  1. Apr 12, 2024 at 11:19 AM
    Looks like the entire ass-end is missing too.
    JakeJake[QUOTED] likes this.
  2. Apr 12, 2024 at 11:21 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    @bmf4069 I have a great deal for you. One pristine door handle, in your color, for one easy payment of $999.99 :rofl:
  3. Apr 12, 2024 at 11:42 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Installed an extended rear brake line for my custom shock relocation.
    455h0le_dachshund likes this.
  4. Apr 12, 2024 at 11:50 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    not long travel just longer travel lol.
    Removed the spare tire cradle and driver side upper shock mount which the LSPV is mounted to. Made a new mount for the LSPV. This setup is VERY similar to the archive garage rear setup. Only reason I opted to do this is I already had the shocks. If I didn’t I would have left it alone until I went spring under. Added bonus it’s all under the bed.
    Rear LT requires spring under Deavers, ~16” triple bypass shocks, shackles, shackle hangers, bed cage, bump stop cans mounts and strike pads, u bolt flip kit I’m presuming, and probably a few more small things. Not to mention 10x the cost of what I just spent (not including shocks).
  5. Apr 12, 2024 at 12:07 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s a unibody I believe.
  6. Apr 12, 2024 at 12:10 PM
    Jack McCarthy
    Bill
    North of Boston
    Guess I need my eyes checked again.
  7. Apr 12, 2024 at 12:10 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Yeah that intake tube is the v8
    the front bumper brace is pushed in and up on the drivers side
    not sure how straight the frame actually is, probably needs to go on a frame machine and get measured out before i would trust it. Its a LOT of work to swap frames and swapping in a bent frame could / would be a heck of a lot more work than its worth. Replacing a badly rotted out frame is likely an awful job, cutting out body mount bolts whose heads are round, picking up bed and cab whose rigidity is questionable, swapping over SO many driveline parts, axles, front end, suspension, and all of the broken bolts, rusted parts you gotta deal with. I can only imagine its a 40+ hour job having a lift and the shop space to do it properly, the 40+ hours is very open ended to having to order additional parts and play wait while you wait on those parts to come in to replace the stuff you broke, cut out, and mauled trying to get it apart since everything is rusted and oxidized together.
    boy what a heck of a nightmare.
    JakeJake likes this.
  8. Apr 12, 2024 at 12:11 PM
    Jack McCarthy
    Bill
    North of Boston
    I’m guessing that frame is done by the way the reinforcement is bent back a little too much.
    shifty` likes this.
  9. Apr 12, 2024 at 1:08 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I bet that's your issue. You'll need to tweak the prop valve to match your new setup. Pretty confident you can fix this and get the brakes back to your standard.
  10. Apr 12, 2024 at 1:26 PM
    JakeJake
    2000 Tundra AC 4X4
    bmf4069, FrenchToasty, BroHon and 3 others like this.
  11. Apr 12, 2024 at 1:35 PM
    Jack McCarthy
    Bill
    North of Boston
    You have to be pretty experienced to do it right and it’s never 100% the same.
  12. Apr 12, 2024 at 1:37 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BroHon likes this.
  13. Apr 12, 2024 at 1:44 PM
    JakeJake
    2000 Tundra AC 4X4
    Awwww, you shouldn't have.
    "Make sure you smash that like button, subscribe, and buy the products I'm promoting!"
    I'll probably make a video or two when I get back to playing trucks.
    shifty`, bmf4069, BroHon and 3 others like this.
  14. Apr 12, 2024 at 3:04 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I feel profiled.
    Jack McCarthy and bmf4069 like this.
  15. Apr 12, 2024 at 3:11 PM
    NUDRAT
    SW CT
    Lot's of fun suggestions, but this is close to the neighbors truck & close to my garage. My plan for this one is to dig/shovel it out. Better health through hard labor.
    I do have 2 backup stumps that may be good candidates for fire or rapid expansion. Would a rapid expansion event with shock wave accompaniment cause the chickens to stop laying for a day or three? Bonus points to anything that ups my arsehole neighbor rating. I'm currently running in 12th place in a grouping of 3 - I really need to up my arsehole game.
  16. Apr 12, 2024 at 3:15 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    So I had this sitting in the garage and never did it so figured it was a good time to try. I can definitely feel the brake bias in rear so I should have done this a while ago, but still have that 50% squish before real good engagement. Probably bleed it again and hope it fixes it.
  17. Apr 12, 2024 at 4:04 PM
    JakeJake
    2000 Tundra AC 4X4
    That's just big bodyshop propaganda. Who radicalized you?
    FrenchToasty likes this.
  18. Apr 12, 2024 at 4:13 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    A couple tires over the stump filled with diesel :bananadead: That should get you close to the top of that list.
    New neighbor decided to burn the abandoned fake Christmas tree left behind by the PO during the eclipse... ushered to the top of my shit list.
  19. Apr 12, 2024 at 4:17 PM
    Jack McCarthy
    Bill
    North of Boston
    My father who’s been fixing them since 1970. He retired back in 2010. I can’t comment on the modern computerized systems. He’s used to the old analog way. Most shops would give him all the work since he knew what he was doing, He didn’t like it himself because he had to wait 2-3 weeks for a large payday on a big job.
  20. Apr 12, 2024 at 4:24 PM
    JakeJake
    2000 Tundra AC 4X4
    I would love to see his reaction to my analog methods :rofl:He sounds like a hell of a craftsman.
    I'm just having fun here, no disrespect intended.
  21. Apr 12, 2024 at 4:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    NO! Ironman is ugly and that makes him beautiful!
    However, if you get it I'd buy those wheels if it has all four....
  22. Apr 12, 2024 at 4:35 PM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, I know. I got a good chuckle when I watched the video after I posted. Maybe , I should have held off on my comment. haha
  23. Apr 12, 2024 at 4:36 PM
    JakeJake
    2000 Tundra AC 4X4
    I know your door handle policy, but I couldn't resist.
    your money is no good here, ironman wheels on me if I can make a deal. I sent the guy a message and I'm waiting for a response. I'll try and take a look at it in the next few days.
    *assuming it has all four wheels, but the rear axle is missing so that's not a good sign*
    bmf4069[QUOTED] likes this.
  24. Apr 12, 2024 at 5:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes. Pull forward and tug down IIRC
  25. Apr 12, 2024 at 5:59 PM
    Jack McCarthy
    Bill
    North of Boston
    Pull it from the back? Also, are there screws under the map lights that need to be removed?
  26. Apr 12, 2024 at 6:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You could always try moving by the nuts up or use a basic bracket from a hardware store to lift the entire assembly 1-2 inches.
  27. Apr 12, 2024 at 6:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I don't recall any map light screws.
    I just know mine came out pretty easily with a tug
    VR6T and Jack McCarthy[QUOTED] like this.
  28. Apr 12, 2024 at 6:34 PM
    JakeJake
    2000 Tundra AC 4X4
  29. Apr 12, 2024 at 7:33 PM
    Jack McCarthy
    Bill
    North of Boston
    Looks like I have to pull it from the front instead of the back. No screwholes other than the two in the sunglasses holder as you said.
  30. Apr 12, 2024 at 8:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    yeah the crash ratings are lousy, but it'll be a good resell later on perhaps
