that on hookers and blow instead?
  26. Jun 19, 2024 at 9:07 AM
    VR6T
    Truck will still be there in the morning hooker's and blow won't be ........ Spend it on the truck
  27. Jun 19, 2024 at 9:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Do you wanna try the bushings in the control arms or just get new arms? I know you're a handy guy, but those bushings suck. What if, bear with me now, I got some new uppers for mine and you could have my Freedom UCAs? They're good, but not for what I need.
  28. Jun 19, 2024 at 9:27 AM
    JakeJake
    2000 Tundra AC 4X4
    :rofl:I mean we could probably work out a UCA deal, but I already have the ball joints and bushings.
    I went with the black poly bushings from Daystar. Just melt out the old rubber with the torch leaving the steel sleeve behind. The poly bushings get pressed into the sleeve.
  29. Jun 19, 2024 at 9:29 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  30. Jun 19, 2024 at 9:33 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I wonder how much HP I gained by losing weigh? Lol
    BroHon likes this.
