  1. Jul 14, 2020 at 7:54 PM
    #5671
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if you saw how much money i spent the last 3 days for the 01 tacoma. youd know willwoods are nothing lol
    plus im talking after this tacoma rebuilds "done"
    FrenchToasty likes this.
  2. Jul 14, 2020 at 7:55 PM
    #5672
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Interesting.
  3. Jul 14, 2020 at 7:56 PM
    #5673
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your better than that, do it yourself! Also I don’t know about Spc, but total chaos has little like channels for the grease to travel down when you pump it in, but you also have to completely relieve torque on that thru bolt or you can blow out bushings lickidy split, then retorqe everything back down.
    EL beat me to it
    empty_lord likes this.
  4. Jul 14, 2020 at 7:57 PM
    #5674
    Casper421
    In the woods
    06 DC
    I watch the build on TW. What did you pick up?
  5. Jul 14, 2020 at 7:59 PM
    #5675
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here are links for the two I was planning on. I would like camburgs but after discussing it with @Darkness. Rust would be a major factor in that. Protected UBJ is next best such as these.
    https://www.summitracing.com/parts/mev-cms861200/year/2002/make/toyota/model/tundra
    https://www.summitracing.com/parts/mev-cms861201/year/2002/make/toyota/model/tundra
    I don't know if any of these pictures are good enough for your alls inspection.
    From my inspection it looks like the inside of the bushings where the metal sleeves go are "knurled"
  6. Jul 14, 2020 at 8:01 PM
    #5676
    empty_lord
    05 rollover special
    the leafs (obviously) all the parts to rebuild my 02 rear axle shafts since the 02 is getting the 01s axle shafts (they have new backing plates and bearings, no point in cutting up those backing plates, theyre expensive)
    brake lines, got the front calipers going to powder coat very shortly after i machine the face of them flat. used rear calipers are on their way to powdercoat and rebuild.
    and the machine shop is going to be doing my other 3.4l heads hopefully the end of this week so i can throw that engine and trans in the 01 and maybe drive it for the first time in 5 years (even though thats temporary)
    the big boy engine will be next step to get onto the frame along with the transmission, and a new gas tanks coming shortly. she'll be just about ready to roll under the truck w/e i have all the body work done
  7. Jul 14, 2020 at 8:02 PM
    #5677
    empty_lord
    05 rollover special
    honestly my total chaos uppers lasted 6 winters before they got super sloppy on the taco. I'm running the camburgs uniballs till theyre done, then its getting Icon delta joints installed. (they make adapters to make them work on 1st gen tacos and tundras)
    Casper421 and FrenchToasty like this.
  8. Jul 14, 2020 at 8:03 PM
    #5678
    empty_lord
    05 rollover special
    @Tundra2 those bushings do not look like they'd be grease able
    Tundra2 likes this.
  9. Jul 14, 2020 at 8:04 PM
    #5679
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This will require thinking, and investigating.
    I just want to to keep the lift, and also get an alignment again. I like my tires...
    I'm figuring that since i will be doing a full LCA overhaul I would do the UCA at the same time.
  10. Jul 14, 2020 at 8:07 PM
    #5680
    FrenchToasty
    Mo
    Bone stock
    Gas tanks? Plural? I’m tickled!
  11. Jul 14, 2020 at 8:07 PM
    #5681
    empty_lord
    05 rollover special
    camburgs got me the specs i wanted. (2.7 degrees of castor). but the uppers not adjustable like the SPC arms. they're a fixed position, but with greater castor than stock.
    SPC will give you more adjustment ultimately.
    Tundra2[QUOTED] likes this.
  12. Jul 14, 2020 at 8:08 PM
    #5682
    empty_lord
    05 rollover special
    no. thats just a lack of proper grammer. its getting a stock tank with a gas sock in it (to attempt to remove the risk of air in the fuel under hard acceleration... because race truck)
  13. Jul 14, 2020 at 8:09 PM
    #5683
    Casper421
    In the woods
    06 DC
    Need more info on these adapters! My TC uniballs are driving me nuts! I wanted DJ’s but never saw anything for our trucks.
