  1. Jan 24, 2024 at 4:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    These zerks are brand new. I’m thinking there is an issue with them. I will actually look at them closer. I’ve got a pack of them somewhere so I’ll try to swap them out. If still not working, new gun nozzle.
    BroHon[QUOTED] likes this.
  2. Jan 24, 2024 at 4:27 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I currently have two different sets of beadlocks (on two different CJ7s. OMF and TrailReady). I haven’t noticed any weird stuff from them. I suppose one of these years i’ll have to go back and check the torque on the ring bolts.
  3. Jan 24, 2024 at 6:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My buddy in the hill country runs beadlocks and 37's on his FJC. He drives it on the street. I know @Mr.bee talked to em about it the last time we saw em at Hidden Falls.
    khooiii[QUOTED] likes this.
  4. Jan 24, 2024 at 6:15 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I wonder if you can (on the bench) apply finger resistance and stop the flow, make it come out around the grease gun.
    Last bunch of grease zerks I bought were from an ACE hdw and were stainless... mmmm nice.
  5. Jan 24, 2024 at 6:26 PM
    Sunnier
    Sunny
    San Diego, CA
    :rimshot:
    whodatschrome[QUOTED] likes this.
  6. Jan 24, 2024 at 6:33 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    This thing will open it back up if it’s clogged.
  7. Jan 24, 2024 at 6:37 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I Haven’t tried this but it looks interesting…
    https://youtu.be/OExN2vzO3VU?feature=shared
  8. Jan 24, 2024 at 9:02 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    It doesn’t fit every scenario, but I have a ‘lock-n-lube’ end on one of my grease guns and it’s great, you know it’s on right and won’t pop off. It’s way easier to use, just can’t fit everywhere a normal tip does. Not that that sounds like your problem, just a recommendation.
    Azblue, shifty`, Dakillacore and 4 others like this.
  9. Jan 25, 2024 at 7:06 AM
    shifty` Goons of Hazzard
    The vintage tips I use lock on naturally. I have a lock-n-lube but haven't installed it. It looks really convenient. I need to rebuild one of my decades-old Craftsman grease guns totally in the near future. I was hoping to find a video showing a breakdown of how to rebuild, just so I could see the guts before getting in.
    The Black Mamba likes this.
  10. Jan 25, 2024 at 7:24 AM
    Jack McCarthy
    Bill
    North of Boston
    Why is it Nokian can make retractable studs for their tires yet I see no footwear with comparable technology? I would think retractable stud boots would be a big seller.
    Edit: Found some but the cleats have to be manually retracted.
    khooiii and 455h0le_dachshund like this.
  11. Jan 25, 2024 at 7:40 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Seriously. They can make heelies and those 90’s retractable roller skates, but not studs?!
  12. Jan 25, 2024 at 7:48 AM
    Jack McCarthy
    Bill
    North of Boston
    I found some but you have to manually flip them out and flip them back on the bottom of the boot. It’d be nice in this day and age to have them pop out/retract automatically if you start to slip. Even if you could hit a button on your keychain to whip them out it’d be okay.
  13. Jan 25, 2024 at 7:55 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    We used Yaktrax on our shoes in Northern Japan. Prevented a lot of slips and falls.
    Jack McCarthy likes this.
  14. Jan 25, 2024 at 7:59 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    if i were making em, you'd have to click the heels together 3 times.
  15. Jan 25, 2024 at 7:59 AM
    Jack McCarthy
    Bill
    North of Boston
    I’ve used those or something similar in the past. I was just looking for something more convenient that could be used and retracted on demand.
  16. Jan 25, 2024 at 8:00 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Could you imagine? "Hey guys hold up, I have to charge my shoes before we go hiking". Hah.
  17. Jan 25, 2024 at 8:11 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    I've got my front steering knuckles off doing some other work, the knuckles are a bit rusty (am going to clean them up) and the bearing seals are falling apart. I'm replacing my bearings (OEM) while I've got the knuckles off.
    Is buying the OEM inner and outer bearing seals worth it over buying National branded seals. It looks like OEM seals are going to cost me $80 per side, while the National seals are $46 per side.
  18. Jan 25, 2024 at 8:13 AM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, but we’ve all encountered situations where regular boots are sufficient except for patchy areas where whipping them out would reduce your chance of slipping. Nobody wants to put on and take off yaktrax 2-3 times out on a walk or hike.
  19. Jan 25, 2024 at 8:28 AM
    The question I ask myself in situations like this is: Do I want to be doing this again in the next 15-20 years?
    If the answer is "NO", then I'll go with OEM or with the manufacturer that made the OEM part (should be Koyo for wheel bearings IIRC).
    If the answer is "YES", I'd consider going off-brand, but let's be real, the shorter life expectancy of off-brand is why the parts cost less money.
    Granted, that doesn't justify the prremium price Toyota puts on its parts entirely, but it seems like they tend to price fairly in the ballpark of [(Toyota longevity ÷ Off-brand longevity) x (Off-brand price - 25%)], plus or minus a few percent.
    Personally if I know I'm getting 4x the lifetime but only paying 2.5x - 3x the price, I'm coming out ahead, and not just on labor...
  20. Jan 25, 2024 at 8:30 AM
    kentuckyMarksman
    Thanks for the input. I'm going OEM on the actual bearings. Was just hoping the National branded seals would be quality. Sounds like I should go OEM all the way.
    Sunnier likes this.
  21. Jan 25, 2024 at 8:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I wouldn't be scared of all aftermarket for bearings/seals. I personally wouldn't use National but if SKF or Timken are significantly cheaper than OEM they're solid brands.
    shifty` likes this.
  22. Jan 25, 2024 at 9:24 AM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Yeah we also have a cool place we could stay for free in Pagosa Springs. I was looking at doing this Byway with the family. https://tracksacrossborders.com/. I think there are some off road sections which would be fun to do in the truck with the kids. Anybody familiar with this?
    txagg likes this.
  23. Jan 25, 2024 at 11:16 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Update on my zerk fitting situation. Problem solved by replacing the gun’s coupler :thumbsup:
    NUDRAT[OP], khooiii, txagg and 6 others like this.
  24. Jan 25, 2024 at 11:18 AM
    Jack McCarthy
    Bill
    North of Boston
    Always use a Lincoln fitting IMO. For me a 3 prong, the cheap 4 prongs won’t let go, but that’s a different problem.
    Glad you got it resolved.
  25. Jan 25, 2024 at 11:56 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It’s a 4 :anonymous:
    Loosening the coupler spring helps to release it
  26. Jan 25, 2024 at 1:41 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Horde AP rounds
  27. Jan 25, 2024 at 4:06 PM
  28. Jan 25, 2024 at 4:15 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Tundra was putting in some work today on Fort Hood. My dad recently retired because of crippling arthritis, and has somehow managed to get himself into furniture wholesaling. I'd say she's a little over payload. Meanwhile new rear shocks and air bag helpers sit in my garage.....
  29. Jan 25, 2024 at 5:05 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Might have to do this myself.
  30. Jan 25, 2024 at 5:06 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    If I start to slip I just flail my arms as hard as I can. Can confirm it works 50% - suggesting user error.
