  1. May 25, 2024 at 1:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i think i called & asked about the same lbj# that sunnier used, and boerne toyota verified it was correct, so then i ordered em from whichever dealer was running the sale.
  2. May 25, 2024 at 1:55 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  3. May 25, 2024 at 1:57 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Well.
    //Looks at TREs, LBJs, thinks 'that's probably fine'//
  4. May 25, 2024 at 1:59 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    pretty sure i had found a reference chart, i'll let you know if i find it again.
    Sunnier likes this.
  5. May 25, 2024 at 2:00 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    My favorite is the exploded parts diagram that's totally understandable, but then the numbers changed at some point, but the diagrams weren't updated. Genius.
    Jack McCarthy likes this.
  6. May 25, 2024 at 2:02 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Sunnier likes this.
  7. May 25, 2024 at 2:06 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Can call Serra (205-838-4400) and give them your VIN then they will give you the part numbers. They are very friendly and helpful in my experience.
  8. May 25, 2024 at 2:18 PM
    shifty` Inside his chest they found ten thousand pencils
    When you get into EPC data, go into "Transmission & Chassis", scroll to the 2nd picture and click on "Front axle arm & steering knuckle".
    Inside there, click "Open Full Size Scheme".
    Do yourself a favor, in the big full size image. Hold your mouse over either of the numbers I'm pointing at. You should see a helpful pop-up window appear saying "JOINT ASSMBLY LOWER BALL ...", i.e. the website gives you the part inf. This will help you make sure it's the right part, since the other numbers inside the box are for the castle nut and cotter (left/right). The way these diagrams are laid out, an ASSEMBLY is boxed, with the reference number OUTSIDE the box. Anything inside the box is individual pieces in case you don't need the full assembly.
    With that in-mind ... Click on the number with "RH" at the end for passenger side (right hand) or "LH" for left hand ... the numbers above it are for the castle nut (the numbers ending in L and B) and the cotter pins (the 10-digit hyphenated numbers).
    When you click on each of them, it'll take you back to the small diagram and spit your number out at the top. There's your part number... The main part number (FOR MY 2006 AC 4WD ONLY!!!!) is the one I'm underlining in red. Notice theres a "substitute" (SUBS) part number underlined in blue which is a compatible alternative, dunno what that's about.
    BroHon and JasonC.[QUOTED] like this.
  9. May 25, 2024 at 2:24 PM
    You'd be amazed what a toothbrush will do to knock stuff loose. Then vacuum it out. You can also use water in there, PHM did that with his, it should drain out the nipple in the firewall.
    I would literally toothbrush to knock that shit loose, vacuum it out, maybe rig up something on your vacuum to reduce the nozzle to fit. Once you vacuum, get any foaming HVAC coil cleaner and apply it directly on the coils, let it soak in, brush it, rinse/vacuum again.
    Or just knock the big shit loose and vacuum, then when it's mostly gone, follow this method. A brush will loosen and vacuum should suck out most of what you see there. The foam will do the rest. Just don't foam using my method unless the resistor is reinstalled! Else the foam will be on your floorboard. I'd also empty the whole f'n can into the firewall nipple.
  10. May 25, 2024 at 2:44 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Just chop down that Bradford Pear
  11. May 25, 2024 at 2:48 PM
    VR6T
    That ball chiller comes in clutch baby. Don't know why they ever got rid of them
    455h0le_dachshund likes this.
  12. May 25, 2024 at 2:49 PM
    VR6T
    Naw it's my sister's house she likes the shade. But we cut it back by about 4ft all around, so about 8ft off the total diameter.
    She's gonna rent a mulch chipper and we're going to mulch all the cuttings. I'm trying to see if that woods good for smoking if so I'm gonna do a brisket with it. @Mr.bee @455h0le_dachshund @FishNinja
  13. May 25, 2024 at 2:54 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    pear wood for pork. I use fruit wood for pork, oak for beef, and mesquite for chicken.
  14. May 25, 2024 at 3:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    RIP
    Best female wrestler to ever live.
  15. May 25, 2024 at 3:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  16. May 25, 2024 at 3:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    *& only up to $200.
    Ask me how I know.
    des2mtn[QUOTED] and Sunnier like this.
  17. May 25, 2024 at 3:35 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've been this rabbit hole and have taken the whole evaporator out and separated the cases to clean it, as well as change the expansion valve. You're most likely not going to be able to pull the "lower unit case" without pulling it completely out of the dash. Back two screws and the clip specifically will be hard to access.
    Here's my posts from tearing into the dash and pulling it out:
  18. May 25, 2024 at 3:37 PM
    des2mtn
    SW
    Tonto cover
    That's a bummer. I'm sure in the future, if you hit the limit, you could just make multiple orders.
  19. May 25, 2024 at 3:38 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Is that a Acura v6 or something??? Lol that thing looks rad
    BroHon and 455h0le_dachshund like this.
  20. May 25, 2024 at 3:46 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    J32 (at least what i searched for) probably from a tl. Could have been had with a 6 speed & plenty rowdy.
  21. May 25, 2024 at 3:50 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's a good idea.
    But I think it's was like $40 I had to cover for shipping. So not too bad. Just enough to make me email em and complain about their false advertising.
  22. May 25, 2024 at 4:02 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    This is the exact reason why Toyota should’ve had a cabin air filter for the Tundra and not just the Sequoia.
    BroHon and TXTundraGuy23[QUOTED] like this.
  23. May 25, 2024 at 4:04 PM
    VR6T
    What you don't think Rowdy Ronda is the best ever...... I feel a hissy fit coming on
  24. May 25, 2024 at 4:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Chyna was the best to ever be. She set the stage for the current women's superstars. I'm not discounting them, because they are awesome. But Chyna could legit beat up some of the WWF's men. Plus she was in DX... Nuff said.
  25. May 25, 2024 at 4:11 PM
    Jack McCarthy
    Bill
    North of Boston
    You mean Rodney Piper had a bastard child?? I did not know this occurred.
    Chyna could waste her, regardless.
  26. May 25, 2024 at 4:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Lots of the old guard now have legacy kids in the biz. Pretty neat.
  27. May 25, 2024 at 4:26 PM
    Jack McCarthy
    Bill
    North of Boston
    Decided to make my own adapter today to measure clamp current for my new meter.
    Good to 1 mA resolution AC or DC. Not true RMS but I’ve got the Fluke for that when it comes to square waves.
    bmf4069 and BroHon like this.
  28. May 25, 2024 at 4:52 PM
    VR6T
    Naw Rodney didn't, some one got beat in the UFC cause she was drunk on her own hype b******* couldn't handle the pressure of her comeback loss and then fled the UFC and then went pretending to be the world's greatest fighter. And now the WWE calls her rowdy Rhonda. Which I feel is a slap in the face to somebody who used to watch '80s and early's '90s WWF wrestling. She's not even half as cool is the piper was
  29. May 25, 2024 at 5:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Y'all mixing up Rowdy Roddy Piper and Rhonda Rousy? Lol
    I also thought you meant Roddy Piper had a daughter in WWE.
    I know Rick Flare has a daughter in WWE and Dusty Rhodes has two sons in WWE. Although I'm not sure if Gold Dust is retired or not. I'm sure there's others I'm forgetting
  30. May 25, 2024 at 5:12 PM
    VR6T
    No the WWE calls her losers ass Rowdy Ronda Piper
