  1. May 28, 2024 at 12:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  2. May 28, 2024 at 3:17 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    154k. We don't drive it a ton since we work from home. Still get around 28 mpg highway.
    Nicklovin[QUOTED] and BroHon like this.
  3. May 28, 2024 at 6:01 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    less than 150 pics until a million.
  4. May 28, 2024 at 8:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I bought my battery 7/4/18. It's completely dead now and time for a new one.
    So whats the word on AGM vs Optima? And would a dual battery setup be good for my application? I was thinking just doing 2 in parallel for the amp draw. I also need a sequoia alternator.
    :bananadead:
  5. May 28, 2024 at 8:53 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    I remember watching this with my dad in the weekends. It was such a a good show
    BroHon likes this.
  6. May 28, 2024 at 8:56 AM
    VR6T
    DO NOT mix an AGM style battery and a non AGM battery in the same system. I can not express the DO NOT hard enough. Best recommendation is to run the same brand of battery in a dual set up. Or at least the same style so standard cell with standard cell.
    artsr2002 and bmf4069[QUOTED] like this.
  7. May 28, 2024 at 9:02 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Optima are AGM, except their lithium.
    des2mtn, bmf4069[QUOTED] and VR6T like this.
  8. May 28, 2024 at 9:03 AM
    VR6T
    Thanks I forgot to address that part of it. That's important info to have.
    PenderBen[QUOTED] likes this.
  9. May 28, 2024 at 9:05 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oh they'd be the same type. I don't think I'm quite there yet though. I'm pulling roughly 100A at full boogie, so the tree alt and a new battery should be good.
    Sweet. So does it require that weird diode thingy?
  10. May 28, 2024 at 9:10 AM
    VR6T
    I have a 100 amp sitting in my walk way for mine waiting to go in.
    AGM batters just hold up better, take a deeper charge and can be mounted in non traditional ways vice a traditional wet cell battery. They are more geared towards race and hard core off roading applications.
    You will need an AGM compatible charger to be able to charge them if they ever go flat. If you're not trying to Baja or do racing/ an application where you could end up on your roof I'd say save the 60 extra per battery and go traditional.
  11. May 28, 2024 at 9:34 AM
    PenderBen
    2003 Tundra AC 4x4
    Don’t forget they’re essentially no maintenance, I think that’s why a lot of people get them.
    Sunnier and VR6T[QUOTED] like this.
  12. May 28, 2024 at 9:38 AM
    VR6T
    But when they require their maintenance it's a bitch to repair/ recondition them. But other than that they're good batteries for sure
  13. May 28, 2024 at 9:44 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    LBJs ordered. Thanks, Mr Shifterson. Going to hold off on TREs for awhile.
  14. May 28, 2024 at 9:48 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Optima is a brand that makes AGM. They are made by a company called Clarios. The current AGM I have is a Northstar, who is now EnerSys. I don't think they use the Northstar brand anymore, but they also make Odyssey batteries, as well as Batteries Plus' house brand, X2 Power. The current AGM I am looking at is US Battery brand. That's what my local battery house carries currently I believe, and that battery house is typically cheaper than Batteries Plus.
    Spendier, but I'd do a LiFePo4 as a second battery instead of an AGM. You can discharge a Lithium further without damaging it. Think there shouldn't be an issue running the two types in parallel if needed, varying opinions you can read on that, but you'll want a separate charging system. I'd just try to run your amp off the LiFePo4 alone instead, might get some good run time with it charged and the truck off.
    @FrenchToasty, do you have plans to do an isolator or get your Renogy connected to the alternator?
  15. May 28, 2024 at 9:55 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Probably not, I should have gotten a DC-DC charge controller from get go
    des2mtn[QUOTED] likes this.
  16. May 28, 2024 at 10:12 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do lithium discharge in the cold?
  17. May 28, 2024 at 10:13 AM
    des2mtn
    SW
    Tonto cover
  18. May 28, 2024 at 10:23 AM
    des2mtn
    SW
    Tonto cover
    LiFePo4 perform better in the cold, not as better as they would in regular temps, but you can't charge them below freezing. They don't loose their charge overnight in the cold like flooded batteries do. For cold weather, I'd run something like this. https://lionenergy.com/products/battery-warmer.
    The LiFePo4s in our motorhome are so much better than the stock flooded ones.
  19. May 28, 2024 at 10:25 AM
    VR6T
    All batteries discharge in the cold, some worse than others, but as what's what that beyond my knowledge scope
    des2mtn likes this.
  20. May 28, 2024 at 11:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I need to attach this to my skid
  21. May 28, 2024 at 11:32 AM
    VR6T
    Yes
  22. May 28, 2024 at 11:42 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Ive got a few to choose from.
    But i want this:
    soooo close. 5 to go.
    Sunnier and bmf4069 like this.
  23. May 28, 2024 at 11:45 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. May 28, 2024 at 11:49 AM
    VR6T
    Oh man
  25. May 28, 2024 at 12:27 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Oh hell, at least a good distance from the house! You come through it alright?
    I feel for ya, we had an f1 tornado go over our place in Aug last year.
    Tundra2[QUOTED] and Sunnier like this.
  26. May 28, 2024 at 12:30 PM
    shifty` Inside his chest they found ten thousand pencils
    Depends on what TZ you’re in. It was 9:30am when I posted that. I’ll be out of pocket for a few days and possibly posting at weird hours while hanging out with some windmills, tulips, and eating too many stroopwafels
  27. May 28, 2024 at 12:36 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Anyone else has their truck insurance double from last year? Clean record and all. Da fk.
    Any tips on who provides reasonable rates on our trucks?
  28. May 28, 2024 at 12:37 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    riding bicycles in a funny hat & shoes?
  29. May 28, 2024 at 12:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    mine hasnt budged, bit its liability only.
    Voss[QUOTED] likes this.
  30. May 28, 2024 at 1:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ours went up 70% in two years. My agent said this is the worst market he's seen in 20 years. I recommend finding a local agent that will shop for the best rates among several insurance companies. Just make sure you are having them use the same coverage amounts as you currently have so that you get an apples to apples comparison. We had him shop around and just switched to a new company which saved us $1000/year between home and auto.
    abcinv, FrenchToasty and Voss[QUOTED] like this.
