  1. Jul 24, 2020 at 6:36 PM
    #6121
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Inhaled more paint fumes tonight.
    Darkness, imDementeD, bmf4069 and 4 others like this.
  2. Jul 24, 2020 at 8:33 PM
    #6122
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    its a regular occurrence in MN.
    Minnesota nice is a myth. Many Minnesotans are passive-aggressive arseholes.
  3. Jul 25, 2020 at 12:29 AM
    #6123
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    argh! How the hell did I miss it. Notifications on this site are killing me! Thank you. It is the same and I just ordered it.
  4. Jul 25, 2020 at 5:21 AM
    #6124
    Professional Hand Model
    Hand Protectors
    My theory is that they see the lights and feel ‘safe’ that they see the lights, therefore, allowing them the comfort of stabbing out in front of me. I really noticed people mesmerized by my LED Katanas during all conditions. Maybe they put a spell on them?
    Now, without the lights they have ‘doubt’ and wonder is this guy coming in hot?:rofl:
    All I know is people don’t pull out in front of me as much now that DRL is off.
    MS22, lsaami[QUOTED] and Tundra2 like this.
  5. Jul 25, 2020 at 6:26 AM
    #6125
    Hand Protectors
    Bump.
  6. Jul 25, 2020 at 6:28 AM
    #6126
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm not 100% sure on how it works, but given I have a little knowledge of electrical this is how i see it:
    That connector sends power to the relay that runs the headlights at half power or so. If you tap into it, it should work fine. Add a new circuit, maybe a relay, and it should work perfect.
  7. Jul 25, 2020 at 6:34 AM
    #6127
    Hand Protectors
    But I’m a Hand Model and we do things different. We are wired different. :rofl:
    Its just an idea that hit me last night. Probably won’t do anything with it, but just thinking if I can get some OEM connectors and run a test on some lighting it might be and option for DRL Ambers.
    MS22 likes this.
  8. Jul 25, 2020 at 6:43 AM
    #6128
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    For drl ambers, plug the connector back in and intercept the wire before the headlight relay and tie it into the front.....well, hold on. I'd have to think about that one cause if you energize that circuit it would turn on all the parking lights. Unless you isolated it from the rear somehow. Hmmm.....
  9. Jul 25, 2020 at 6:58 AM
    #6129
    Hand Protectors
    I was thinking of just wiring/completing a circuit from one disconnected DRL connector to each new Amber light(s) and then back to the other DRL disconnected connector.
  10. Jul 25, 2020 at 7:07 AM
    #6130
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hmmmm......
    Darkness likes this.
  11. Jul 25, 2020 at 7:09 AM
    #6131
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Showing of your new books I see!
    Darkness and bmf4069[QUOTED] like this.
  12. Jul 25, 2020 at 7:15 AM
    #6132
    Hand Protectors
  13. Jul 25, 2020 at 7:24 AM
    #6133
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    The problem I see is that resistor and the function of the circuit. I can't find the actual wiring diagram, but I think it's a signal circuit for a relay. If you add lights inline, then reconnect, it could cause issues. Or if it's not and you add lights then reconnect, the drl's will come back on and with the additional load may blow a fuse. You'd have to d/c the drl's out of the circuit to make that work.
  14. Jul 25, 2020 at 7:39 AM
    #6134
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Not exactly what you are trying to accomplish, but I would likely run new DRLs on a new circuit with a new toggle switch in the cabin. Still have control when they come on (downside: you have to remember to turn them on and off). But really not unlike many trucks (like my Tacoma) that had a DRL detente on the stalk.
  15. Jul 25, 2020 at 8:35 AM
    #6135
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Uhh, since when did murica get Holdens? I just saw a maloo ute drive by while getting an oil change in Bessie. Didn't have time to get a pic. Then, almost right after that, a clone of my truck drove by! Red and tan and everything! Wtf is going on today!?
  16. Jul 25, 2020 at 8:38 AM
    #6136
    FrenchToasty
    Mo
    Bone stock
    Buy a lotto ticket!
    I almost bought one the other day, every single light on the way to work was green(that’s 5 lights haha) but then it happened the next day, must have changed the timing!
    bmf4069[QUOTED] likes this.
  17. Jul 25, 2020 at 8:40 AM
    #6137
    Casper421
    In the woods
    06 DC
    You must be dreaming! Why else would someone be changing your oil?!
  18. Jul 25, 2020 at 8:57 AM
    #6138
    Hand Protectors
    This is a pretty complete part# list for doing a timing belt for the 2002 4.7L 4x4 AC Timing Belt plus all the other shtuff in/around there. Only thing I question in the way of price is the Radiator which I seem to remember some of you guys getting for $150ish. All items priced are from online stealers for local pick up.
