  1. Mar 4, 2024 at 11:33 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Local Lexus dealer was fine doing an alignment after I replaced the entire rack and tie rod ends
  2. Mar 4, 2024 at 12:09 PM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    You will find some shops that don't really care and will help out. I had one that wouldn't install the parts that I bought because they didn't buy them. Even though the parts that I bought were OEM and still sealed in the box/bags. :smash:
  3. Mar 4, 2024 at 12:58 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Just pulled the trigger on an Eaton TruTrac LSD to match my new to me 4.10's, for the 03 street queen. PayPal credit ftw. 6mo interest free. I can definitely pay it off before then. :woot:
    whodatschrome, bmf4069, txagg and 7 others like this.
  4. Mar 4, 2024 at 3:13 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Pretty much every shop in MA is like that.
    Dakillacore[QUOTED] likes this.
  5. Mar 4, 2024 at 4:37 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    sounds like a hissy fit. Not a shop you'd want to patronize.
  6. Mar 4, 2024 at 4:55 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I love it when people come in for alignments on work we didn't do. About 50% of the time we find stuff wrong and charge to fix it :D
  7. Mar 4, 2024 at 4:57 PM
    NUDRAT
    SW CT
    That's a good thing isn't it? More revenue for you, more safety for them (and everyone else on the road).
  8. Mar 4, 2024 at 4:57 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Agreed
    NUDRAT[QUOTED][OP] likes this.
  9. Mar 4, 2024 at 5:02 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I never cared when people installed their own parts. We would just say "ok, you HAVE to understand, we cannot warranty anything. If one of the parts you bought fails, it can negate any/all work we did to your vehicle. Do we have a clear understanding? Ok. Sign the waiver here."
    Full price and no warranty????? Shhhhiiiiiiiii
  10. Mar 4, 2024 at 5:12 PM
    Jack McCarthy
    Bill
    North of Boston
    The shop hated me because I maxed out the camber to be positive to insure the new control arms would achieve something more positive than -0.5 (old control arm bushings were shot and maxed at that number).
    Well the guy spent an hour on the machine trying to get it to pass before giving up. Shop manager tells him to drive it off the plates and reset the machine for a new alignment.
    After that and the tire slipping (made a pop noise as it pulled off the plate), he was able to redo it and get it to pass.
    Lesson learned. Don’t align a front end that’s TOO far out of alignment, which the machine can’t handle.
  11. Mar 4, 2024 at 6:30 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    Thanks for that tip KNABORES, just used it. :fistbump:
    KNABORES[QUOTED] likes this.
  12. Mar 4, 2024 at 6:56 PM
    Trouble in GM 6.2 land today. BIL drove the truck over to the tuner (literally at the end of our road). Offered to tow it over, but said he’d just put it in Low 1 gear and basically idle over. Ok, fine. I’ll follow you. Well, he got on it a little turning out of the hood to go the 120 feet to the shop doing the tune and it popped and code and went reduced power, shut off when he rolled into the parking lot. Scanned the code, P0011, cam advance error. Ok, not awesome, probably from too much throttle and no tune. Cleared code and it wouldn’t restart. Thought it was a bad battery not letting it restart as it was cranking weak at times. Left it with the shop. They called and said they couldn’t get it to start. “Wouldn’t turn over”. Dreaded words post engine rebuild. We get a new battery and test it, barely turns the motor, but it does turn thank god. Bad starter? Nah, I’m thinking timing issue after the code. Screw it, we tow it back to the shop and pull the valve covers. Rockers are all rocking when rotating the motor, but it’s harder than normal to rotate. Pull the spark plugs, no change. Pull the rockers and pushrods, no change in the effort required to rotate. Pissed and disappointed, called it a day. Will pull timing cover and check the VVTI sprocket and timing position when we work on it again. We were so close.
    whodatschrome, bmf4069 and des2mtn like this.
  13. Mar 4, 2024 at 7:01 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
  14. Mar 4, 2024 at 7:07 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    DAMN :eek:
    NUDRAT[OP], CodyP and bmf4069 like this.
  15. Mar 4, 2024 at 7:10 PM
    Yeah. Not sure what causing the increase in effort required to rotate the motor. We’re down to cam and crank rotating. I even took the accessory belt off. Zero clunks or tapping noises or anything when it shut off. Feels like too tight crank bearings when you’re first assembling a motor. Something is dragging or resisting. It’s not compression or valve train as those have been eliminated. My poor BIL is heartbroken. Told him to keep his chin up. We move forward.
    bmf4069, BroHon, Sunnier and 3 others like this.
  16. Mar 5, 2024 at 4:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    We're not sure what caused it. We were doing some fast boi shit in the sand and I heard popping over some whoops. It sounded like it was coming from the front though. It stopped popping on the next run. That was on Thursday. I had people behind me on trails everyday after that and nobody said anything. It wasn't until we were braking down the camps on Saturday that someone saw it. We went to see Bruce over in CA to get it welded back before we left Sunday morning. All seems we so far. Except the sheen of oil covering the bottom of the truck when I got back home...
    JakeJake likes this.
  17. Mar 5, 2024 at 4:35 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Damn, you think you would have heard it slapping around or felt the difference anyway
    I've got a sheen and it's no problem... free undercoating! :D :rofl:
    Hope that turns out not serious:thumbsup:
    Love those pics between the rocks, cool AF
    bmf4069[QUOTED] likes this.
  18. Mar 5, 2024 at 5:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Also, finally mileage for the journey.
    whodatschrome, txagg, BroHon and 6 others like this.
  19. Mar 5, 2024 at 5:25 AM
    Oil temp light is on dude
    FrenchToasty and bmf4069[QUOTED] like this.
  20. Mar 5, 2024 at 5:45 AM
    FrenchToasty
    Mo
    Bone stock
    Mine is too when the truck isn’t running
  21. Mar 5, 2024 at 5:53 AM
    Dang, you're right. Truck died dude.
  22. Mar 5, 2024 at 9:03 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    New Subaru owner financing their overlanding starter pack
  23. Mar 5, 2024 at 9:37 AM
    Jack McCarthy
    Bill
    North of Boston
    There's enough space on the roof to lie down comfortably in that?
  24. Mar 5, 2024 at 9:39 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    We'll find out. I'll post once it's done
  25. Mar 5, 2024 at 10:08 AM
    FrenchToasty
    Mo
    Bone stock
    Nap test?
  26. Mar 5, 2024 at 10:27 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    It’s a 1 1/2 man tent. I’m not impressed.
    Jack McCarthy likes this.
  27. Mar 5, 2024 at 10:40 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Say, do these look familiar?
  28. Mar 5, 2024 at 10:46 AM
    Sunnier
    Sunny
    San Diego, CA
    Length of sleeping area?
  29. Mar 5, 2024 at 10:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is this aftermarket or part of some package that Subaru offers?
  30. Mar 5, 2024 at 10:50 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    4' W, 7' L
    Sunnier[QUOTED] likes this.
