  1. Jun 15, 2024 at 2:05 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Exactly but without your cart they'd be scratching their head and you'd be out with it the next day.
    BroHon and JakeJake[QUOTED] like this.
  2. Jun 15, 2024 at 2:05 PM
    ToyotaDude
    ToyotaDude Member
    You also swapped the clockspring and airbag? What parts did you use?
    455h0le_dachshund likes this.
  3. Jun 15, 2024 at 2:14 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Didn't need to swap clock spring. Ordered a steering wheel cover with the cutouts, attached my own bag to it and used cheap Chinesium controls I ordered from AliExpress. I had to add 3 wires to my backside clock spring connector and ran those to an iDatalink steering wheel interface for use with my Kenwood double din. The iDatalink wouldn't work with a couple of aftermarket cheap stereo units that I tried but would work with the wires coming from the clock spring by themselves. I wasn't happy with the sound quality of the cheap units so I went back to my Kenwood and the iDatalink interface. I left the left side buttons as default but I swapped the right hand side buttons to include volume up and down and a play pause button. The buttons can be programmed for dual settings when programming the iDatalink steering wheel controls interface. You just choose your vehicle and stereo and it gives you options for each button. Each button can have press and a press/hold function. I'm used to right hand side controls from my Ford so that's what I tried to replicate in my Tundy.
    The airbag cover I grabbed off eBay was from a Sienna minivan, again I just attached my own bag to the cover and added the cheap Chinesium buttons. They even matched my dash with green backlighting.
  4. Jun 15, 2024 at 2:34 PM
    I haven’t investigated cost and time.
    Failure to cancel: A couple of prior vehicles, there was a cam* that’s supposed to get kicked over when the steering wheel rotates. Failure to cancel was typically a failure of that can or mechanism for me in the past. I haven’t dug inside the column on these trucks yet, just everything from the clock spring upward.
  5. Jun 15, 2024 at 2:36 PM
    Grapes (Niagara) are going aprshit this year! I’ve already placed about 35 bags on clusters to fend off the birds and squirrels. May or may not work with the squirrels. Have yet to see. First tomatoes of the year too.
  6. Jun 15, 2024 at 2:50 PM
    ToyotaDude
    ToyotaDude Member
    Yeah IIRC there's a litle tab on the turn signal switch that is supposed to get clicked back into place by the wheel turning. Pulled the lever/switch previously. It appeared to be working fine so figured the other part that turns under the steering wheel might be at fault. That's the clockspring right? Read once about a mod for the switch to increase the depth of the tab but figured instead for $20 instead probably try to swap the switch for aftermarket part because it's so easy. And if that doesn't work then plan to invest in clockspring and the time to swap.
  7. Jun 15, 2024 at 2:53 PM
    ToyotaDude
    ToyotaDude Member
    So what is gained with the mod? Only stero controls? Or call answer/cancel if there's a blue tooth mod as well? Seems like cruise is already right there near the wheel.
  8. Jun 15, 2024 at 3:02 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Where’s your trellis to support the grapevine? Do you just let it grow along the ground?
    FrenchToasty likes this.
  9. Jun 15, 2024 at 3:49 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  10. Jun 15, 2024 at 3:51 PM
    artsr2002
    'Yonder
    Yep. Stereo controls and phone controls.
    VR6T likes this.
  11. Jun 15, 2024 at 3:53 PM
    artsr2002
    'Yonder
    Does anyone else see Instagram posts on mobile? I don't. I'm using S22U with Firefox Beta browser. I can click the link and it doesn't do jack shit.
  12. Jun 15, 2024 at 3:55 PM
    artsr2002
    'Yonder
    I can see them and play videos inline using Samsung Internet Beta browser so it must be one of my ad blocking settings on Firefox. I used to use Samsung Internet Beta browser exclusively for this site but after a while it keeps locking up my phone. And only on this forum. It's weird.
  13. Jun 15, 2024 at 4:00 PM
    artsr2002
    'Yonder
    Figured it out. I had Strict Tracking Protection enabled in Firefox. Carry on.
    shifty` likes this.
  14. Jun 15, 2024 at 4:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can see it on mine. Google Pixel 7. Chrome browser.
  15. Jun 15, 2024 at 4:38 PM
    I'm using the 4ft picket fence as a support and every few feet, I've got one of those $20 Costco arbors or whatever to let them throw vines up and catch as much sun as possible. Hopefully you can see in this pic, but the little cluster of Cherry Laurel is blocking it. The main vine is as big around as my forearm. I've been growing it for years, but my neighbor had a big ass Holly tree blocked all the sun to it. This year, tons of sun, and tons of clusters.
  16. Jun 15, 2024 at 5:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Now that's thinking with your dipstick, Jimmy!
  17. Jun 15, 2024 at 5:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  18. Jun 15, 2024 at 5:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I see em fine with Chrome for Android
  19. Jun 15, 2024 at 5:54 PM
    artsr2002
    'Yonder
    Yep works fine in Samsung Internet Beta and on Chrome.
  20. Jun 15, 2024 at 6:08 PM
    Jack McCarthy
    Bill
    North of Boston
  21. Jun 15, 2024 at 6:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It didn't work well for mud either. But it was better than nothing. The biggest issue was the sprinkler wouldn't stay in place. It kept sliding on the wet concrete and would end up pigeon holed somewhere, not giving good coverage.
  22. Jun 15, 2024 at 6:21 PM
    Jack McCarthy
    Bill
    North of Boston
    What you need is a 3000 psi pressure washer feeding a hose with pinholes that point up which you can drive over slowly.
    This will work too…
    https://www.amazon.com/Undercarriag...18c1c0362363317398a9f05f390232d8&gad_source=1
  23. Jun 15, 2024 at 6:45 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  24. Jun 15, 2024 at 7:02 PM
    ToyotaDude
    ToyotaDude Member
    Just threw my hi-ten on the bathroom scale and it came out 30 lbs. Never really tried to make it lighter .... guess thought of it kind of like carrying weights in a pack on purpose. Think the one with the CRMO frame is a little lighter but seems geared differently so workout feels about the same.
    shifty`[QUOTED] likes this.
  25. Jun 15, 2024 at 7:04 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  26. Jun 15, 2024 at 7:06 PM
    Can’t even tell it’s tape. Looks mint.
  27. Jun 15, 2024 at 7:07 PM
    artsr2002
    'Yonder
    What tape? The roll? That's duct tape not duck tape. Lol
  28. Jun 15, 2024 at 7:36 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Kinda looks like Polo riding shotgun...
  29. Jun 15, 2024 at 7:44 PM
    NUDRAT
    SW CT
    Haven't noticed anyone mention a "parking brake". Dunno if you've got hills there, but heavy stuff don't like to stay where you put it when wheels get involved.
    BroHon likes this.
  30. Jun 15, 2024 at 8:16 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I could stand on a penny and watch my dog run away for three days.
