  1. Feb 21, 2024 at 7:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Is Continental Elite the serpentine belt that used to be the Gatorback belt or does anyone have anything horrible to say about it? (Puck excluded).
  2. Feb 21, 2024 at 7:36 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I only went to Decatur because that was the one you listed in the ad. I'll check Birmingham for sure.
  3. Feb 21, 2024 at 8:02 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    10-4. It sounds like a Toyota corporate sale so you can probably pick from your favorite dealer list.
  4. Feb 21, 2024 at 8:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :frusty:
  5. Feb 21, 2024 at 9:44 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Is the plastic drop-in bedliner secured or mounted in any way? Or does it just sit there and tuck under the bed rails?
    Planning on pulling it out soon and cleaning underneath it.
  6. Feb 21, 2024 at 9:47 AM
    Is there a ninth injector in there? Also missing a turbo, I only see one. A sequential setup would be cool.
    bmf4069 likes this.
  7. Feb 21, 2024 at 9:48 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Mine is just sitting in there, under the bed rails
    FiatRunner likes this.
  8. Feb 21, 2024 at 10:07 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  9. Feb 21, 2024 at 10:41 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    My list is a little out of order, but here's what's in my cart. Other than a THIS, what might I be missing?
    VALVE COVER GASKETS & TIMING BELT JOB
    Spark Plugs - 90919-01192 (x 6)
    Spark Plug Wires - 19037-62010 (1 Set)
    Throttle Body Gasket (Not for Supercharged engines) 22271-62040
    Intake Plenum Gaskets - 17176-62040 (x 2)
    Valve Cover Gaskets - 11213-62020 (x 2)
    PCV Valve - 12204-62010
    PCV Grommet - 90480-18001
    Semicircular Plugs - 11183-62010 (x 4)
    Valve Cover Bolt Washers - 90210-05007 (x 16)
    Camshaft Plugs - 11188-62010 (x 4)
    Toyota FIPG - 00295-00103
    Spark Plug Tube Seals - 11193-70010 (x 6)
    REAR MAIN SEAL - 90311-38051
    Thermostat- 90916-03075
    Thermostat Gasket - 16325-62010
    Power Steering Belt- 99364-81070
    Alternator Belt- 90080-91090
    A/C Belt- 99364-20870-78
    Timing Belt 13568-YZZ03
    Tensioner 13540-62021
    Water Pump 16100-69398-83
    Camshaft Seal - 90311-40022 (x4)
    Oil Pump Front Main Seal - 90311-40022
  10. Feb 21, 2024 at 10:45 AM
    Dang. You pulling the motor or dropping the transmission?
    bmf4069 likes this.
  11. Feb 21, 2024 at 10:53 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Drop trans should be the easier route
  12. Feb 21, 2024 at 10:55 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You covered your ass with this. Smart.
  13. Feb 21, 2024 at 10:57 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Ever seen a 4" straight pipe for some sort of diesel on cl for $25 & decide you needed it?
  14. Feb 21, 2024 at 11:04 AM
    Through bed exhaust snorkel
  15. Feb 21, 2024 at 11:10 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    its not perfect, but i could make it work.
  16. Feb 21, 2024 at 11:11 AM
    Why aren’t our automotive air conditioners powered this way
    BroHon and Mr.bee[QUOTED] like this.
  17. Feb 21, 2024 at 11:12 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Voss, BroHon, bmf4069 and 2 others like this.
  18. Feb 21, 2024 at 11:17 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :sawzall::welder::popcorn:
    Cats and resonator delete? Perhaps single exit straight pipes? Gonna need some headers to really complete my vision haha.
    I'm thinking LT headers, no cats, 3 inch intermediate pipes going to a Y with a 4 inch pipe out, no muffler, just a resonator, dumped after the rear axle. :notsure:
  19. Feb 21, 2024 at 11:18 AM
    Nascar dustpan exhaust tips.
  20. Feb 21, 2024 at 11:20 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    for a sense of scale:
  21. Feb 21, 2024 at 11:23 AM
    That’s gonna mess with your back-pressure, er flux capacitation uh inline rotary gutter specs.
    Voss, artsr2002, BroHon and 3 others like this.
  22. Feb 21, 2024 at 11:28 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Send it :devil:
    Mr.bee[QUOTED] likes this.
  23. Feb 21, 2024 at 11:35 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    What discount code are you using? @bfunke posted this one a little bit ago. Still active 257187659198834985
  24. Feb 21, 2024 at 12:15 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    So before I place my order for WL calipers, rotors and pads, do the WL calipers use the same caliper bracket as the WE?
  25. Feb 21, 2024 at 12:20 PM
    yes
  26. Feb 21, 2024 at 12:22 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Pretty sure they use the same rotors.
    The Black Mamba likes this.
  27. Feb 21, 2024 at 12:29 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    I'm replacing rotors anyway since these are warped again after 8 years.
  28. Feb 21, 2024 at 12:34 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I think I finally found the wheels I’m gonna get
    It’s either those or the rocktrix rt112 in bronze. Just cause it would cost me like $150 less
  29. Feb 21, 2024 at 12:42 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    How does everyone warp rotors? Are you too close to the vehicles in front of you? Get surprised by obstacles? Tow a trailer like you stole it? Maybe towing a TT down a mountain pass being chased by a passive aggressive roadrager?
    the tundra has better engine braking than the 5.6 in the titan.
    FirstGenVol and BroHon like this.
  30. Feb 21, 2024 at 12:43 PM
    FishNinja
    Lee
    06DC2wd
    I also wonder this
