  1. Dec 29, 2023 at 9:01 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @Mr.bee
    Mr.bee and NUDRAT[QUOTED][OP] like this.
  2. Dec 29, 2023 at 9:06 AM
    Oh and @FirstGenVol where is this ...
    Nevermind you cut everything.
    Usually installers will color-code their wiring. Like ... white to door/window contacts. Gray for siren. Red for motion. Stuff like that. If you have any siren, motion, or other sensors you should be able to pop them off the wall and confirm the wire sheath color, and you can use a DMM to test the wiring if you wanted to label it still. You'll want to check and make sure, like, that green isn't a solid single conductor going to a ground bar somewhere nearby (if it is, remove it just to be clean about stuff). Make sure none of the 4-conductor wiring (the red sheaths) are going to a "wall wart" (power brick).
    I agree with everyone above - install a box with a plate. But I'd recommend tossing in a backless low voltage box, slap a blank on it, and label it 'alarm'.
    bmf4069 likes this.
  3. Dec 29, 2023 at 9:07 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The heat kicked on and I can feel air coming through this hole in the wall. Probably explains the dust.
    Weird that they wouldn't seal this a little better.
    Jack McCarthy likes this.
  4. Dec 29, 2023 at 9:08 AM
    Oh, and cutting the wiring isn't a big deal. If all the wiring is going upward, someone can just mount an alarm panel higher up in the wall if needed, or just use some beans to tap off the wiring that's there. But if they don't know what the wiring is, like you don't bundle it in some painters tape and label it "ALARM", they won't know :D
  5. Dec 29, 2023 at 9:12 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Mr.bee and Jack McCarthy[QUOTED] like this.
  6. Dec 29, 2023 at 9:13 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah I know I'm never going to use ADT so I wanted it gone. If a future owner wants to mess with it, they can. I'll work on getting these wires organized.
    shifty` likes this.
  7. Dec 29, 2023 at 9:14 AM
    Expanding foam is your friend!
    Surely you've got a few other places around the house that could use some foam so you're not wasting a can? I have a couple of places where pipes pass into the house that need a refresh every couple of years, for example.
  8. Dec 29, 2023 at 9:15 AM
    NUDRAT
    SW CT
    a little air 'waste' was factored in to systems like these.
    I'd have all sorts of problems if I sealed my house up tight. It just wasn't designed to be tight.
    The Black Mamba likes this.
  9. Dec 29, 2023 at 9:21 AM
    NUDRAT
    SW CT
    There is a fire-stop foam. I used that internally in the house. Like basement to living space.
    Amazon.com: 3M Fire Block Foam FB-Foam, Orange Color, Ready-to-Use, Foam-in-Place, 12 fl oz Can : Industrial & Scientific
  10. Dec 29, 2023 at 9:21 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Expanding foam is awesome. I used a few cans of Loctite foam down in my crawlspace in a few areas. Prepping it for my DIY encapsulation that I have to do down there.
  11. Dec 29, 2023 at 9:23 AM
    If it were me, I'd probably just shove a wad of insulation in the hole.
    To his point though, when you grow up with no/less/meager means, if you want things, you learn. Can't spend $200 buying four used tires if you're paying the HVAC guy $350 to fix your HVAC, or $200 for the shop to change out your alternator, etc.
    NUDRAT[QUOTED][OP] likes this.
  12. Dec 29, 2023 at 9:31 AM
    NUDRAT
    SW CT
    HVAC? Weren't you fancy.
    An exhaust fan in the attic & everyone opens their window once the sun goes down was our HVAC. Lucky kid is in the bedroom close to the attic door (more air movement).
    JasonC. likes this.
  13. Dec 29, 2023 at 9:56 AM
    Jack McCarthy
    Bill
    North of Boston
  14. Dec 29, 2023 at 10:04 AM
    NUDRAT
    SW CT
  15. Dec 29, 2023 at 10:30 AM
    Man, I'd love to have a whole-house exhaust fan again, I haven't even seen one in a house in at least 20 years now.. We'd probably reduce our HVAC usage by a solid 60%.
  16. Dec 29, 2023 at 10:38 AM
    NUDRAT
    SW CT
    I pulled one out of the dumpster at work (electrician shares the dumpster). Someone had him remove it / working condition.
    It's just gathering dust now - no spare electricity in the attic. When I rewire, I'll have it ready to go.
    But i do have vents between 1 & two in the ceiling/floor. Old Skool!
    shifty`[QUOTED] likes this.
  17. Dec 29, 2023 at 10:50 AM
    NUDRAT
    SW CT
  18. Dec 29, 2023 at 11:37 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    My last house had one. It was awesome in the spring and fall (other than pollen season). Don't really miss it..
    NUDRAT[OP] and shifty`[QUOTED] like this.
  19. Dec 29, 2023 at 11:45 AM
    Big waves in Ventura, Ridgeline down!
  20. Dec 29, 2023 at 11:57 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    If you watch the video @Voss posted earlier, the DC actually can be seen driving away after the wave hits
    Jack McCarthy, Sunnier and Voss like this.
  21. Dec 29, 2023 at 11:58 AM
    Oh I’m sure, I’ve already seen the top gear episode.
  22. Dec 29, 2023 at 11:59 AM
  23. Dec 29, 2023 at 12:28 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  24. Dec 29, 2023 at 12:36 PM
    Sunnier
    Sunny
    San Diego, CA
    A buddy sent me a pic of a full sized duelly truck, flipped over in the surf at Pismo.
    Voss likes this.
  25. Dec 29, 2023 at 12:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How does this happen suddenly? A storm or one of those creeper waves?
  26. Dec 29, 2023 at 12:45 PM
    Apparently a sudden rapid rising of the tide during a big wave event.
  27. Dec 29, 2023 at 12:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Got it. Unless he washes that undercarriage off really well that wave will ultimately win. That's crazy.
  28. Dec 29, 2023 at 12:52 PM
    Seismic events can also lend to this. Sometimes on the complete opposite side of the globe.
  29. Dec 29, 2023 at 2:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I need more advice. I'm getting ready to start cutting shelves for this closet.
    This is the goal, but they will be painted.
    The problem is this cutout in the closet. I know it would look better if I didn't bring the shelf past this but that means the shelf would only be 11" deep. I was thinking a shelf should be at least 12-14" deep to be useful.
    What would Tundra Gang do?
    Here's the opposite side where the ADT box was.
  30. Dec 29, 2023 at 2:14 PM
    Wrap the shelf around that cutout? Basically cut the shelf full depth, then full length across, then make a “notch” for that cutout spot in the boards.