    I have not confirmed the part#’s with stealer via phone, but have done so with 2 other online type OEM dealers. Yes I am looking at redoing the seals/washers/gaskets at our Oil Cooler. The timing belt is from a non-dealer online source touting direct sourced parts from factories that Toy uses.
    This list has taken about 4 hours to compile. Save it for future use. You may not need all the parts I plan on doing, but at least you’ll have it.
    Right now the list sits at about $1500 before taxes. I can trim some cost on the Radiator and maybe not doing the Bracket TSB. Also, hoping to score the Black Friday 30% discounts I saw last year on some online dealers. Hoping to get the complete list below for under $1000. Keep in mind this includes basically the entirety of everything between the front bumper and engine block for around $1k.
    Local shops/stealers will charge $1100 just for a basic TB change (Labor/Parts) and skip most of these other items depending on your region.
    Toyota Timing Belt Project
    Timing Belt Kit Toyota Tundra 2000 to 2006 4.7L $279*
    TSB Newer Style Accessory Belt Tensioner/AC Bracket (not necessary to do)
    16620-0W036 tensioner 68.40
    88431-0C011 AC Bracket 73.76
    Zerex Asian Red $20 Gallon (x4) 80.00*
    Alternator 100A 27060-0F020 218.90*
    Core charge. $75*
    Oil Cooler Hoses and Clamps and Seals.
    Hoses 15777-50060. 14.91*
    16281-50030. 7.47*
    16282-50070. 6.29*
    Cooler Hose Clamps (6) 90467-20011 18.00*
    Oil Cooler O-Ring ? (TBD!)
    Oil Filter Bracket Gasket 15692-50020. 1.00*
    Cam Shaft Sensor. 19300-50020. 116.02*
    Crankshaft Position Sensor 90919-A5001. 99.17*
    Oil Pressure Sending Sensor 83520-60051. 49.62*
    Oil Dipstick Tube Seal 96721-19010 2.03*
    Radiator 16400-0F020. 349.00*
    Radiator Hoses 16571-0F010. 24.54*
    16572-0F011. 29.85*
    Radiator Clamps (4) 90466-41003. 40.00*
    Engine Coolant Temperature Sensor 89422-35010. 55.43*
    Temperature Sensor (Transmission) 89429-34010. 55.43*
    bmf4069 and Lil Steve like this.
  19. Jul 25, 2020 at 9:59 AM
    #6139
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It's for my work truck. Oil change and inspection.
  20. Jul 25, 2020 at 1:15 PM
    #6140
    Hand Protectors
    Wurrld Peas dinner. Used ChopStick Fly Technique.
    bmf4069, NUDRAT[OP] and Lil Steve like this.
  21. Jul 25, 2020 at 1:17 PM
    #6141
    Hand Protectors
    Thats right. Let the monkeys mess up Bessie so you can take a few days off from work. :rofl:
    bmf4069[QUOTED] and Tundra2 like this.
  22. Jul 25, 2020 at 1:32 PM
    #6142
    Dog
    Dog sit!
    Where's the beef? That's not how nature is supposed to work...
    Pucks18, bmf4069, MS22 and 3 others like this.
  23. Jul 25, 2020 at 1:35 PM
    #6143
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    lol, I tried looking for a meme to quote his post with
  24. Jul 25, 2020 at 1:44 PM
    #6144
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Meat makes a no go.
    20200708_175203.jpgVeggies makes a go go.
  25. Jul 25, 2020 at 1:53 PM
    #6145
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Nothing special for me today. Ghoulash wid grille cheese
    Pucks18, Hooptytrix, bmf4069 and 4 others like this.
  26. Jul 25, 2020 at 2:00 PM
    #6146
    Hand Protectors
    Its all about building Carbon Credits. Not sure if you noticed, but I’m really really working hard on my Social Credit Scores so when it comes time to need them I’ll at least have a good start. I need to redeem my poor Non-PC past and renew into a post modern man. Soy is the Future!:rofl:
    Hooptytrix, bmf4069 and shifty` like this.
  27. Jul 25, 2020 at 2:02 PM
    #6147
    Hand Protectors
    I call that Shovel Food. You just Shovel it in and enjoy. Looks really good.
    Tundra2[QUOTED] likes this.
  28. Jul 25, 2020 at 2:05 PM
    #6148
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Please soy it isn't so
    bmf4069 likes this.
  29. Jul 25, 2020 at 2:05 PM
    #6149
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  30. Jul 25, 2020 at 2:08 PM
    #6150
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    is this a poem to PHM?
    You guys sure have been bromancing hard these past weeks :rofl:
    Pucks18, bmf4069, FirstGenVol and 4 others like this.
