  1. Apr 12, 2024 at 7:10 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    One of the HVAC techs that was at my house a few weeks ago reminded me of you so much Noah. Similar background, personality, and views on the world. Dude was funny. Left a cigarette butt on my garage floor :D.
    bmf4069 and Tundra2[QUOTED] like this.
  2. Apr 12, 2024 at 7:15 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I wasn’t under the truck I was pumping the brakes so idk. But it was on the ground.
  3. Apr 12, 2024 at 7:18 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    The first 2/3 of the pedal don’t do a damn thing. Then brakes engage at the bottom. After bleeding the LSPV twice with decent amount of driving in between it’s engaging where it should, but it’s pretty weak. I’m ~50% of the brake pedal travel before it grabs like it did normally before.
  4. Apr 12, 2024 at 7:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I no longer smoke, I've moved away from acoustic cancer in favor of electric, mint flavored cancer :rofl:
    Gave you some Deja vu?
    bmf4069 and FrenchToasty like this.
  5. Apr 12, 2024 at 7:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    You didn't pump the pedal all of the way to the floor, did you? I would think that a shop like that would have an actual pneumatic bleeder system on hand.
  6. Apr 12, 2024 at 7:30 AM
    You just had someone install LT in the rear. If you deleted your parking brake stuff, or your parking brake is out of adjustment, that is 100% the most likely issue here. These trucks cannot brake properly without functional parking brake. Is yours still intact? If so, did you do anything to adjust/fix your shit after doing the LT? Like, the lever/arm position on the LSPV?
    @KNABORES is right, my '06 came with two clips on each side. Maybe the earlier 13WE trucks were different, but my 13WL later-model has all 4 clips.
  7. Apr 12, 2024 at 7:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Sounds like air is still trapped somewhere. Did you put anything under the brake pedal before you started bleeding to protect the master cylinder? Usually recommend to put something under it to keep the pedal from traveling too far during the bleeding process.
    Other than replacing a brake line, did you do anything else?
    The Black Mamba likes this.
  8. Apr 12, 2024 at 7:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Very good point!
  9. Apr 12, 2024 at 7:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is fantastic, it's perfect :D
  10. Apr 12, 2024 at 7:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @shifty` is right. The rear brakes being even slightly out of adjustment will have a huge impact on brake pedal travel and performance. I hate the rear drums.
  11. Apr 12, 2024 at 7:36 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    The parking brake is a good way to test the drums, but its really a drum brake adjustment.
  12. Apr 12, 2024 at 7:37 AM
    I feel like rear drums are almost like points ignition or carburetors. If you know how to adjust points, and you know how the various methods to baseline a carb for dial-in, good for you. Me, I need to use a damn reference all the same. Some folks wax nostalgic about working with all three, points, drums, carbs, because they've figured out all the little tricks and can commit that info to memory. Everyone else who either (A) don't realize there's a fundamental trick involved or (B) know there is, but don't do it enough to remember and/or execute perfectly the first time, it's a nightmare.
  13. Apr 12, 2024 at 7:40 AM
    But if anything changed on the rear braking linkage/assembly, and it puts the drums out of alignment, say the LSPV is splitting rear/front load 60/40 while properly adjusted, but now, the rear changes moved or altered either (A) the LSPV ratio or (B) changes to the parking brake and/or drum default offset, then what? Now it's no longer 60/40 and/or the rears aren't engaging as quickly.
    It's going to take longer to engage the drums, leaving all the braking to the front, which is going to feel soft as hell. All it takes (ask FGV) is the rear drum being a tiny bit out of spec - I think it's something crazy like <1mm or something on these 1GTs - and your pedal will feel soft, brakes lakcluster.
    FrenchToasty likes this.
  14. Apr 12, 2024 at 7:41 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I've tried passing my knowledge of carb tuning to the next generation, but polo doesnt seem interested at all.
  15. Apr 12, 2024 at 7:42 AM
    It's a wuff life.
  16. Apr 12, 2024 at 7:43 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I'd like to understand more about how the lspv return line works & how that line would get bled.
