  1. Dec 7, 2023 at 11:06 AM
    They got their faults, just like anyone.
  2. Dec 7, 2023 at 11:30 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Saran Wrap or PressnSeal would keep the dust out.
  3. Dec 7, 2023 at 11:51 AM
    Emailed ATS about my spring "clunk" issue, and to ask if my weird intra-leaf gap is normal or not. It's on both sides so I assume it is. @rock climber had mentioned his weren't like that. I'm curious to hear what they say.
  4. Dec 7, 2023 at 12:42 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Interesting timing. I sold that Tundra to my nephew, but just bought it back over the weekend. I'm getting a clunk in the back I'm trying to track down.
    455h0le_dachshund likes this.
  5. Dec 7, 2023 at 12:49 PM
    rock climber
    I wonder if it's the diff or the CV's and then if it's aftermarket cv axles.
  6. Dec 7, 2023 at 1:20 PM
    I'm texting over my videos to them.
    If I get under the driver's side, behind the rear wheel, and wedge my knees up into the spare tire to lift the truck up and down, I can definitely hear and feel a 'clunk' in the leaf pack, near the axle, and a little tap/click you can actually feel in the 1st two leafs (above the overload).
    artsr2002 likes this.
  7. Dec 7, 2023 at 2:42 PM
    Their support is awesome. Very responsive. He's shooting videos and pics over to the guys who are assembling the packs for input.
    I can tell you 100% confidently: My clunk is specifically felt most prominently in the 2nd from the bottom leaf (red line), somewhere between in that range (yellow lines).
    I suspected it's coming from the rebound clip (U-shaped clamp). But I removed its lower lock nut and loosened the other (non-nylock) nut there, clunk is still felt. Tightened it all back and loosened the top nut until that barrel was loose, still feel it. I'm suspicious though, because that lower bolt on the rebound clip, the head seems to be floating somehow inside that 2nd leaf. As in, i can run something flat between the 2nd/3rd leafs without hitting that fastener, but I can't do the same between the 1st/2nd leaf.
    I tried saturating all of that shit in white lithium grease, and applied to several other spots just as a sanity check, but no change. I tried clamping all 4 leafs at the tip of the overload, but no change. Only thing I didn't do so far is whacking strategically with a BFH to see if the clunk lessens/increases, but I don't think a BFH is the key to this problem.
    Open to ideas/input here...
  8. Dec 7, 2023 at 2:47 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Wedge some popsicle sticks into the gaps.
    & you mounted your tires inside out.
  9. Dec 7, 2023 at 2:54 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I thought the RCD Bilsteins were for 4-6 inch lifts
  10. Dec 7, 2023 at 2:59 PM
    It's what Toytec sells for our truck for the rears. I ran the part number against Bilstein's site, it jibes with what they're saying: Intended for 0-1" lift or 1-2" or something like that. I rolled with it.
  11. Dec 7, 2023 at 3:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I wonder what the RCD means then
  12. Dec 7, 2023 at 4:27 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    U-bolts?
  13. Dec 7, 2023 at 4:53 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    $225k for 1/3 of an acre in my neck of the woods. Damn.
  14. Dec 7, 2023 at 5:35 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    thats what i'm waiting on. I'll split my property into 20 1/4 acre lots.
    txagg, bmf4069, FirstGenVol and 2 others like this.
  15. Dec 7, 2023 at 5:40 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    So a trailer hood?
  16. Dec 7, 2023 at 6:17 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  17. Dec 7, 2023 at 6:25 PM
    Uh, maybe it means it's the same shock sold with the RCD kit, which Toytec also sells?
    Not u-bolts. Not coming from anywhere near the axle. It's definitely on the rear 1/3 of the leaf pack.
    The u-bolts are longer, new, torqued to FSM spec (98lbft), and criss-cross tightened to ensure even load on the seat. And it's not coming from where the overload contacts the axle housing. I can put my hand directly on the leaf at the back side of the axle housing, and feel nothing. If I slide it 6" back, I start to feel a tapping when I lift/drop the truck. Once I get my hand between the yellow marks I feel a significant single CLUNK, CLUNK, CLUNK with each lift.
    artsr2002[QUOTED] likes this.
  18. Dec 7, 2023 at 9:02 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yes they are. People hop the fence and spray paint them like cadillac ranch.
    Mainly tie rods. Occasionally CVs.
  19. Dec 8, 2023 at 4:25 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    Huh. Never heard of those giant legs before. Pretty damn weird.
    FirstGenVol and bmf4069[QUOTED] like this.
  20. Dec 8, 2023 at 5:09 AM
    Jack McCarthy
    Bill
    North of Boston
    This artwork must’ve been done in the 70s or early 80s. Nobody’s wore long gym socks since that time and with good reason. #SuperLame
    bmf4069 likes this.
  21. Dec 8, 2023 at 6:01 AM
    Bro. I'm standing right here.
  22. Dec 8, 2023 at 6:05 AM
    Jack McCarthy
    Bill
    North of Boston
    Got the long gym socks on, don’t ya?
  23. Dec 8, 2023 at 6:08 AM
    Love the way they hug my calves. But it's gotta be double stripe or triple stripe, I can't do any of that single stripe nonsense.
  24. Dec 8, 2023 at 6:09 AM
  25. Dec 8, 2023 at 6:16 AM
    Leafs and coil-overs in the rear? Y-link in the front? Not sold
    shifty`[QUOTED] likes this.
  26. Dec 8, 2023 at 6:19 AM
    Dakillacore
    Georgia
    My gas mileage is already dog shit where it's sitting, I can't imagine what this hog gets.
  27. Dec 8, 2023 at 6:20 AM
    Based on the rest of the build, It’s probably K swapped. Gets 22mpg on 6.88’s
  28. Dec 8, 2023 at 6:24 AM
    It was definitely unique, not the typical by any stretch. Figured it was worth posting for shits n giggles
  29. Dec 8, 2023 at 6:35 AM
    It’s also sporting the Bluetooth front driveshaft.
  30. Dec 8, 2023 at 6:36 AM
    Oh, you may've missed the location. That's how they do all the trucks down there.