  14. Jul 14, 2020 at 8:10 PM
    #5684
    empty_lord
    05 rollover special
    also getting an aeromotive pump.. probably 340 for now.. we'll see the supers happening right away. the turbo... not for a while
  15. Jul 14, 2020 at 8:11 PM
    #5685
    empty_lord
    05 rollover special
    call up icon. they have them for the 1st gen tacomas. which use the same upper ball joint design. its a adapter that goes on the spindle to let the delta joint attach to it. the uniballs should just be standard 1" uniballs on the TC arms
    NUDRAT[OP] and Casper421[QUOTED] like this.
  16. Jul 14, 2020 at 8:11 PM
    #5686
    empty_lord
    05 rollover special
  17. Jul 14, 2020 at 8:14 PM
    #5687
    Casper421
    In the woods
    06 DC
  18. Jul 14, 2020 at 8:15 PM
    #5688
    empty_lord
    05 rollover special
    id call em up and see if they want a test mule for the 1st gen tundras. opens up more business for them.. i know when mine start to squeak, im going delta joint. The 01 has uniballs too.. but had i known delta joints would become a thing, I would of put them on.
  19. Jul 14, 2020 at 8:23 PM
    #5689
    Casper421
    In the woods
    06 DC
    That’s the plan first thing in the am. I was warned about uniballs but it’s more annoying than I though. The dj’s are a better design.
  20. Jul 14, 2020 at 8:24 PM
    #5690
    empty_lord
    05 rollover special
    I’ve honestly never had them squeak. I’ve battled bushings squeaking more than anything
    the trick for me has been not maintaining them!
  21. Jul 14, 2020 at 8:29 PM
    #5691
    Casper421
    In the woods
    06 DC
    The bushings squeak even though I grease them every oil change. One of the zerks is cracked so that doesn’t help. The uniballs get squeaky after every trip. Must be the damn Cali dust. I power wash and lube them after every trip. Im over it.
  22. Jul 14, 2020 at 8:33 PM
    #5692
    empty_lord
    05 rollover special
    It does seem to be a west coast thing. If you saw how destroyed my uniballs on the Tacoma were you’d be amazed to hear they never once squeaked.
    good ol NWI road salt treatment
  23. Jul 14, 2020 at 9:25 PM
    #5693
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sweet-ness. This whole page from my last post down was an exciting, and informative read.
    The ultimate goal is returning to alignment.
    Camber, and caster adjustments are nice also.
  24. Jul 15, 2020 at 3:03 AM
    #5694
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    :notsure: working on 30k on my SPC arms and no squeaks.
  25. Jul 15, 2020 at 3:34 AM
    #5695
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sweet!
    I've been meaning to ask a general question for the thread. Those that have them, how you do like them?
  26. Jul 15, 2020 at 3:41 AM
    #5696
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Saw this on the inner-nat! Was like hmmm
    Then I saw this, and was like HMMMMM
    Radio mounted over a CB! That'd be cool. I like radios. Lol
    NUDRAT[OP] and sflips like this.
  27. Jul 15, 2020 at 4:15 AM
    #5697
    Professional Hand Model
    Hand Protectors
    Cell phone and insurance too?:rofl:
    You should do the brakes then. In the grand picture its not much more than the WL. Its a lot of work either way so might as well do it.
  28. Jul 15, 2020 at 4:42 AM
    #5698
    Festerw
    Festerw New Member
    04 Tundra DC
    They got my caster where it needed to be and they're well built. Not a lot of maintenance, I grease them every oil change so 7.5-10k same time I do the driveshafts.
    I live on a dirt road so uniball arms were never a consideration for me.
  29. Jul 15, 2020 at 4:55 AM
    #5699
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Dont want to start another thread so...
    My new coilovers and rear shocks are on so now I am digging into the ins and outs of sway bars as my front links could use replacement. So lots of guys run without the front giving more articulation but also more body roll.
    Anyone run just a rear sway bar? I am wondering if this could be a middle ground: better articulation and independence of the suspension up front but also cutting into the body roll a bit.
    I think I am going to drop the front sway bar and see what that feels like.
  30. Jul 15, 2020 at 5:06 AM
    #5700
    FrenchToasty
    Mo
    Bone stock
    You can also just disconnect the links and let it hang, whichever is easier
