  1. Dec 19, 2023 at 2:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I figure if they really needed to be replaced, I'd have broken em by now
    KNABORES[QUOTED] likes this.
  2. Dec 19, 2023 at 2:24 PM
    Red is normal for lots of movement in two situations:
    • You have both front wheels jacked up at the same time
    • Your rack bushings are worn, soft, or shot
    Like, currenty, with my truck on a roll-on alignment rack I can grab the wheel with the full weight of the truck on it at red and move it and see the whole rack move. And I feel that out on the street also, things are a bit drifty, although part of that is purely the shit caster choices the shop I went to chooses.
  3. Dec 19, 2023 at 2:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Also done in 2019 with poly replacements.
  4. Dec 19, 2023 at 2:25 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    when they do 'break' you'll have stripped the threads and need a rack.
  5. Dec 19, 2023 at 2:26 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ah. That's probably my issue then. Let me try one at a time tomorrow.
    FrenchToasty and Jack McCarthy like this.
  6. Dec 19, 2023 at 2:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  7. Dec 19, 2023 at 2:27 PM
    FWIW though, it doesn't explain the popping. That's the larger concern IMO. You really need to isolate that...
  8. Dec 19, 2023 at 2:27 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The sort of movement when you have both front wheels off the ground (yes, I’ve made that stupid mistake years ago in the past). :D
  9. Dec 19, 2023 at 2:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So I'm doing it right?
    Mr.bee[QUOTED] likes this.
  10. Dec 19, 2023 at 2:28 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    With the steering wheel locked because it was in park with the key off, i also wedge a funny shaped stick under a steering wheel spoke to the floor.
  11. Dec 19, 2023 at 2:28 PM
    You may want to consider jacking up under the LCA also, so there's load on the suspension while doing it. Or maybe not. I've seen people jack at the frame and at the LCA.
    Mr.bee likes this.
  12. Dec 19, 2023 at 2:31 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Rent the tool from local parts store
  13. Dec 19, 2023 at 2:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Could be the CV. Mine popped before I replaced it. The boots were shredded
  14. Dec 19, 2023 at 2:31 PM
    Jack McCarthy
    Bill
    North of Boston
    I do the LCA for simplicity. Only problem is you don’t see play in the LCA bushings that way.
  15. Dec 19, 2023 at 2:36 PM
    I thought he said pops while not turning though.
    His LCA are relatively new though, so I figured it's worthwhile for him.
  16. Dec 19, 2023 at 2:37 PM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  17. Dec 19, 2023 at 2:38 PM
    Ah, misread then. Yup. Classic CV symptom.
  18. Dec 19, 2023 at 2:39 PM
    Someone has some reman CV over in the marketplace forum for $250 shipped rn.
    FrenchToasty likes this.
  19. Dec 19, 2023 at 2:42 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The CV axles look fine. Boots are still looking new. I suspected them initially. I agree the noise is a concern. I'm stumped. It could be the SPC upper ball joints right? I suspect those won't last as long as OEM but I've greased them at proper intervals.
    I also don't get why the noise seems to go away after a few minutes of driving.
  20. Dec 19, 2023 at 3:05 PM
    Mine was the same and you saw the carnage that was responsible
    shifty`[QUOTED] likes this.
  21. Dec 19, 2023 at 3:22 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I get a lot of play from the rubber coupler in the steering shaft I’m pretty sure, after a new rack it still did the same and sounded the same, it seems weird for it to be that noisy if it’s rubber?
  22. Dec 19, 2023 at 3:22 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I laid across sidewards so i could push some real force slowly to load things. cause my tre boots have been leaking forever, but they were tight.
  23. Dec 19, 2023 at 4:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    IIRC mine popped when I slowed down, sped up, or turned
  24. Dec 19, 2023 at 4:17 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i'll be able to mount it to my vise bench.
  25. Dec 19, 2023 at 4:33 PM
    If it's happening only when turning at low speed, it's the CV axles. Maybe you slung all the grease out. But the joint is failing either way.
    Mine still look good, but definitely have play in them.
    Slow turn in a parking lot, turning after a full stop are typically when popping happens with failing CVs, IME.
  26. Dec 19, 2023 at 5:01 PM
    Damn, Hoss.
    BroHon likes this.
  27. Dec 19, 2023 at 5:04 PM
    It'll buff
  28. Dec 19, 2023 at 5:14 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    The listing sounds like it’s not even their truck. No title. Unknown miles.
  29. Dec 19, 2023 at 5:16 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    I'm going to go against the grain here, I would just swap out the inners. Steering rack replacement is a PITA. Get the lifetime alignment, so if or when the time comes you aren't out any extra.
    ETA- got caught up. Guess it's not against the grain
    bmf4069 and FirstGenVol[QUOTED] like this.
  30. Dec 19, 2023 at 5:16 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    somebody died in that thing