  17. Apr 12, 2024 at 7:44 AM
    There's very little to adjust on the rears. First you MUST get the parking brake dialed in. The reason this is so important is the parking brake operates from the lower part of the pads. The normal brakes operate from the top. The whole pad does not move perfectly in from the side, they pivot from the top to apply the parking brake, or from the bottom to provide the regular brakes. Getting the parking brake set properly gives the regular brakes the appropriate pivot point for good engagement. Then you set the brake pad distance from the drum with the starwheel adjuster to get the brake travel minimized, engaging the rears as soon as he pedal is depressed which then sends the pressure forward engaging the fronts sooner and improving the brake feel, travel, and effectiveness. Adjusting the LSPV should be last to blend the brake pressure front to back to keep the rears from locking up when hard braking.
  18. Apr 12, 2024 at 7:47 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    News to me. The earlier trucks were definitely different.
  19. Apr 12, 2024 at 7:49 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    To keep beating the aa dead horse, only some DC's and sequoias have dual rear brake lines? Everyone else only has a single line that splits at the axle? So the abs cant control the rear wheels seperately?
  20. Apr 12, 2024 at 7:50 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Stop, drop, shut 'em down, open up shop
    Oh, no, that's how Ruff Ryders roll
  21. Apr 12, 2024 at 7:57 AM
    daveeasa
    David
    Someone help me understand the super high level reasons why drum to disc is such a chore?
    Am I correct in understanding that the primary problem is a mounting bracket for the caliper itself? Which would need to be well braced to the axle housing? Or whatever the part that encloses the part that spins to apply force is called? Driveshaft and axle are the only words I know about.
    Seriously seeking to learn here.
  22. Apr 12, 2024 at 7:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did he go full long travel? I thought that involved more than just longer shocks. But either way, if he changed the ride height without adjusting the LSPV, that could definitely be an issue. That thing is extremely finicky for me. Mine is not working like it's designed. It's weird that it varies day to day for me.
  23. Apr 12, 2024 at 8:00 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    I can vouche for this... Recent rear brake job. My bellcranks are obviously fused together with rust, (heat/pb/and a 3lb sledge... didn't budge) so adjusting the rears pads out manually got rid of 90% of my pedal travel.
  24. Apr 12, 2024 at 8:00 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Not yet. He's prepping for it
  25. Apr 12, 2024 at 8:02 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    @daveeasa
    Gotta get the drums & backing plates off, which means pulling the axles. Then need an adapter to bolt the caliper to the axle flange (which is a different shape than the sequoia flange, but not sure about the 4runner or FJ flange) then, i'm pretty sure the disc calipers take more fluid than the drums, so might need an adjustable proportioning valve. And some fine tuning to get everything to work together. I know the sequoia had a larger piston in the MC. But it also had 4 channel ABS.
    daveeasa likes this.
  26. Apr 12, 2024 at 8:14 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    what did you do to get to this point? Did you change rear brakes? Did you change front brakes? Did you just install new pads and do a bleed for the heck of it?
  27. Apr 12, 2024 at 8:17 AM
    I dunno, the pictures I saw showed two new shock mounts welded onto the axle tubes on the back side of the axle, passenger one was a few inches outboard from the LSPV bracket. I don't recall whether the LSPV bracket was still intact or not. I also don't know if the axle was sitting higher/lower after.
    I mean, realizing the gear ratio on the axle assembly matched, of course.
  28. Apr 12, 2024 at 8:18 AM
    daveeasa
    David
    And pulling the axles, that’s required for a regear, correct? Hard but not brutal?
    the adapters are one trick and the fluid is the real source of trouble?
  29. Apr 12, 2024 at 8:27 AM
    Does anyone remember if the DC/Sequoia rear axle is wider or skinnier than the AC/RC trucks?
    I'm just thinking ... if the DC/Sequoia rear axle is like 1" wider, knowing the wheels naturally sit a little more inboard, maybe it'd be advantageous for AC owners to grab a Sequoia assembly swap to get all-wheel disc?
    I think you'd ve able to ditch the LSPV, although you'd probably want to install a manual PV. Else if you really needed to keep LSPV with discs (I can't think of why), you'd potentially need to weld on an LSPV bracket, I don't think the Sequoia has LSPV. And I don't think any of the DC came with disc.
    Anyway, just spitballing some random brain chatter over here.
    Mr.bee likes this.
  30. Apr 12, 2024 at 8:30 AM
    Axles are diff't length between RC/AC and DC.
