  1. Jan 24, 2024 at 10:30 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    damnit, thanks for the disappointment :boink:
    bmf4069[QUOTED] likes this.
  2. Jan 24, 2024 at 10:37 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Did you catch the vid?
  3. Jan 24, 2024 at 11:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm still catching up on this thread. I was still on pg 1920.
  4. Jan 24, 2024 at 11:03 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I meant the covid
    bmf4069[QUOTED] and FrenchToasty like this.
  5. Jan 24, 2024 at 11:08 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    artsr2002, txagg, Dakillacore and 2 others like this.
  6. Jan 24, 2024 at 11:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ooooh. Yeah, pretty sure I had the rona. I'm still not 100%. It started thrusday 2 weeks ago.
    FrenchToasty likes this.
  7. Jan 24, 2024 at 11:20 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
  8. Jan 24, 2024 at 11:28 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Did it Slowly go through symptoms one at a time... like fever/loss of appetite/diarrhea/chest/sinus/loss of smell-taste, then you just feel fkn exhausted?
    Guy at work just got it for the 3rd time, he is fully VXD:confused: but I think he regrets not getting his 8th or 9th booster...................o_O
    :rofl::rofl:
    Hope your feelin better man, its an ass kicker!
    whodatschrome and txagg like this.
  9. Jan 24, 2024 at 11:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It hit all at once. Fever, chest, butt pee. No sinus or loss of taste. I got wore out easily after that subsided, and still do. Still have a slight cough. No vax here though.
    BroHon[QUOTED] likes this.
  10. Jan 24, 2024 at 11:54 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, me either. That was sarcasm about my co-worker.
    Several of them that are vaccinated and boosted have had it several times... and not covid "light" either.
    whodatschrome likes this.
  11. Jan 24, 2024 at 12:45 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    EDIT: I’m actually a dumbass “there here” hahahaha
    They’re* here! Ceramic coated and curing.
  12. Jan 24, 2024 at 12:51 PM
    Those are slick! Are they real beadlocks?
    khooiii[QUOTED] likes this.
  13. Jan 24, 2024 at 1:05 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yessir race line monsters. About to kill my mpg these suckers are heavy haha
  14. Jan 24, 2024 at 1:07 PM
    You running these on the roads? Or dedicated off-road vehicle
  15. Jan 24, 2024 at 1:07 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yes. :rofl:
  16. Jan 24, 2024 at 1:10 PM
  17. Jan 24, 2024 at 2:57 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    How so? Lot of my buddies do it and I’m a stickler for routine maintenance.
  18. Jan 24, 2024 at 3:11 PM
    Very few people run actual beadlocks on the streets. They are not designed for street use. They are designed to “prevent wheels from dismounting when placed under massive amounts of torque load and lower-than-normal tire pressures”. Most also do not have DOT approval and cannot be run on the streets in some scenarios at all. Interpretation of that is varied, and definitely applies to vehicles under DOT scrutiny, but maybe not for common passenger cars depending on who you ask. Many tire shops will not balance true beadlock wheels. You could run balancing beads in them or do your own mount and balance possibly. Not much can go wrong off-road with a beadlock that comes loose or allows some leakage of air around the bead as you are probably looking to be down in the 3-8psi range rock crawling if your on beadlocks. On the street, the beadlock ring is what’s holding the bead, and keeping the air in at much higher pressures. Check those bolts often and keep a close eye on the tire psi as a loss of bead will lead to a loss of pressure and potential blowout. Sounds like fun having to check all 120 or so beadlock bolts everytime you go for a drive. Not. They do look dope though.
  19. Jan 24, 2024 at 3:26 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    To be completely honest I was preparing for a gnarly DOT lecture haha. Well handled. I definitely understand the consequences of running it on the street and how tedious ownership could be, but I’m prepared. Luckily I’ve got a few connections that can get me setup and if I didn’t these would have been out of question. Thanks brotha!
  20. Jan 24, 2024 at 3:30 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Y’all should have ripped me a new one for this grammatical error :rofl:
  21. Jan 24, 2024 at 3:50 PM
    Don’t worry, I made some of my own.
  22. Jan 24, 2024 at 4:01 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    I don’t know if something is wrong with my zerks or my gun. I tried to put grease in and it just shoots out of the nozzle around the zerk. I used a pin to open the ball of the fitting and I’ve put pressure against the fitting with the gun but I cannot get the grease to go inside the fitting.
  23. Jan 24, 2024 at 4:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    6 lugs need a multiple of 6 spokes & a multiple of 6 bolts. Too many spokes, not enough bolts.
    but i've talked to a few people who run beadlocks full time, everyone has said they've been trouble free.
    455h0le_dachshund likes this.
  24. Jan 24, 2024 at 4:14 PM
    Sometimes loosening the zerk will allow grease in. Or removing the Zerk altogether, cleaning and reinstalling.
  25. Jan 24, 2024 at 4:15 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    What if they’re brand new? I can take the zerk off, I can pump grease through it on the bench and then put it back in, nothing. There is nothing inhibiting the grease behind the zerk opening
  26. Jan 24, 2024 at 4:17 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Can you push the ball in with something?
  27. Jan 24, 2024 at 4:17 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Yes
  28. Jan 24, 2024 at 4:18 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I don’t see a forest. So did the trees get scared and leave?
    455h0le_dachshund and Mr.bee like this.
  29. Jan 24, 2024 at 4:18 PM
    This ^^^
    Ultimately this will tell you if the fitting is working or if it's a prob with your gun/tip/whatever. Does it do it on all zerks or just one? Try another zerk, if the zerk works, swap the zerk over and grease, then clean/replace the other.?
    The Black Mamba likes this.
  30. Jan 24, 2024 at 4:18 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Take the Zerk fitting off and make sure the NEW part's hole is even drilled right/open into the part.
    EDIT: Unless the NEW part you were referring to was the actual Zerk.
    NUDRAT[OP] likes this.
